FixYa.com
Tags:
Compaq MP2800 Multimedia Projector
Compaq MP2800 Lamp powers down after a few seconds (by 5 users)
posted by WayneES on Mar 22, 2008
The unit powers up fine and displays a good crisp image, but shuts down within 45 seconds even though both fans are running. I noticed that the Lamp fan came on just as the Lamp began to heat up and stayed on even after the Lamp shut off.
Wayne
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
4 Other Users Have The Same Problem
Comment by gaz-man, posted on Jul 12, 2008
Exactly the same thing hapening to my mp2800 as wayne's. I have only loged 590 hours on the lamp so it should not be that causing the shut down. Kept it very clean over the years so it should not be due to dust or muisture. tryed runing it without the bolb in and it still shut down so ??????
Comment by fabbraun, posted on May 31, 2008
I'm having a similar problem:
Device powers up and i get a good image.
Device fan starts immediately.
Lamp fan starts after about 15 seconds.
After about 1 minute the device powers off (device fan stops, but lamp fan keeps on blowing for some seconds).
Something strange: In standby mode the device produces a quiet clicking-noise.
Did someone of you encounter this problem too?
As a future electrical engineer I already did some measurements (oscilloscope, voltage-meter, ...).
It seems that Ballast is having a problem. It's PFC (Power Factor Controller) which converts the rectified 230Volts (Swiss voltage :-)) to 400VDC has a huge ripple voltage (about 50Volts Peak-To-Peak). The frequency of this ripple is exactly the same as the strange clicking-noise.
For better reparing this ballast I'd be glad having a Schematic of this.
Does someone know where to get this?
Actually it wouldn't be so motivating drawing the schematic (by reverse engineering) because it's multi layer (at least 3 layers) board. :-(
I know there'd also be the possibility to just replace the part. But 150$ (ebay ;-)) for a Ballast seems quite expensive to me - as a student.
Does somene know a better ressource where to get a ballast?
Thanks in advance!
Fab
Comment by lost12, posted on May 01, 2008
Have the exact same problem, guess I will start at looking to replace the fan...
Comment by Guest, posted on Mar 26, 2008
Have exactly the same problem!
Best Solution
posted on Apr 02, 2008
Thanks for Trying (70)
Marrie
Rank:Wiz Wiz
Rating: 84%, 245 votes
Hi Wayne
It is normal for the lamp's fan to start running , but should actually happen within 15 seconds of starting up. Try changing the lamp's fan and if the problem still persists then you will have to replace the Ballast ( lamp's powersupply )
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Multimedia Projectors problems?
Screen is turning blue
My screen is turning blue so I... Answer This...
HELP ME!
We just bought a used... Answer This...
HP VP6210 won´t turn on at...
Hi, my HP VP6210 Projector... Answer This...
Sharp Notevision XR-1S...
Hello - sorry to bother you but... Answer This...
How to reset Compaq MP2800...
Hello, do you know how to reset... Answer This...
Repair Service
Find Multimedia Pro. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
