Question about Abit NI8-SLI Motherboard
NI8 SATA DVD Drive compatability
I recently purchased a Sony Optiarc SATA DVD drive for my Abit NI8 SLI mobo.
When used with a WD raptor SATA HDD, the computer will not boot.
When used with a WD IDE HDD, the computer boots properly.
Is there a fix for this? I am using the latest bios chipset for this mobo.
  • Ylum Mar 24, 2008
    Wow, I would have never thought such drastic measures would be needed for a PNP device.... lol
    Thank you Mike and map9966 for the info. System is working as it should now, with the exception of one thing...
    When set up with the system in SATA, windows is unable to read my WD 250G IDE HDD. It shows up on the boot screen and in device manager but windows/device manager says the disk is "unreadable".
    Initial boot after fresh install of windows the WD IDE 250G HDD showed up as 'WDG WD6540FB-04GUC4 (0000000000' on boot screen and in windows device manager. This was with jumper set to slave.
    Upon second boot With jumper set to slave the HDD was unreadable by windows and showed up as 'WDG WD6540FB-04GUC4 $$$$$$$$$$$' in device manager.
    Third boot with no jumper it showed up as 'WDCWD2500BB-00GUC0' and was still 'unreadable'.
    Forth boot with jumper set to cable select it showed up as WDCWD2500BB-00GUC0 and was still 'unreadable'.
    Fifth boot with jumper set to PM2 it showed up as 'WDCWD2500BB-00GUC0' and was still 'unreadable'.
    After installing iNvidea IDE controller drivers, system freezes on the windows logo splash screen. Which is exactly what the system was doing just before I sent in my first post...
    I have tested this SATA config with a WD 80G and 120G IDE HDD and they work perfectly.
    I have also tested the WD 250G IDE HDD on another 'IDE' system and it too is working as it should.
    What can I do to get this 250G IDE HDD to function on a SATA setup?
  • 2,351 Answers
You must have added the SATA drive after setting up the IDE. If both drives are using the same os this will not function. Ony one drive can have the os on it. All SATA's are seen as a master.
To correct this problem, disconnect the IDE drive. Hook up the SATA drive. Again if the SATA has the os on it everything will run. Change the jumper on the IDE and set it as a slave. Hook the IDE up. Enter the bios & do not list the IDE in the boot to section. Problem solved. While in windows, format the IDE drive.
You do not want windows thinking you want a dual boot system.
So you understand, in the bios -boot settings this is how things should be listed.
Boot device 1 Sony Optiarc DVD drive
Boot device 2 WD raptor SATA, In-stall your os to this drive
Posted on Mar 23, 2008
  • Mike Peluso
    Mike Peluso Mar 23, 2008
    Your SATA controller is functioning other wise the Sony Optiarc SATA DVD drive would not work. If your operating system was installed onto the IDE drive, just remane the boot.ini file. Install windows on the SATA drive, (fresh install). When finished copy your data from the WD IDE drive to the WD raptor SATA drive.
    Have any more questions, feel free to ask.
  • Mike Peluso
    Mike Peluso Mar 24, 2008
    Ylum, your WD2500BB WD Caviar - 7200 RPM needs to be checked with WD's Data Lifeguard Tools 11.2 & or Data Lifeguard Diagnostic for Dos floppy or CD. Download these tools from the link below.
    Pick WD Caviar - 7200 RPM from the left column & pick your flavior from the right column as noted from above. Your WD was the cause of your troubles from the get-go. In order for this not to harm windows follow these simple steps.
    1. Disconnect (just unplug the data cable from the SATA hard drive).
    2. Set your WD drive's jumper as a single master drive.
    3. Use a seperate 80 pin IDE data cable plugged into the primary IDE slot on the motherboard.
    4. Disconnect the Sony Optiarc SATA DVD drive's data cable only.
    5. Set your bios to boot only the WD drive, save & exit.
    6. Boot to Data Lifeguard Diagnostic & check the drive for errors. WD's software should be able to repair any problems.
    7. Boot to Data Lifeguard Tools 11.2 & setup the WD drive.
    8. Shut down the PC. Reconnect both SATA data cables.
    9. Change the boot order.
    1st boot device floppy
    2nd boot device SATA DVD drive
    3rd boot device SATA hard drive.
    4th boot device (not needed or you choose.)
    This should take care of the problems for both windows & the WD drive. One suggestion. Format the WD twice, one quick & one full. Catch a show on TV while it formats in full mode.
    If the WD gives you more troubles (Shoot it)! Next time buy Seagate. Can't beat the five year warranty. (Never buy a Maxtor).
    map & Mike are the same person.
    Let me know if things work out!
Computer wil not boot
You can get a manual here:
Check the bios settings.
Where it boots from.
Maybe your harddrive has a defect.
Try even to press F8 and go in failsafe mode.
And choose the last configuration where the system worked.
Just to if there is a problem.
Good luck.
Feb 24, 2011 | Abit NI8-SLi GR Motherboard
I have a abit 1c7g motherboard intel 3.2ghz processor twin western digital raptors sata raid 0 config ... 1 sony dru 710a on ide 1 (slave) trying to install plextor 880sa dvd burner having conflict with...
Suggest you connect the plextor to the SATA port 3 and set it's jumper to Master. All SATA drives are seen as Master drives. (Check the serial number on your WD SATA drive "Primary".
Enter the bios menu. Within page 3-7 section 3-3 Advanced bios features. Check, 1st, 2nd and third boot devices.
Floppy disk drive as, 1st boot device. 2nd boot device, "Primary WD SATA port 1". 3rd boot device, CD-ROM drive SATA port 2, Plextor 880sa drive". Save and exit the bios. If you no longer have you're manual you can download it from the link provided below;
Check page 3-13. See OnChip serial ATA Mode. As noted, the RAID option is available when the item "OnChip serial ATA" is set as [Enhanced Mode].
Jun 27, 2010 | Abit IC7-G Motherboard
Optiarc 7240 sata
Try updating the Bios , it should work . U can also update the Firmaware of the Drive using this link
May 10, 2010 | Sony Optiarc AD-7240S 24x DVDRW DL SATA...
If I bought a SATA dvd drive, where would I connect it to? Does it take SATA dvd, or does it still need to use IDE only?
This MoBo has 4 SATA connectors. Assuming you have one or two hard drives just plug it into one of the spare ports. If you are unsure, carefully follow the data cable from a hard drive to the MoBo to find the ports.
Nov 28, 2009 | ASUS A8N-SLI Premium Motherboard
2nd sata connected and xp won't boot
It seems you have not made the second SATA the slave of first SATA. You'll have to fix the jumper pin in the designated slot to make the second SATA the slave. a1d66e3.jpg
Jul 07, 2009 | ASUS A8N32-SLI Deluxe Motherboard
My abit fatality aa8xe mobo will not recognize/find my WD 150gb Raptor when installing winxppro! I need the .inf files to slipstream into the install disks for that mobo. please help!
did you try to verify that the WD HDD is the culprit. try external HD enclosure, or much simpler try the WD on other PC transfer the inf to usb.
Jul 06, 2009 | Abit Fatality aa8xe (MBFAA8XE) Motherboard
SOYO KT600 Dragon Plus mobo not recognize WD Caviar SATA 1TB HDD
Yuck! Soyo filed for bankruptcy in May and their website is gone!
You need to enable the SATA in the rom bios AND install the drivers for it; but, I hope you have the manual and the CD.
Jul 05, 2009 | Soyo Computers & Internet
Installing windows xp with 2 new sata wd 150g 10k 16m raptors to NO avail...
I guess you are trying to install Windows XP in RAID 0 configuration. If so, you need to do several steps:
1. Configure the bios to work as RAID 0
2. Download the RAID driver from the mobo vendor site, copy it onto a floppy disk and have it ready for when Windows asks for it.
See this link for detailed example
In SATA there is no master/slave configuration, so there is no need for jumpers.
I hope this answers your question.
Dec 26, 2007 | Western Digital (WD1500ADFD) 150 GB Hard...
Computers & Internet Logo
338 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
