Question about Panasonic PT-51HX41 51" Rear Projection Television
Long warm up time
It takes about 20 - 30 minutes for tv to get a decent picture after turning on. The poor picture is wavey and has black lines.
  • linkoy88 Oct 09, 2008
    poor picture when t.v set is turn on after few mins. it will be ok
  • Panasonic Master
  • 8,617 Answers
You have a bad capacitor in the deflection circuit.You will need some diagnosing and testing to find which one. An ESR meter will make short work of that but they are expensive meters.
Posted on Mar 22, 2008
SOURCE:
Picture and remote problem
Contact the authorized service center. Your TV need a though check-up. Gopakumar Gopalan Google
May 18, 2014 | Sanyo DP46849 46 in. HDTV
Horizontal wavey lines in projection TV picture
what brand? could be a ground problem or bad crt
Aug 22, 2009 | Televison & Video
Plasma "warm up" is now up to 30 minutes and climbing
put a towel across the top of the tv so it can heat up faster and you will get your picture. be carefull!!
Jan 26, 2009 | Televison & Video
Wavey lines
Sounds like your set has dried caps in the Power Supply, take it to a decent tech, its not something you should try to do yourself as dangerous voltages can still be present evn if the set is unplugged.
Jul 25, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Have Westinghouse 32"LCD TV. When its very hot and humid after being on for approximately 30 minutes black, heavy vertical wavey lines appear on the screen. Sometimers I can make the lines disappear...
I had the same problem these LCD TV's are designed poorly and have very little ventilation my warranty was up so i took it apart and installed cooling fan have no problems what so ever now.
Jul 17, 2008 | Televison & Video
Wavey picture
Zebra19. This problem is a common occurance in these sets. So common that there is a service bulliteen to service centers on it. Fixing it is not easy though. It ivolves 11 very very small micro capacitors. on what is known as the hypermodule. In an ideal world replacing the hypermodule is the best course of action. but.. these are almost impossible to find. if you are very good at soldering and have a lighted magnifer and very small twezzers it can be fixed. but if you damage the board....... i have done this repair about 6 times.. replacing them is what need to happen. 11 10 microfard surface capscaae315.jpg this is the hypermodule ... it is a board in a sheilded can that plugs in behind the input termals in the back. kind hard to get too. the caps are the small circular components that you see with the red and black marks on it.
willie at fordtv.com
May 19, 2008 | Toshiba 57H81 57" Rear Projection...
57h82 toshiba projection tv
Hyper board bad = No longer available part # 23148024 PTS
rebuild only...send core in........57H82..............................T.
Part # is specific to model !....
Mar 20, 2008 | Toshiba 50H82 50" Rear Projection...
Blue screen of death on a tv??
this could be three differnt things
1. the crt itself could be bad
2.the vertical ic on the crt board
3. the focus pack or focus block
Sep 19, 2007 | Sony KP-53V45 53" Rear Projection...
The TV turns on and you can hear the sound but the picture is dark except for a thin line of blue dots in the center of the screen.
You have whats known in the biz as a cold solder connection on the vertical output IC or on the associated components. Not a job for the handi-man unless you know the issues with safty, and precautions to take with Hi voltage inside of tv sets. Shouldnrt cost much for the local shop to find your problem . Now on rare occations the poor connections are inside the IC and the IC has to be replaced. Good Luck
Jun 17, 2006 | Panasonic CT-25G6 25" TV
Panasonic PT-51HX41 51" Rear Projection Television Logo
198 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
