Question about Hotpoint Ultima WD72 Front Load Washer/Dryer
Hotpoint washer dryer ultima 1200 model WD71S
When the door is shut i still get the message saying to shut the door even though it is shut
  • thelm Jun 16, 2008
    The problem was the door lock. i actually found a manual on line that showed that most pieces in a washing machine are just plug in,i purchased a new door lock for £13 including p&p, it was a matter of removing the lid, undoing 2 screws, unplugging the old lock plugging in the new lock and putting back together, it prob only took 15 minutes was alot cheaper than a call out charge even if it had not worked.
    Problem Solver:
  • 12 Answers
Most like cause is the door interlock is faulty but its one of those jobs that unless you have the right equiptment namely a tester you won't know for sure unless you change it. Could also be the voltage from the control board is't correct so best let someone who knows check it for you.
Posted on Jun 15, 2008
Hi My hotpoint washer dryer 1200 ultima has a door fault , saying close door when in fact the door is shut, i have attempted to replace the door lock, but i cannot get the front drum seal off, there seems...
The cap should be just a cover cap. A circle cap with two prones opposite of each other. Try and get a knife and slide it around till you find the connection prones press in and poof should pop out. All it is is a precaution to prevent water from corroding the screw. You should also beable to buy a replace ment very cheap if you happen to break it. Hope it helps. Let me know what happens
Dec 22, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Looking for a door seal for a Hotpoint Ultima 1200.
If you have not yet got door seal, then go to www.hotpoint.co.uk.
Please rate my solution.
Thanks.
Jul 09, 2009 | Hotpoint Ultima WD72 Front Load...
I have a hotpoint aquarius ultima 1200 wm 72 but no users handbook where can I get one from
Goto;
www.hotpoint.service.co.uk
In the drop down list on left click on-----------hotpoint manuals , user guides, handbooks.
In the search box type in your model number, and download instructions.
Plz rate my solution.
Thanks.
Jan 15, 2009 | Hotpoint Ultima WD72 Front Load...
E30 error code
Error E30 is a motor drive problem. Would check motor brushes as most likely fault.
Thanks for using Fixya.
Dec 16, 2008 | Hotpoint Ultima WD72 Front Load...
I have an e15 code on the lcd display
Are you sure it is E15 and not F15?
F15 on an lcd display washer/dryer indicates dryer element faulty. this being the case then it will probably require a new element fitting.
Hope this helps
Dec 05, 2008 | Hotpoint Ultima WD72 Front Load...
HOTPOINT WD71 ERROR E 30
Hello john walker24
Welcome
You said, you have a Hotpoint Ultima 1200 Washier dryer model WD71s and keep getting an E30 error code after it fills with water.
Any idea what the problem is?
This is what Hotpoint tells us!
E30 = A motor drive problem has occurred.Try running the programme again.
If the problem persists call for a Service Engineer.
BUT, I will tell you to unplug the appliance for 5 minutes and see if this resets the system and solves the error code.
Sometimes it is only a glitch and you can reboot and be alright if there is really no mechanical failure!!
Let me know how it goes?
Huuum,
Please remember to leave a rating!
Thank You.
Waiting for your response!
Oct 01, 2008 | Hotpoint Ultima WD72 Front Load...
Hotpoint WD71s
The e30 error code relates to motor drive problem. Open the service panel and look for a broken belt and does the motor spins. Let me know with your results if you will need for further assistance. Good luck!
Sep 08, 2007 | Hotpoint Ultima WD72 Front Load...
Hotpoint Ultima WD72 Front Load Washer/Dryer Logo
146 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
