RCA DLP HD50LPW166 Works fine for 15sec
My DLP turns on fine, looks and sounds good, then after 15 sec. the picture dies and the power button flashes 5 times. Then the picture slowly comes back for another 15 secs and repeats. I've pulled the lamp out and checked everything and blew it out with some air but it wasn't really that dirty. (its only 18mon old) I di hear the wheel turn on when the picture first comes on.
Will a Lamp really fix it? Its seems the lamp work fine for a quick period.
  • Anonymous Apr 27, 2009
    the power light blinks 5 times and then restarts for a few seconds an then repeats
Same Problem here. After some investigating and speaking with one Lamp supplier they told me to replace the Lamp Ballast first (this is mine EUC 120 P/H11 9137 008 09405). I found one on Ebay. Since this may also wear out the bulb, I may have to replace that also. If I can get my TV working (HD50LPW166YX6) for around $150.00 for both, I'll be happy even if i get only 6 month of use out of it. Did I mention the TV was free? :o) Hope this helps.
Posted on Jan 05, 2010
SOURCE:
Flashing green light
I have a mits. 82738 tv which would shut off after 20 minutes when first turned on .
Loose sound and picture.
Looked up error code in service manual and it said the lap was the problem.
Replaced lamp and now it works fine and the picture quality is great.
Jan 20, 2014 | Mitsubishi WD-82738 DLP TV
I have a 50" Phillips
Check ur owner manual or call Philip support Tech. ask it this tv model have a colors wheel design into it tv.Not sure for a Philip model tv 50" DLP tv,but the Samsung model 50" DLP tv this problems alway causes by a dying colors wheel that design into it tv.Which the colors wheel it is warp worn out and spinning off of it motor mount axis to cause grinding noises and tv colors to mess up and flashes or have flashes Black & White within it picture.
Jun 07, 2011 | Philips 50PL9126D/37B 50" DLP TV
I have the same problem on my rca serial# hd50lpw166
It seems more to be an issue with your ballast, of course this is if you replaced the lamp before, but regarding the clicking sounds it's most probable to be your ballast. discountdashmerchantdotcom, the ballast aren't that expensive, they're around 60 dlls
Jul 23, 2009 | RCA HD50LPW175 50" HDTV
My samsung dlp has no picture or sound. Model hls5066wx, power comes on lamp light flashes for 15sec and then the standby lamp comes on then it goes back to the lamp light flashing. It repeats this a few...
hi first of all u should check ur transistor connections.Check your Horizontal and vertical output transistors.You should also check the horizontal and vertical yoke connections as well as your low voltage regulators.... if any of these got damaged u should purchase a new one.. but try to purchase with the help of a tv service assistant...
thank u!!!
rate me
Jul 12, 2009 | Samsung HL-67A510 67" DLP HDTV
RCA SCENIUM HD50LPW166 worked fine, then "POP!!" has power
you lamp is bad. even if it looks good, its not firing (you're seeing the spark gap fire, indicating this). the lamp is customer replacable and roughly $200. the 5 blink error is a general shutdown error
Dec 08, 2008 | RCA HD50LPW175 50" HDTV
My HD50LPW166 will not turn-on...
unfortunately all of these types of tv's are failing from poor craftsmanship , poor quality components , thus leading to inevitable break down ( just poorly made) if you want some technical info just click helpful and leave a note . I can help determine the cause if you want to get into the tv , otherwise you will need to call a repair shop to get it fixed
thanks for using fixya!
electech
Oct 19, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
My RCA Scenium 50in. is not turning on!!
Its sounds as if the lamp has exploded or the color wheel has. I will post a link to a site that has a trouble shooting manual on CD called RCA DLP Disc #1 which covers every DLP in the ATC line which is what your model is. They have it either in cd form or they will email it. Its a very good resource for fixing your own set.
http://servicemanuals.vstore.ca/
Jun 16, 2008 | RCA HD50LPW175 50" HDTV
RCA DLP SCENIUM HD50LPW166 NO PICTURE OR SOUND
let me know the model number of your set and I should be able to help you out with it, as the ATC dlp chassis have different things that goes wrong but I should be able to help you out as RCA DLPs are my favorite to diagnose.
May 21, 2008 | Televison & Video
52 RCA DLP 1080P Television with NO picture and buttons flash
IF you would like help diagnosing your set. Go to the enclosed link. They have the service manual for your set and offer unlimited chat support for only 29.99. Just click on your sets manufacturer and you will see your model. Then click on the contact us link and provide your email address and they will email your manual and instructions on how to obtain your support. I am one of their techs. This manual contains step by step procedure for troubleshooting Your RCA DLP Light Engine
Dec 30, 2007 | RCA HD61LPW175 61" Rear Projection HDTV
Televison & Video Logo
226 people viewed this question
Top Televison & Video Experts
Ekse
