Trying to print
Ok I intalled it on my computer not sure if i need ro reinstall or not but I get as far as pushing the print button, the a box pops up and asks me for fax information, not sure, what to do here.
  • 3,587 Answers
Hmmm..are you trying to print or fax?
Posted on Mar 22, 2008
How do i stop my windows intaller trying to install symantec antivirus msi file
Step 1:
Stop Windows Installer From Popping Up b> The older a computer gets, the more junk it accumulates. A great number of computers out there don't start up without a thousand things popping up demanding your attention. Windows Installer is one of the more notorious pop-up offenders for Microsoft users. Stopping these pop-ups can prove challenging, however, there is a way.
On your computer's desktop, click on the "Start" tab, typically located on the bottom left of the screen (in Vista it may be the Windows symbol rather than the word "Start"). Now locate and click the program titled "Run." Vista users can locate this program by typing "run" in the search box at the bottom of the "Start" menu. Once "Run" is open, type "MSCONFIG" into the empty box and click "OK." This will open the System Configuration Utility. With the System Configuration Utility open, select the tab labeled "Services." Scroll down the list of services (it may be beneficial to click the "service" column to sort the services alphabetically) until you find the "Windows Installer" program. Now click the check box beside the Windows Installer name and click the "Disable" button at the bottom of the System Configuration. Congratulations, you have stopped "Windows Installer" from popping up!
Feb 06, 2013 | Acer TravelMate 4150LCi Notebook
Brother MFC 465CN won't print due to "Unable to
Hi Good day!! try this method
1.pull out the AC plug
2.put back the AC plug while holding down the "menu" button and keep holding it (15 sec) you are entering the MAINTENANCE mode and "error 46" pops up in the display 8 by using the arrow buttons ,push OK and select 0 and push OK
5.00:00 00:01 OK (the display is showing this message) push the MONO button 25 times until you see PURGE: xxxxx
7.Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
8.the purge counter indicates now: purge: 00000
9.switch off the printer ,switch it on
ready to print
Nov 19, 2010 | Brother Office Equipment & Supplies
I have MFC-790CW. Just changed all color ink cartriges. Now I get an error message 'Unable to clean 5A'. Help !!!
Basically your waste ink container is full. You can reset it but risk the chance of overflowing the waste ink, which would be very messy on your desk, if you don't actually clean it out. As far as that goes, you have to dis assemble the machine and manually clean out the ink as far as I know, good luck.
Here are some generic reset instruction I found for similar models.
- pull out the AC plug
- put back the AC plug while holding down the “menu” button and keep holding it (15 sec)
- now you are entering the MAINTENANCE mode and “error 46” pops up in the display
- select 8 by using the arrow buttons ,push OK and select 0 and push OK
- 00:00 00:01 OK (the display is showing this message)
- now push the MONO button 25 times until you see PURGE: xxxxx
- Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
- the purge counter indicates now: purge: 00000
- switch off the printer ,switch it on
- ready to print
The only remark is that your waste ink box is too full with ink. Ink flooding might be happening……
and this
· Machine off
· Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
· Press 80
· Press the “mono start” button several times until you see “purge: xxxx”
· Press “2783” in order to reset the purge counter. You will see: “purge:0000”
· Press the "stop" button.
· Press “99” to exit the maintenance mode.
Mar 23, 2010 | Brother MFC 490cw Color Inkjet...
Can't print from computer
Reinstall the printer drivers. (completely remove the old ones first)
Try new drivers from HPs website if need be.
Check the print queue in control panel>printers to make sure nothing is lying in the print queue and blocking your printing.
Make sure that you are printing to the correct printer in the "print" dialogue box that pops up when you go file>print. Sometimes this can revert to "microsoft document printing" or somesuchand just save a file on your hard drive instead of printing (in techie speak, printing does not necessarily mean print out on a bit of paper). Or may the "Print" dialogue box wrongly is pointed at another/old printer that still has drivers installed on your pc when it pops up, check before clicking the "ok" button..
If not, try a new cable, if not, call HP.
Feb 05, 2010 | HP PSC 2175 All-In-One InkJet Printer
The waste ink absorber for canon i9900. please help
you can change ink absorber. if not ,you can change this boxe,s absorber sponge in same size. it workes is absorber wastage ink of printer. thank (nepal)
Jun 28, 2009 | Canon Pixma iP6000D InkJet Photo Printer
Intalled the downloaded Photo 926 AIO driver. When printing any document, the print status box goes to 99%, but then states document failed to print. Have gone through all ''troubleshooting'' steps on...
I am trying to solve the same problem. I can get the document to print if I go to Administration tools then Services Locate Printer Spooler and right click, then select Proporties. The spooler dialog box will come up. Near the bottom "click" the Stop button to stop the spooler. Then click the Start button to restart and my documents will print. Just can't figure out why it needs a restart of the services every time a new print document is sent.
Mar 28, 2009 | Dell Office Equipment & Supplies
Lexmark x3550 will not scan 'Downloading Application List" and "
Had the same problem. Installed the most recent drivers. OK now. Good luck. - Kakou
Feb 05, 2009 | Lexmark X3550 All-In-One Printer
Printer does not work
go to hp support site and make sure you are using the latest drivers for that operating system... which version of windows are you using?
Feb 01, 2009 | HP Photosmart C3180 All-In-One InkJet...
Pixma 4200 compatible ink cartridge problem help
The ink detection is a critical function of the printer.
Ink actually acts as a lubricant for the heads, and running (Printing) without ink is equavalent to driving a car without oil.
I.E. It will seize eventually....
Hopefully you didn't print much without the ink, and your heads are still in good shape...
Here is a chip reset procedure....
With the original chip now attached to the compatible cartridge (you may need double sided tape to get the chip to stick well to the cartridge), and with the cartridge now in the printer, Press and hold the Reset/OK Button for 5 seconds to reset the chips.
  1. The "Ink Low" dialog box will pop up (similar to photo 1 below)
  2. Continue to print until the "ink has run out" dialog box pops up (similar to photo 2 Below) Click "OK" to continue to print.
  3. The "Ink Low" dialog box may reappear, if so repeat the first 2 steps
  4. Then the "once empty" dialog box will pop up (similar to photo 3 Below) Click "Yes" to continue to print
  5. The "Not Liable" dialog box will pop up (similar to photo 4 below). Click "Yes" to continue to print
  6. Continue to print until the "remaining level of ink" dialog box pops up (similar to photo 5 Below) Click "OK" to continue to print
  7. Another dialog box will pop up with the "press and hold the Resume" or "press and hold the Paper Feed" button (similar to photo 6). Press and hold the "STOP/RESET" button (for Canon MP Series) or "PAPER FEED" button (for Canon IP Series) for 5 seconds. DO NOT Click "Back" or "Cancel Printing"
  8. The "Ink Monitor" dialog box will appear and the printer will continue to print. (similar to photo 7) In the event that that the "press and hold the Resume " dialog box pops up again, Press and hold the Paper Feed Button or Stop/Reset Button for 5 seconds
Feb 05, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
No color prints
When you tried to print, did you press the button for black or color? Either one of these will be the start button. If you hit color and it still prints in B&W, the other solution is to the pop-up box should come up then you click on advance options. file-print --then click on preferences just below your icon list of printers. Two pop-up boxes will appear. close the smaller one (I want to...), and the other box should stay open. You will see on the lower right corner the box to check off for "print color images in black & white. Make sure the box is unchecked. then click ok, and print.
Dec 11, 2007 | Lexmark X6170 All-In-One InkJet Printer
32 people viewed this question
