Question about Sony FD Trinitron WEGA KV-24FS120 24" TV
1998 Sony Trinitron 32"Receiver
I am hooking the unit up to an outside VHF aerial and do not know which connection to attach to at the rear of the unit.
    Sergeant:
    Champion:
  • 301 Answers
VHF
Posted on Mar 29, 2008
Can i attach headphones to my sony wega tv
One may connect headphones amplifier here:
TV Rear Panel
hope these helps,
thanks for choosing Fixya for assistance!
Aug 15, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Hi, I am perplexed. I have a Sony KD-FS32170 model television. I just bought a Panasonic receiver to attach to my Sony along with four Bose speakers I already had. Unfortunately, I discovered there is no...
Hi
This tv should have one or two 21 pin scart connector;s on the back, using a scart to rca (phono) adaptor you should be able get audio out, and this can be connected to your sound sty. note the level will be fixed not dependant on the volume setting. Hope this will help regards Derrick
Aug 21, 2011 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony Trinitron KD-28DL10U switched off suddenly to standby mid programme and won't come back on.When trying the remote on I can hear it click on and immedietly off again.Switched off at set and socket and...
Hello
In time as the Sony Trinitron ages it begins to have power issues. While this can be true of most tube televisions it's the rate and severity at which this happens to Trinitrons that makes it particularly of note. Many Trinitron owners have complained of the Trinitron set turning itself off randomly and frequently. Some sets have failed to stay on for longer than a few minutes at a time. Eventually some sets will not turn on at all. These problems grow more severe with age.
Check the power cable running from the Sony Trinitron 32. Make sure the cable is completely inserted into the power connection on the rear of the TV as well as the local power outlet.
Disconnect the power cable from the electrical outlet, then plug it into a different connection. It is possible to electrical outlet has died, forcing you to obtain a power current from a different source.
Check the cable connection running from the cable/satellite receiver or VCR. If the TV is on but no picture is on the screen, the problem is most likely due to a connection issue.
Power off the cable/satellite receiver, then press the "Video" button on the remote control to switch the Trinitron 32 to the video input signal. Turn on the cable/satellite receiver and the programming now loads onto the television screen.
Nov 21, 2010 | Sony FD Trinitron WEGA KV-34HS510 34" TV
I have a 32 in sony trinitron and i do not know
You need a matching transformer, or 'balun'.
Any home electronics store will have these. $3-$5.
Now, if this TV does not have a cable connector on the back, there is a good chance you will not be able to receive many of the channels (not a cable-ready TV).
Jan 11, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
We have a Sony Trinitron and a Sony STR-K670P. We use to have it hooked up to a DVR, but now we went down to basic cable. I can't seem to get sound to come through my surround system. Any advise out there?...
if your trying to use the dvr still your probably not connecting it all properly. make sure that. having a sony trinitron you have alot of connections on the back. if you connect all of the accessories that you have on your tv directly into each input and use the tvs main output connection to connect straight to your surround sound. this should fix your problem. plus you wont have a bunch of stuff hooked up to your surround sound receiver
Feb 21, 2009 | Sony Audio Players & Recorders
Hitachi ax-m136u aerial outside
Hi What you probably need is a line transformer.
If you have 300 ohm "twin lead " from outside and the receiver has coax , you need a 300 to 75 ohm transformer.
If you have a coax coming in to 2 screw terminals on the receiver , you need a 75 ohm to 300 ohm transformer.
Some place like Radio Shack or a stereo store would have them.
Jan 22, 2009 | Audio Players & Recorders
No colour when digital set top box attached
Ensure the set top box is set to the correct video out. Probably RGB if scart lead or CVBS if coax lead.
Jun 10, 2017 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a CXSGT08HP sony car stereo. It was installed by a friend at home. The memory does not work. Can you tell me which wire is the memory wire and were i need to hook it up to?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}Hi Justtamera,
I’m attaching a wiring diagram which hopefully isreadable. I’ll also list the “where to”instructions for all of the other wires. It’simportant that several wiring steps be done in a particular order.
About the Memory Wire:
The memory wire is Yellow and should be connected to the +12 V power terminal (which isenergized at all times). First besure to connect the black ground (earth) lead to a metal surface of the car.
Important…
>>Before making connections, turn the stereo unit and carignition off to avoid short circuits.
>>Connect the yellow and red power input leads onlyafter all other leads have been connected.
>>The power antenna (aerial) control lead (blue)supplies +12 V DC when you turn on the tuner.
Hope this helps. Lemme know if you have more questions or would like me to email you acopy of the owner’s manual.
Thanks, and take care.
Gail :-)
Connecting the Sony CXS-GT08HP Car Stereo Unit
1. To a metal surface of the car
>First connect the black ground (earth) lead, thenconnect the yellow and red power supply leads.
2. To the power antenna (aerial) control lead orpower supply lead of antenna (aerial) booster amplifier
>Notes
>>It is not necessary to connect this lead if there isno power antenna (aerial) or antenna (aerial) booster, or with a manually-operatedtelescopic antenna (aerial).
>>When your car has a built-in FM/AM antenna (aerial)in the rear/side glass, see “Notes on the control and power supply leads.”
3. To AMP REMOTE IN of an optional power amplifier
>This connection is only for amplifiers. Connecting anyother system may damage the unit.
4. To the +12 V power terminal which isenergized in the accessory position of the ignition switch
>Notes
>>If there is no accessory position, connect to the+12 V power (battery) terminal which is energized at all times.
>>Be sure to connect the black ground (earth) lead toa metal surface of the car first.
5. To the +12 V power terminal which isenergized at all times
>Be sure to connect the black ground (earth) lead to ametal surface of the car first.
Important…
>>Before making connections, turn the car ignition offto avoid short circuits.
>>When your car has built-in FM/AM antenna (aerial) inthe rear/side glass, connect the power antenna (aerial) control lead (blue) or theaccessory power supply lead (red) to the power terminal of the existing antenna(aerial) booster. For details, consult your dealer.
>>A power antenna (aerial) without a relay box cannotbe used with this unit.
Nov 29, 2008 | Car Audio & Video
Sony trinitron XBR2 32 " can't seem to get the cable working on it
You can hook up to either aux or vhf not converter. then with remote use ant button to select the one you are connected to. then do the auto search. Also can you get to 3 by pushing 3 and ent on the remote?
May 18, 2008 | Televison & Video
Sony Trinitron XBR
VHF/UHF works for me. Make sure the game/tv/video rtc tab is correct
Dec 23, 2007 | Sony KP-51HW40 51" Rear Projection...
Sony FD Trinitron WEGA KV-24FS120 24" TV Logo
32 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
