Error code 7 - EcoSmart Washer - Fisher and Paykel
Washer stopped working just recently. Only the last 3 lights are lit in the Wash Progress panel. Looking on the site I didn't find an error code 7.
It seems that before it beeps and quits it is filling the drum and draining at the same time but never filling the tub.
Please advise as to what needs to be done to get this fixed.
Thanks,
Randal
  • 1294dahl Mar 23, 2008
    GWL10US ROW
    Prod Code 96167
  • 1294dahl Mar 24, 2008
    I have tried your suggestios for the following:
    If Washer does not work but it does make noise:
    none of these have helped or located a problem.
    I am waiting to rate your solution because it was incomplete. I had to spend over 3 hours on applicanceguru.com to get an idea of what my parts looked like and where they were located.
    Your site is good but not for the Fisher and Paykel washer.
    Do you have any other ideas?
    Genius:
  • 3,422 Answers
HI,
If no water is entering the wash tub:
If Washer does not work and makes no noise :
  • Check that the water supply valves are turned on
  • Inspect the filter screens
  • Test for overheating
  • Inspect the water pump
  • Test the water inlet valve
  • Test the motor
  • Goodluck,
    Please don't forget to rate the solution
    Posted on Mar 22, 2008
    • Priya darshan Mar 25, 2008
      Hi again,
      You can get the parts from HERE
      You can download the Manual from HERE
      The manual is in pdf format.So you will need Adobe reader to view it.If you don't have it you can download that from HERE
      Further you can get more troubleshooting steps and the contact info of Fisher & Paykel from HERE
      Goodluck once again...
    • 1,512 Answers
    Hi there, what is the exact model of you washer?
    Washing Machine stopped through cycle and now will not turn on
    Check the wiring harness, connections, contacts, etc. Look for some corrosion and loose connections. Also, check the water inlet for anything that may cause a reduction in water flow.
    Dec 02, 2007 | Fisher Paykel EcoSmart GWL15
    Tip
    Decoding Fisher & Paykel Electronic Washing Machine Fault Codes
    The Fisher & Paykel Smart Drive and EcoSmart electronic washing machines are equipped with fault detecting software to help easily determine the cause whenever a problem occurs. Not like other electronic washing machines, these ones do not have displays to flash the code, but rather use the eight (8) light-emitting diodes (LED) of the Wash Progress indicators to indicate the fault code. The eight (8) LEDs stand as an 8-bit binary number (zeroes and ones) that must be decoded and then converted to the decimal number system to get the fault code.
    The fault code can be decoded by determining which Wash Progress LEDs are lit. Once determined which of the LEDs are lit, write down the 8-bit binary code; 1 for lit LEDs and 0 for the off ones. For example; the final wash, rinse, and spin LEDs are lit; the binary code is 00001101. This in turn can be converted to the decimal number system by multiplying each digit with its corresponding place value then adding up the result. From left to right, the place values are 128, 64, 32, 16, 8, 4, 2, and 1 respectively. Therefore, the decimal equivalent of 00001101 is 128(0) + 64(0) + 32(0) + 16(0) + 8(1) + 4(1) + 2(0) + 1(1) = 8 + 4 + 1 = 13; the fault code is 13 which is a pump fault.
    Once the code is determined, search the web for the meaning and indicate it when requesting for an online assistance to facilitate a quick and precise response.
    on Apr 14, 2010 | Fisher and Paykel GWL11 Top Load Washer
    Fisher and paykel smart drive 608 6.5 kgs has running well for ages but recently while finishing water filling it makes a warning beep sound and start leaking from the bottom,anyone there to help me pls
    Hi just read your post.Now when the machine beeps a series of lights will light up on the wash progress lights. The spin light is number 8 and the other end of the lights is number 1 which is long wash, i think. Starting from the long wash light which is number 1, which lights are on when the machine is beeping, is it 1,4 and 7 or 3, 7 and 8 etc? Please reply with the answer to this question and i am sure i can help you. Regards Lu
    Jan 25, 2014 | Fisher and Paykel Fisher & Paykel Washer
    Fisher paykel washer. turn on 3 progress lights up only, cannot switch off power button. When off the lid lock red light is on
    this is a fault in the motor controller fault. the fault code number is 140. it may have a problem with the motor windings / RPS also. you will need parts from F+P.
    Nov 12, 2013 | Fisher and Paykel IWL12 Top Load Washer
    My fisher and paykel gw708u is intermitantly filling then goes into alarm and stops
    Your rotor position sensor could be faulty,
    your error code should be on the wash cycle progress lights.
    Nov 18, 2012 | Fisher and Paykel Fisher & Paykel Washer
    Our FnP GW611 while filling the water stops and starts and after a short time it stops and beeps and the long wash and spin lights come on orange. Any ideas? Thanks
    The problem can be determined through the Wash Progress LEDs. The specific lit LEDs combination indicates an specific error code that tells what generally the problem is. But the exact positions of the lit LEDs are necessary in determining the exact code. Refer to the illustration below and post back the code or the exact positions of the lit LEDs. You may Google for the error code once you determine it, like "Fisher and Paykel Fault Code 37".
    Aug 20, 2011 | Fisher and Paykel GWL11 Top Load Washer
    Fisher and Paykel, EcoSmart with lid lock. After initial fill, all wash lights go out, advances to rinse, then beeps continuously. Have to shut machine off and start over. Continues to wash, but leaks...
    Fisher and Paykel, EcoSmart with lid lock. After initial fill, all wash lights go out, advances to rinse, then beeps continuously. Have to shut machine off and start over. Continues to wash, but leaks out of top panel under lid. Machine is level. Any Suggestions?
    Jul 28, 2011 | Fisher and Paykel WA37T26G Top Load Washer
    Will not spin
    Some of the Wash Progress LEDs flash when the machine stops due to a fault. The 8 Wash Progress LEDs stands for the binary digits and by indicating the digits, the fault code number is determined. The fault code can be shown by activating Diagnostic Mode if none of the Wash Progress LEDs are lit.
    Turn machine OFF on the control panel then hold down the Water Temp Down button and press the POWER button until the machine gives 2 short beeps and lights up. Release buttons and you are in Diagnostic mode. Press the Spin Speed Up button 3 times until the Hold and Slow LEDs are lit. Write down the LEDs which are lit across the Wash Progress LEDs and post it back.
    You don't have to accept or reject and rate this post to add information or post comments and follow-up questions should you need further assistance. But accepting the solution does not stop you from communicating with the expert. You may continue communicating with the expert as long as you need assistance regarding your concern stated herein.
    Sep 07, 2010 | Fisher and Paykel GWL11 Top Load Washer
    Fisher Paykel ecosmart purchased 3-4 years ago.
    I too am having this problem.  I am checking out if anyone has a solution.  Somewhere someone said to change the "Fill switch"  I don't know what that is or where it is.  Does this help?  If you have found anything let me know. monica.roberts@usa.com
    May 23, 2008 | Fisher Paykel EcoSmart GWL15
    Washing Machines Logo
    202 people viewed this question
    Top Washing Machines Experts
