Question about Panasonic PT-51G44 51" Rear Projection Television
Expanding picture
I just had my 51" panasonic projection tv repaired few days ago, the next day it started it again the same problem. The problem is the picture expands were the top and the bottom goes past the viewing part of the tv. the part that was replaced is a transformer integrated high voltage. now i have also a CHK 11f5d in the upper left corner.
Thanks Sean
    Genius:
  • Panasonic Master
  • 1,689 Answers
Call the service rep who did the work. They replaced the failed parts, but did not find the original cause of the failure. You should tell them that! Replacing the parts without finding the original cause will only cause the present work done to fail again.
Jerry G.
Posted on Apr 12, 2008
The picture on my 13 yr old panasonic PT-51G44 ia darkening. Is this fixable or do I need a new tv?
Yes,the tv is fixable.When was the tv projection lamp been inside this tv was replaced in this tv,when was it the last time the bulb was replaced?The last time the probjection lamp was replaced about 1 1/2 or 2 years ago?The tv on an used at leat 4 or 5 hours a day?The projection lamp life is over.Require a new projection lamp.
Aug 02, 2010 | Panasonic PT-51G44 51" Rear Projection...
Tv goes off after about 5 seconds
Bulb replacement is a good try, I would also have them come out to look at the set again as I am sure there is some kind of warranty on the parts.
Apr 17, 2010 | Toshiba 51H83 51" Rear Projection...
I turn on the tv it beeps about 10 times no picture then shuts down
the beeping would be due to a failed power supply unit inside or a fuse there-of i would check this out before making costly repairs that will not work in the long run, hook me up with a good rating and have a good day!
Aug 15, 2009 | Panasonic PT-51HX41 51" Rear Projection...
I have a rear projection panasonic 51" tv with blue curved lines
This can be repaired by a Degaussing coil from most TV repair places. If you haven't already you should shut down the TV and wait till it cools maybe 1 hour or so and then when you turn it on there should be a degaussing circut that might clear this up for you build into the set. Its not that strong a signal and usually takes care of minor discolorations. If it doesn't have that then a shop can come and take care of it pretty fast usually.
Mar 29, 2009 | Panasonic PT-51G36 51" Rear Projection...
Hi, have a 50 inch rear projection Mitsubishi. The problem is that the picture is curved and some of the words around the edges are doubled. Its most noticeable when watching sports because the score board...
power transistors in the convergence circuits on this series TV go bad after several years, making the wavy lines around the edge of the screen and 'doubling' of the edges of the text in varied colors which do not converge. Professional repair is required unless you are brave enough to tackle the project yourself and follow some rather simple instructions, buy a few tools from Radio Shack, and save yourself about $500 bucks...which I did on my own 42" Panasonic rear projection set.
Feb 01, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Can You PLEASE help me
Common problem and fairly easy to fix.
Problem
Screen shrinks and expands - may or may not correct itself after the TV warms up. After a few days, weeks, or months of having the shrinking/expanding problem you may loose all audio/video but the power light will remain lit!
Solution:
Check with the site www.TvRepairKits.com. They have built a kit to fix this problem.
Jan 22, 2009 | Philips Magnavox 9P6034C 60" Rear...
Blue shadow
You need to replace both convergence ICs numbers STK392-570 this is an easy repair which requiresasic soldering skills. you can get replacement ICs that come with free step by step instructions with pictures so you can do the repair yourself, they also provide free on line tech support in case you have any questions . Heres the link
http://servicemanuals.vstore.ca/
May 11, 2008 | Sony KP-51HW40 51" Rear Projection...
Dim picture
I would check the 160 volt radial lead capaitors in the high voltage circuit for high ESR or change in capacitence.
Dec 27, 2007 | Panasonic PT-51HX40 51" Rear Projection...
2002 sony projection screen tv kp-51ws500
the set has a bad tube Don't spend any more money on it
Mar 03, 2007 | Sony KP-51WS500 51" Rear Projection...
Panasonic PT-51G44 51" Rear Projection Television Logo
48 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
