2005 Cadillac CTS Logo
Anonymous Posted on Apr 21, 2010
Electrical malfunction driving yesterday, the radio, power locks and windows went dead while there was a light appearing on the dash the looked like a lock (security). When I turned the vehicle off and turned it back on it worked. Is this going to be a problem or an anomoly?
Marvin
Level 3:
Top Expert:
  • Cadillac Master 85,242 Answers
  • Posted on Apr 21, 2010
Marvin
Cadillac Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29058848
Points
266281
U may have a problem with the BCM (body control module), it will happen again and becopme more frequent until it won't start. I suggest the next time ythis happens have the GM dealer test the BCM, it has a self testing feature to help ID these types of problems, it takes a GM electronic scanner to tap into the functions of the BCM..
Testimonial: "Thanks With my limited knowledge, I was guessing that is was something like you suggested I appreciate the quick response Mike"
My wipers...lights..radio and horn went out but I can drive the car..what would cause this?
2008 Chrysler Town & Country Intermittent Electrical Failure ...
www.carcomplaints.com/Chrysler/Town_Country/.../intermittent_electric...
The 2008 Chrysler Town & Country has 25 complaints for intermittent ... The horn,lights, wind shield wipers front and back going crazy could not shut off. .... I was Driving down the road and my van went crazy possessed! ... Electrical checks reveal nothing wrong with the electrical system, and there is power to the radio.
2003 Dodge Caravan ES Electrical Problem - Discussion on Topix
www.topix.com > Dodge Grand Caravan
Aug 7, 2011 - my van was running fine, shut it off, went in for half an hour then it would not ... or the electric doors. windows do and brake lights. heater stays on hot and i can only ... My horn wipers,power windows, radio,blower front and back, headlights, do not work. ... Chrysler Readies Next-Generation Town & Country.Missing: 2004
Thread: I lost almost all of my dash lights, instruments, and ...
forum.chryslerminivan.net/.../7261-I-lost-almost-all-of-my-dash-lights-i...
Jan 17, 2008 - 10 posts - ‎6 authors
I have a 2003 Town and Country mini-van and I lost power to all my ... In addition to this my wipers, headlight controls, blinker controls, power door locks, and A/C/heat controls are out as well. The odd thing is that the power windows work, the power sideview mirrors work, the radio and ceiling lights also work.
Why did my 2003 Hyundai Santa Fe sudden lost power while driving?
what happened when you tried jumping the car? sounds like it could be a bad ignition switch since only non-switched things work.
I have a 2009 jetta station wagon, today went to drive it and it was dead, the fuel dial didnt move at all but radio, lights and electric windows work. The dash has no lights apart from the green light...
BY dead do you mean that the starter did not crank the engine at all or it would not start and run. I would have a load test done on the battery and check for a failed cell if that is the case.
Red battery shaped warning dash light on now car won't start no battery no blinkers
The battery ran out of power because the alternator is not charging it.
Have the alternator output tested and take a look at the fuses.
Electrical malfunction of dash guages
Wiring problem under the dash. Could be a ground issue as you said. You need to get under the dash and check the grounds.
Power door locks do not work unless the ignition switch is on, radio and dome lights also do not work.
look for another fuse box in or under dash. still sounds like you have a blown fuse. look in owners manual for all fuse box locations,including underhood electrial center. good luck.
Had starting problems and cleaned terminal wires, car started. Yesterday same problem, adjusting wires did not work. Had battery jumped, car started. I warmed up car for 5 minuted before driving. Car...
I would say that you need to replace the alternator. The car was running on the batteries power. When you drove the car, it ran the battery completely dead.
I HAVE A '99 LINCOLN NAVIGATOR WITH A ELECTRICAL PROBLEM. NEW BATTERY AND ALTERNATER AS OF YESTERDAY. APPEARS TO BE CHARGING BY THE INSTRUMENT GAUGE BUT AS I WAS DRIVING TO WORK THE BATTERY SYMBOL DASH...
Items to check:
Try wiring behind alternator.may be full of corrosion.
One of the accessories maybe shorting out and draining battery.
(Techns know how to find this out)
1helpful
Dash lights are out
You have all the fuse locations. I have seen some that after radio was put in did that. usually it turns out that re-grounding the dash or using different power supplies for the radio has corrected it. otherwise, I'd check the light switch and make sure it's OK.
Top Cadillac Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Cadillac Expert? Answer questions, earn points and help others
