Question about Maytag HYE3657A Electric Dryer
MY MAYTAG DRYER IS SLOW AT DRYING
I HAVE A MAYTAG MODEL #PYET44AYW, IT TAKES A REALY LONG TIME FOR IT TO DRY MY CLOTHES. I RAISED THE HOOD AND I CAN SEE MY HEATING ELEMENT TURNING ON FOR ABOUT ONLY TEN SECONDS THEN IT WILL STAY OFF FOR ABOUT SECONDS. IS THIS NORMAL OR IS THEIR A PROBLEM HERE ?IT TAKES ABOUT A HR. FOR A NORMAL LOAD TO DRY.
    Scholar:
  • 101 Answers
Have you checked it for fluff. Also if the vent is blocked it wont dry properly.
Posted on Mar 22, 2008
My Maytag Dryer, Model No. ldg8404aae, is taking too long to dry the clothes. After Turning the dryer on the Vent Pipe gets Hot and then after a little while it feels cool. The vent feels like it is...
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Sep 13, 2011 | Maytag Dryers
Dryer element is not drying clothes like it use
if it takes too long check your vent
Feb 07, 2010 | Dryers
THE DRYER ISNT DRYING THE CLOTHES ALL THE WAY. IT TAKES 3 CYCLES TO DRY THEM. WHY?
If the dryer is generating heat, the first thing I'd check is your vent. Even a partially restricted vent will drastically increase your dry time. Vent hoses are easily crushed behind the dryer and the flap inside the exteriod hood can be blocked.
Dec 30, 2009 | Dryers
Dryer will not dry clothes on the first time drying
if it is drying after two loadsthen you probably have a vent is clogged or slow due to a long length
if you go to where your dryer exhaust outside of the house you should feel good airflow,, it should almost move your hand type of air noit jsut a wind
Nov 02, 2009 | Dryers
Maytag electric dryer is drying inconsistently.
you may need to check the lint trap and clean it .. also try cleaning out the dryer vent... if this doesnt work , try changing the drine belt...
good luck
Oct 12, 2009 | Dryers
Maytag MDE8600AYW takes way too long drying clthes
either your house vent is plugged, or the vent in the dryer by the blower is plugged. when the vent is plugged, even partially, the moisture is not leaving the dryer. It will take a long time to dry, and the top of the dryer will get hot when the vent is plugged. Clean the house vent and check down below the lint trap by the blower, then it will dry fine again.
Oct 09, 2009 | Maytag MDE8600AY Electric Dryer
Slow drying time
very simple, do this test, take your vent hose off the back of your dryer, now dry a load of clothes, if it still takes a long time to dry, then you may need to replace your thermastats, if it works better, your vent hose was pushed in, or smashed or the vent from the wall to the outside is clogged.
thanks Whites appliance repair
Sep 07, 2009 | Kenmore 659 Electric Dryer
Maytag gas dryer wont turn off when done drying in auto dry regular fabrics. does turn off in air fluff and auto dry perm. press. model # d3382
auto dry relies on a moisture sensor to say when its done. so your clothes arent dry enough according to sensor. perm. press. doesnt dry the clothes as much
Aug 01, 2009 | Dryers
Maytag Nepyune not drying completely
There is a cheap PDF repair manual on eBay for this model. It is item number 200258764242.
Premmy
Oct 14, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Maytag dryer
Dear sloika,
I do not believe the problem lies within the dryer unit.
when the dryer unit fails to dry clothes in reasonable time 90% of the time it is the clogged air vent is the reason.
Dryer vent cleaning improves the safety and efficiency of your dryer installation. As dryer vents become filled with lint and other debris, drying time increases and can cause the dryer itself to overheat. This increases energy consumption since the dryer has to run longer to dry your clothes and can also cause fires in the dryer or the dryer duct. The Consumer Product Safety Commission reports dryer related home fires are on the increase.
  • First check your vent hose between the back of dryer and the air outlet on the wall. Vaccum clean the dirty hose and even into the dryer unit using flexable vaccum attachment. also try to vaccum clean airoutlet that goes into your wall as far reach into and much as possible. The dryer's lint filter and its path needs to be cleaned as well.
  • If all air flow path are cleaned it will improve 200% of your drying time.
There is also professional dryer vent cleaners in your area who can help solve the problem. just check your yellowpages..
Feb 16, 2008 | Dryers
Maytag HYE3657A Electric Dryer Logo
176 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
