Question about Linksys WRT300N Wireless Router
Linksys wrt 300n
Hi there, i have lost the installation disk for this router and reset it back to factory settings.... how can i re-install it without disk?
    Genius:
  • 1,027 Answers
Any settings on the router will be erased and the router’s IP address will become “192.168.1.1” and the password will be “admin.”
Disconnect router from internet, plug in the cat5 cable to router from computer, open browser, if router log in is not displayed, type in where the URL would go the default 192.168.1.1
If you are using dsl make sure to change your router static ip to something else. e.g. 192.168.0.1 so there won't be any conflict.
For user guides and software follow this link
Select the Ver # and continue
Posted on Mar 22, 2008
SOURCE:
Unbrick router e2500
If you installed dd-wrt for your new router firmware it's possible you installed the wrong firmware. In most cases, it's permanently bricked. If not, you can try the 30/30/30 method to reset the router to its original factory settings. That is
1. Unplug the router and press the reset button for 30 secs
2 plug in the router and press the reset button for 30 secs
3 unplug the router again and press the reset button for 30 secs
During the entire process keep the reset button depressed. It takes some good hand coordination. 20/20/20 always worked for me for all the linksys routers I've owned over the years.
Jul 06, 2014 | Linksys Computers & Internet
I need to reset my router back to its default settings linksys wrt 300n wireless n
First, to reset the router to factory default setting, press and hold the reset button for few seconds (Reset button is at the back of the router near DC Power Jack). The LEDs will then blink and the routers factory settings would be restored.
Please note that after RESETTING THE ROUTER to defaults, ALL SETTINGS WILL BE LOST AND YOU HAVE TO RECONFIGURE IT. Generally, after hard reset you get the connectivity, however, you have to make the connection secure etc.
Please, refer the product guide/manual and make configurations as per the details provided by your Internet Service Provider (ISP).
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Dec 26, 2010 | Computers & Internet
I forgot my passwoed
If you lost your password/forgot what you set it to, you will have to factory/hard reset your router back to factory default settings and set everything back up again. Just make sure you keep your password somewhere safe so you don't lose it again.
To hard reset (Factory Reset) your router (The best method), use the following steps:
The following procedure will clear out the NVRAM and set your router back to default values:
  1. With the router powered on, press and hold the reset button on back of unit for 30 seconds
  2. Without releasing the reset button, unplug the unit and hold reset for another 30 seconds
  3. Plug the unit back in STILL holding the reset button a final 30 seconds.
This procedure should be done BEFORE and AFTER every firmware upgrade/downgrade.
Do not use configuration restore if you change firmware builds (different svn build numbers).
The default login for your router's control panel/settings manager is as follows:
Username: Not required /Admin/Administrator (Try all three. One should definitely work)
Password: admin (Case Sensitive)
Also the default access IP of WRT54G is 192.168.1.1 or 192.168.15.1 (Depending on version) so after you hard reset the router and get it booted back up, you should be able to access the router via:
http://192.168.1.1
http://192.168.15.1
I hope this helps. I know it's probably not the answer you wanted, but unfortunatly you won't be able to retrieve or change your password without having the password or hard resetting your router back to factory defaults and set it back up (Sometimes good to do anyway every once in a while).
Also, just as an extra tip/hint, I'm going to lead you in the direction to turn that $60 router into a $600 router (Theoretically speaking) just by using a custom firmware called DD-WRT which unlocks TONS of options and is faster and much more stable than the factory firmware.
You can find DD-WRT here:
http://www.dd-wrt.com
Enjoy!
Best Regards,
James
Nov 27, 2010 | Linksys Wireless-G WRT54G Router
Router does not show wireless light. I have reset it but can't access it with the setup wizard. Any suggestions?
* NOTE: If you tried to set-up the WRT-150N Router previously, but failed, with the Router ON, press the "Reset" button on the back panel and hold it down for 10 seconds, then release. This will reset the Router to factory settings and erase all previous data.
then do this :
1. Hook up the Linksys WRT-150N Router to the Modem via a LAN cable.
2. Hook up the Linksys WRT-150N Router to your computer via a LAN cable with the LAN cable in Port #1 on the Linksys WRT-150N Router.
3. Type http://192.168.1.1 in the address bar of your web browser.
4. Log-on to the Linksys WRT-150N Router with these log-on credentials:
Username: linksys (lower-case)
Password: admin (lower-case)
5. Click on the "Clone PC MAC Address" tab.
6. Click the "Clone PC MAC Address" button.
7. Click "Save", click "Continue".
8. Click the "Wireless Security" tab.
9. Choose "WPA2 Personal - TKIP/AES" for encrypted security.
10. Enter encryption password (passphrase).
11. Click "Save", click "Continue".
12. Exit the web browser.
13. Disconnect the LAN cable from the computer and Port #1 on the Linksys WRT-150N Router.
In about 5 seconds, your wireless connection should be up and running.
Sep 15, 2010 | Linksys Wireless-N WRT150N Router
Hello, I have a Linksys Router model No. WRT 160N and have problems with the wireless signal. Doesn't appear the wireless symbol ON and I have connected already the modem cable. The modem is OK cuz I can...
* NOTE: If you tried to set-up the WRT-160N Router previously, but failed, with the Router ON, press the "Reset" button on the back panel and hold it down for 10 seconds, then release. This will reset the Router to factory settings and erase all previous data.
Then do this
1. Hook up the Linksys WRT-160N Router to the modem(cable, DSL or satelitte)
2. Hook up the Linksys WRT-160N Router to your computer via a LAN cable with the LAN cable in Port #1 on the Linksys WRT-160N Router.
4. Log-on to the Linksys WRT-160N Router with these log-on credentials:
13. Disconnect the LAN cable from the computer and Port #1 on the Linksys WRT-160N Router.
Sep 15, 2010 | Linksys WRT160N Wireless Router
Linksys 300n 1.1 router installation instructions
HERE IS THE LINK TO THE MANUAL
http://downloads.linksysbycisco.com/downloads/WRT300N_ug,0.pdf
Jan 07, 2009 | Linksys WRT300N Wireless Router
LINKSYS wrt 300n
Ok, I recieved one of these routers a while back to fix and I think that some D-Link's access has been disabled. To reset the router back to default settings, on the back of the D-Link, hold in the small reset button in the hole for about 4 seconds and it should restart. Then, all settings on the thing will be reset back to the defaults set by D-Link!
Jan 16, 2008 | Linksys WRT300N Wireless Router
Linksys WRT300N Wireless Router Logo
168 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
