Question about Panasonic NV-GS27 Mini DV Digital Camcorder
Cd-rom not supplied on purchase
Can I download driver to enable me to put mini-tape recording onto DVD?
  • Anonymous Mar 24, 2008
    I have a NV-GS70 that I have trouble getting a USB driver even though it is on the CD that was supplied with the original purchase 4 years ago, also will this camera, when it has the correct driver fitted, work with Adobe Premier 3 or does Adobe only work with FireWire.
  • Panasonic Master
  • 19,396 Answers
Here is the software download
Here is also the manual.
Alternatively use the software here, and use firewire connection to transfer files. See here .
Posted on Oct 14, 2008
Purchased a Gear Head webcam WC745blu 1.3mp, it came with a mini disk to install software. I have a standard cd-rom for standard size disks so I cannot install drivers with this disk.The website does not...
Well the disk actually works on most standard CD-ROMS. paper_bag.jpg If its cd-rom that is used in laptops (extremely thin) it should also work but you can always find a computer with one of these trays and then copy the contents.
Apr 03, 2011 | Computers & Internet
Trying to download mini dv tape onto video
for to import from the Sony handy-cam you need a firewire cable ..not a rca..this one will only help you see the video on a tv ...but you will not be able to import them into computer ...
just ask at the store..and take the camera with you ..
another thing the camera may support even a usb cable that may be available in the box that it came with (infact the iLink cable should be there too )
so ..this is a link to a video I use to explain in detail the procedure to import fom minitape of sony handycam.
.http://www.5min.com/Video/Windows-Movie-Maker---import-from-a-DV-tape-6876
after have them into the windows movie maker..just drag them to the story board..(join them if you need) ..and save them by finishing movie...and save to computer ..in best for computer mode...after that just burn them to **** ..using Nero ..or if they are small enough to get into a cd ...use window feature for burning ..
Mar 29, 2010 | Sony Handycam DCR-TRV22E Mini DV Digital...
Drivers for Toshiba satellite A75-S226
here ya go
http://www.officialdrivers.net/toshiba-drivers.php?gclid=CJip5OKvpJsCFQ4MDQodWCAtCg
Jun 25, 2009 | Toshiba Satellite A75-S226 Notebook
Dvd recorder has copy protected message
the tapes that you can,t copy are protected, manufacturers used to put a high pitched frequency on the tapes themselves, which would in theory cause a scrambled frequency. the only suggestion i have for you, is to play the tape onto a television, and use a camcorder to record the image from tv to camcorder, then camcorder to pc, and use some good editing software to create the dvd.
alternatively, you could try using a second dvd player, and use your recorder as the second device.
The final but more expensive option, is to look for a way to input the recorder, direct to PC. which you would use picture out, to graphics card input, and the red and white ( Audio ) for the stereo Sound output. does your player or tv have An spdif connection or similar, you may be able to output to camera, rather than to dvd.
Where theres a will, theres a way, but these are a few options.
****Please note:- this information is supplied only as you have the original Movies***
Bear in mind, it is illegal to copy protected content. However as you own the originals, this information is provided to enable you, to backup your Purchased Content.
Thankyou for using fixya.
Mike @ compurepair.
Jun 15, 2009 | JVC DR-MV100B DVD Recorder/VCR
How can I connect my CD-RW880 recorder to the
Make sure the phonograph is connected to the Phono Connectors. Hook up your CD recorder to the tape. The play connectors on the CD recorders can connect to the tape play connectors on your stereo. The record connectors on your CD recorder connect to the record outputs on the tape connectors on your stereo. You can also connect you CD recorder to the VCR connectors if you are using an audio tape as your source. All of the outputs and inputs are the same level except the phono.
Jun 12, 2009 | Teac CD-RW880 CD Player / Recorder
DVD ROM/CD-RW Drive
try to roll back the driver , if that doesn't work go to the manufactures web site and download the driver . if it still doesn't record install the drive in another computer and if it doesn't work then it maybe a bad drive itself
Aug 06, 2008 | Gateway 310S (2900621) PC Desktop
Tranfer mini cd to a normal cd?
put the CD back in the casmcorder, and hook up the camcorder to your tv. put a blank disc in your dvd player and play the small disc through the camcorder on the tv. while the camcorder is playing the recorded stuff, press record on the dvd player and it should burn the stuff onto the blank cd.
Jan 10, 2008 | Panasonic VDR-D200 DVD Camcorder
Power save function
Do you put a tape in when you try to record or do you connect to a DVD / VCR so that it records onto the DVD or VHS?
If this is how you do it, then I will recommend you use a mini DV tape instead.
Hope this helps.
Osei71
Sep 10, 2007 | Panasonic Palmcorder PV-DV53 Mini DV...
Recording of video in order to burn to DVD on a GSA 5169D
put tape on the hole on top of the tapes and you shoud be able to record. its tape on the top or pull the top off i cant remimber which one it is but this is the answer.
Feb 21, 2007 | LG GSA-2166D DVD RW Dual Layer Burner
Cd burner
1. go to device manager / right click on cd drive / uninstall driver / reboot and windows will reinstall driver 2. go to My computer right click on cd drive properties - check digital cd playback recording - check enable cd recording on this drive driver - update or uninstall reboot your computer 3. go to support.toshiba.com look for the EXACT model of your toshiba notebook a) download latest BIOS b) download the cd driver Goodluck!
Sep 25, 2006 | Toshiba (SD-R2412) for Satellite A10, A15,...
Panasonic NV-GS27 Mini DV Digital Camcorder Logo
189 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
