Question about Lands Phones
INTERNET AND CABLE WORKING BUT NO DIAL TONE ON PHONE, I RESET THE MOTEM, AND ONLY HAVE 1 PHONE IN THE HOUSE SO I KNOW IT IS HUNG UP CORRECTLY HOW DO I USE OR GAIN AXCESS TO USE THE PHONE?
    Novelist:
  • 155 Answers
I am assuming you have broadband (via your phone line) rather than dial-up internet access...
If so, this sounds like a fault with either your external phone line or a problem with the equipment at the telephone exchange.
Report the fault to your telephone service provider and get them to run a line test.
It is unlikely to be anything at you end.
Hope this helps,
Matt
Posted on Mar 22, 2008
SOURCE:
How do I know if my phone base is faulty on my house phone, it says "no line" and the lights are working. I have tried reset. Any ideas?
Unplug it from the connection at the wall and use another phone to see if the phone wiring in the house works. If you don't hear dial tone in the test phone, then the problem is the wiring in the house or the phone lines. If you hear dial tone then the problem is in the base of the other phone.
Jan 23, 2016 | Lands Phones
Why has the phone reversed, dial tone works only when phone is hung up why?
If I understand you correctly, when you leave the handset in the cradle and press a line, you can hear the dial tone. But, if you lift the handset and then select a line you don't hear anything through the headset. If this is correct, I suspect the handset is damaged, the cord is damaged, or if you're lucky, the clips may not be plugged all the way in on both sides. If you have another phone that is the same, you can switch handsets to test this theory.
Oct 19, 2014 | NEC 22b Hf Aspirephone-bk Stock No....
Why no dialing tone
no dialing tone indicates an open line or an extension that has not been hung up properly. IF you have a corded phone then it may be in the cord (broken at the hand piece or at the base) On the technical side it may be from the wires in are not paired properly ( go google and check for phone line pairing) and on the financial side the account has not been paid
Jul 06, 2014 | British Telecom BT BIG Button Corded Phone
Hi. It's a model DSS8955+3WP. The problem is that the handsets will not communicate with the base. Problem happened over night, previously working fine. When you try to get a dial tone on the handset...
you may have to clean out the jack for the headset or your earphones may not be workin correcty also you may need to make sure that any other connected phones are hung up correctly in your house / office if you need further help let know
Jun 30, 2011 | Uniden Cordless Phone
Hp problem
Try to make a new connection shortcut and make sure your telephone line is properly connected on your modem. Also make sure that your password and username is correct. another thing is check that your system date is correct.. Hope this works ! ITTech7574
Aug 28, 2009 | HP Pavilion a6863w-b PC Bundle with 23"...
No dial tone no incoming calls or outgoing calls
Have You Tried Replacing The Cable Connecting the Base To the Wall Jack? If Not Do That...
If that doesnt work there should be a channel button on the handset try that...If that doesnt work i would say the handset itself is bad.
Apr 03, 2009 | Uniden Cordless Phone EXAI985
Modem connects to internet but I have no dial tone to make calls
Usually DSL, like verizon, they comes with filter. check the filter that connects to the phone.
Mar 30, 2009 | Arris Touchstone 450a (CM450) Modem
Phone button tone replaces dial tone
You first need to determine if it is THAT phone or the jack it is plugged into. I would swap the phone with another in th ehouse and see if the problem stays with the phone or stays with the jack. If its the phone take it back or trash it. If the problem is the jack and if you have "lines keeper service" the phone company will repair the jack for you. If you do not have the inside wire insurance, ask the phone company how much it will cost to repair. You may want to get a private technician that will fix it for you for much less. Good Luck
Dec 23, 2008 | Lands Phones
Uniden TCX805 Cordless "loses" dial tone
Sounds like the switching mechanism that creates the link is stuck. When you answer your phone, you allow the voltage to complete it's path and you either answer the phone or you hear dial tone. If that switch is stuck closed, even though you hung up the phone, the connection is still alive. When you try to pick the phone back up later, the connection is still closed, but your phone has already passed it's "if you would like to make a call" message and you hear no dial tone. Unplugging the power to the phone resets this switch and all is good again.....that is until it gets stuck again. I have seen this problem with phones after a near lightening strike at the house. Sounds like you need to get a new phone as I don't think this is repairable.
Dec 30, 2007 | Uniden Cordless Phone
Lands Phones Logo
108 people viewed this question
Top Lands Phones Experts
Ekse
Marvin
Marvin
Are you a Lands Phone Expert? Answer questions, earn points and help others
