Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Motor whine w/ agitation & no high speed spin
Machine has a loud whine during agitation and spin. Does not appear to go into high speed spin. In addition to the whine, makes a clicking sound while attempting to spin. Smells like hot electrical after a while. Does not appear to drain. I have no problem getting the body off, and can handle most minor repairs. Help is appreciated.
    President:
  • Whirlpool Master
  • 2,651 Answers
Try undoing the pump assy (just unclipp and move it aside) no need to disconect hoses yet. tyspinning now, if quiet then theres csomethin in the pump, you may get lucky and be able to pull whatever it is out!
Posted on Mar 23, 2008
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Loud constant noise (metal on metal clicking / whirring / grinding) during spin cycle
renault laguna 2006 diesel. unlock code for radio... modell renrdw100-10 .
n874 security...
pls..
thanks
Nov 22, 2013 | Whirlpool Washing Machines
Washer making whining noise wash cycle
see this steps and fix it. God bless you
Tub Bearing
If the washer is making a loud noise the tub bearing might be worn out, this is a common problem. The bearing can be replaced. On some models the bearing is part of the outer tub and the outer tub will need to be replaced.
Enter your model number to see parts for your washing machine.
Help me find my model number
Tub Seal and Bearing Kit
If the washer is making a loud noise the tub seal and bearing kit may need to be replaced. This is a common problem. sometimes the tub seal and bearing are part of the outer tub and the outer tub would then need to be replaced.
Rear Drum with Bearing
If the washer is making a loud noise the rear drum with bearing might need to be replace. On this washer the bearing is not sold separately, the entire rear drum will have to be replaced. This is a very involved repair and will require disassembling most of the washer. However, the problem is going to get worse very quickly and so either the drum and bearing will need to be replaced or the washing machine.
Bearing
If the washer is making a loud noise the bearing might be worn out. As bearings wear out from friction they gradually get worse and worse until they fail. In the meantime they get louder. If the noise primarily happens during the spin cycle the bearing is likely the problem.
Drive Pulley
If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
Pulley
If the washer is making a loud noise the drive pulley may be worn out. If the drive pulley is loose or wobbling it will need to be replaced
U-Joint Kit
If the washer is making a loud noise the U-Joint may have failed. This is the primary drive mechanism for the agitation motion in this washer. Although this is not a very difficult repair for a DIY'er with some experience, the part is expensive and so it may be worth considering a new washer.
Motor Coupling
If the washer is making a loud noise the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission.
Clutch
If the washer is making a loud noise in the spin cycle, the clutch assembly might be worn out. The clutch assembly makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may become loud during spin or just after the spin cycle finishes. The clutch is not repairable, if it is loud or not working properly it will need to be replaced.
Drive Belt
If the washer is making a loud noise the drive belt might be defective. Over time the drive belt will dry out and start cracking, eventually a piece of the belt can break off resulting in a loud noise whenever the motor is running.
Transmission
If the washer is making a loud noise the transmission might be worn out or defective. There are many other more likely causes for noise from a washer. If the noise turns out to be caused by the transmission it may have to be replaced.
Drain Pump
If the washer is making a loud noise the drain pump might be going bad or might have something caught in it. Remove the drain pump from the washer and inspect it carefully. Look for anything that might be caught in it, a piece of wire, plastic, etc. If nothing is wrong with the pump, but it's still noisy it will have to be replaced.
Drive Motor
If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
Water Inlet Valve
If the washer is noisy or loud, particularly when the washer is filling, the water inlet valve is at fault and will need to be replaced.
Jul 20, 2013 | Whirlpool Ultimate Care II LSQ9549L Top...
My Whirlpool LSR8233EQ0 washing machine making loud whining and banging noises during spin cycle only...any ideas on what to replace?
Two possibilites would be a loose agitator (some agitators can betightened from the top, check for tightness)If you can't tighten the agitator from the top, turn the machine over ( you will probably need to disconect water hoses first) and check the underside. From here you should be able to determine if the agitator is loose or more likely you've got a loose drive belt.
Nov 16, 2011 | Whirlpool Washing Machines
During the spin cycle it started making a whining
it must be motor run away condition. motor must have exceeded its design speed and the internal windings must have parted off. you did the right thing. but, when your son switched on again, it would have run for few minutes with all internal extra friction and stopped with burnt smell. you have lost the motor. but, before replacing the motor get the speed control system checked.
Mar 19, 2010 | Maytag Performa LAT2500A
Shows "LE" in display.
Machine has a bad motor or "stator" on this machine. It is a direct drive winding on the back of the machine. Remove the back panel, the one bolt removes the rotor then you will see the stator winding, replace it and your good to go.
May 11, 2008 | Washing Machines
Washing machine making whining noise during spin only
Yes, bearing, most definitely. It is a cheap part but difficult to replace.
Apr 11, 2008 | Washing Machines
Motor whine during agitation & won't spin at high speed LSQ9200PQ
check to see if the tub has any side to side play to start then pull the motor and check the coupling the clicking is whats confusing
Mar 21, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Spin and agitate problem
Wald, a couple of things here, see if they apply to your situations. I have seen the speed selector switch on GE models go bad and send voltage to both, the high and low windings in the motor. This causes the motor to get real loud and but usually kicks out the overload in the motor. Another issue is the current jogging between the high and low windings causing a chunka-chunka-chunka effect. GE put out a motor kit with a new harness and start cap to correct this problem. Open the front panel of your washer by pusing in on the two clips just under the lid and pulling the front panel towards you. You should see the harness with the start capacitor on the right if you have the latest motor. If you are handy with a meter, you can check the white and white/red wire to the motor. If you have a steady 120 volts to the motor during this jogging, replace the motor with the new kit. Catriver..post back.
Nov 18, 2006 | GE WBSE2090A Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
168 people viewed this question
Dan Webster
Dan Webster
Sal De
