Question about Samsung SyncMaster 930B 19" LCD Flat Panel Monitor
Backlight is acting like a bad flour. tube .. everthing else OK
When first starting monitor, it has a weak- flickering back light .. just started acting up recently .. everything else is GREAT!! I like the colors and extreme detail this monitor offers.
I'm running XP home .. does seem to be a monitor problem, however .. if the monitor is re-started warm I think it comes up normal .. leaving it in green-flash mode does not change startup flicker after cool-down.
Could there be a startup driver in trouble within the monitor?
I'm concerned that one time soon, the backlight might fail altogether ...
  • thebarrel Mar 24, 2008
    I appreciate the "aging" info .. however monitor [Samsung 930B 19" Black case], is less than a year old.
    Perhaps it just needs a new lamp, but since it runs bright after starting problems without any dimming or flicker until next use, I wondered if there might be a hardware or software fix.
  • Anonymous Mar 31, 2014
    screen not visible after approx 30 minutes,new backlight fitted recently
    Champion:
  • 220 Answers
Normaly the backlights have a life of around 40k hours of working.
If your monitor is 3-4 years ,the backlight tube/s could be defective.Your description seems to indicate tube aging.
It's possible to replace the tube but needs a good amount of technical skill.
Do write if you need more help,Please indicate make exact model no etc.
Samir
Posted on Mar 24, 2008
  • Samir  Shah
    Samir Shah Mar 25, 2008
    This is a Harware problem of monitor.Contact manufacturer Samsung.They should help.
    Samir
SOURCE:
Veiwsonic VP2365wb backlight flickering
If it's not under warranty, buy a new one from newegg dot com.
Mar 27, 2013 | ViewSonic VP2365WB 23 inch LCD Monitor
Will not retain screen image. Flashes the content when you push the on/off button and is clearly projecting data, but just in flashes.
It appears you may have a bad backlight. If you can see the picture content with a strong light shining at an angle to the screen while it is dark, then it is definitely the backlight. Most sets shut down shortly after getting a failure signal from the backlight inverter although you do not mention that happening.
The backlight uses two or more Cold Cathode Fluorescent Lamp (CCFL) tubes, and they'll have the same flickering as a failing standard fluorescent tube. If the light has a pinkish cast to it, this is a common sign that one or both of the tubes is bad. You may see the flashing on the top or the bottom and the other half of the screen will be dark; this means one tube is dead and the other is dying.
May 24, 2011 | Sony SDM-HS73P 17" LCD Monitor
I have Dell 1907fpc monitor. The image flickers and finally darkens. how to resolve the problem?
It sounds like your LCD Backlight/s are going out. To fix you will need to replace the LCD screen inside the Monitor. It may be more feasible to replace the Monitor.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Feb 24, 2011 | Dell UltraSharp 1907FP 19" LCD Monitor
Monitor flickers at start for 20-30 seconds, then everything is ok.
Either a dying backlight or bad internal connection. If under warranty, RMA it with place of purchase. If not, you can try opening it up & tightening any loose connections then reassemble & test. If problem still persists, replace the backlights.
Nov 29, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
Samsung syncmaster 203b problem
This is a typical symptom of a failure of the capacitors on the power supply board. When the filter capacitors go bad the power supply can not start up correctly so you get flickering or even no display. You can repair this unit by replacing the bad capacitors and a fuse on the power supply. This is an easy repair, it just requires a little soldering. Here is a lin to additional information on which capacitors need to be replace and also here is a picture of the power supply board with the capacitors and fuse circled.
http://www.ccl-la.com/catalog/product_info.php?products_id=229
Apr 04, 2010 | Samsung SyncMaster 203B LCD Monitor
Dell 17" Monitor - Won't display anything, power light flashes
Akeru, It may or may not show up again. My guess is that it will. This seems like a power supply/inverter/CCF tube issue. The lamps try to fire up but due to a possible fault in the Switch-Mode-Power-Supply and or the Inverter circuit the SMPS goes into shutdown and does a self reset after 5 seconds. And then repeats the whole cycle again. Well if the unit is over 5years old you can do several things. 1. See if DELL can do a swapout. Send your's+$40-$90 to them. They send you a same model REFURBISHED (new CCF tubes/inverter/smps) and a short 30day min warranty. 2. You can locate a electronics repair shop ( TV/VCR/DVD/Monitor) that knows all about cold cathode fluorescent tubes and their power source, Inverter type. 3. Try to effect repair on your own. That's about all the options that a consumer/user has open to them. I'm louie12fix on fixya or [email protected] aim.com Bye for now.
Apr 30, 2009 | Dell E173FP 17" LCD Monitor
Flickering monitor
Flickering screen display
Flickering on the screen can be caused by defective hardware in the computer or by improperly installed software, but it can also be caused by interference from external devices. The following examples describe situations in which your screen could start flickering:
  • Screen starts flickering because of interference caused by devices which generate magnetic fields, for instance:
    • a TV set
    • a laser printer
    • another monitor
    • fluorescent lights
    • hidden power lines
  • Apart from interference, an incorrect setting in your system CMOS setup can also cause flickering. On some systems it is possible to distinguish between interlaced and non-interlaced monitors. The setup of your system should always be colour non-interlaced.
  • Proximity to the monitor of fans, air-conditioning units or other devices with rotating motors.
  • The number of devices using power from the same electrical line. Are you overloading the plug?
  • Monitor placed on an unstable surface.
  • Improper video drivers, this is a software problem, see section B
  • An improperly configured or a defective video card.
Sep 30, 2008 | E-Machines E17T 17" Flat Panel LCD Monitor
Viewsonc VA720 Flickers On and Off Continuously
Take a look at the capacitors and see if you have any weak one. An obvious way to spot one would be one bubbled up on top. A bad cap won't always be bubbled up. The monitor probably can operate until the voltage drops under 8 volts. Also possible if power supply check out good would be a weak backlight inverter.
Apr 05, 2008 | ViewSonic VA720 17" LCD Flat Panel Monitor
Display lights up then quickly goes dark
It could be your LCD backlight giving you problems. With the computer on and the monitor power LED green shine a flashlight in the lower left hand corner of your screen. Look for the ?Start? button, if your backlight is not working you?ll see a faint ?start? button if you look closely. If you do see the ?Start? button then either your backlight tube is bad or more often the inverter board is bad. Let us know if you have any other questions and please don?t forget to rate this posting.
Jul 15, 2007 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
E172fpt Backlight flicker
It's a pretty easy fix if you can solder. Get the parts here:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&Item=220476282873
May 27, 2007 | Dell E172FPt 17" TFT LCD Flat Panel...
Samsung SyncMaster 930B 19" LCD Flat Panel Monitor Logo
259 people viewed this question
Top Samsung Computers & Internet Experts
Ekse
asber
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
