Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
Estimated time 2minutes blinking with an "F" what does this mean?
Just as it sounds. When I start a wash cycle all seems fine but at the 2min mark the washer starts beeping and the estimated time light blinks 2 min and F. Ive tried pressing cancel and it goes back to 10min remaining so I press start and at 2min it does this again.....it is just a cycle....literally....what do I do?
  • 1 more comment
  • Anonymous Apr 06, 2008
    Estimated time 2minutes blinking with an "F" what does this mean? problem, and notify you when a new solution is offered.
  • donfish1 Apr 30, 2008
    Washer stopped before the cycle finished. Flashes 2 then F. If I press cancel it kicks back to 45 minutes acts like the cycle is going to start but shuts down immediatly and eventually starts flashing 2 then F again.
  • Anonymous May 04, 2008
    I have a problem with a w minute warning then a F code. Also I get a suds code the repairman came out and said from time to time to rinse with vinagar to reduce suds code. Nothing has worked.
I had the same problem too. It is the drain pump that is going bad. Try that fix, about $80, it should do it for you!
Posted on Apr 07, 2008
Are you certain its not blinking F 02 I have a similar problem and the only way I can get it to finish is to hit pause and let it sit overnight befor hitting start again, I cleaned out all the huses and the pump filter which were a mess wet lint and change respectivly, This helped (now I get one load done before it stops)
Posted on Apr 03, 2008
Samsung front loading dryer the display shows rotating circle rather than time remaining
Rotating blinking lights in the display is probably an indication that the Wrinkle Prevent option has been selected. Wrinkle Prevent will continue to tumble the dryer without heat after the cycle has ended to help prevent wrinkles from setting in. When this option is selected by pressing the Wrinkle Prevent button on the control panel, the display will count down the estimated cycle time; when the cycle ends, the display will show lights blinking in a circular (or actually rectangular) motion.
To deactivate, simply press the Wrinkle Prevent button again so the light is not illuminated.
Jul 28, 2014 | Washing Machines
My old Fisher and Paykel GW711 washing machine worked fine until I moved house. It worked fine a few times here, too. But now it fills, but then doesn't start the wash cycle, then after about an hour, it...
sounds like an electronic problem. motor controller most likely. I am unsure off hand what this fault (7) means, but the number is very low, which normally indicates motor control board
Sep 12, 2013 | Fisher and Paykel Washing Machines
Whirlpool quiet wash plus dishwasher
Sounds like the timer module is going bad. Might be getting moisture on contacts. That would explain why it works one time and not the next.Just trying to help!
Aug 14, 2013 | Dishwashers
The machine appears to be stuck in a wash cycle. After unplugging the machine & plugging it back into an outlet you have no indicator lights. The only button that has a response when pressed is the...
this machine sounds to have a computer board problem I have a calypso washer also and i had the same problem so I ordered both computer boards and replaced them and everything was working like new , I haven't had any further problems since
Jul 31, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
The times seem to have changed on the settings for soil levels. For instance, the quick is 50 minutes and the normal is 84 minutes. That does not seem right. Is there any way to set them different?
Answer to your question "Is there any way to set them different?" Short answer is no. The Maytag Neptune like many other washers that display a time of cycle first start with an estimated time this relays a lot on the last cycle ran. But, more importantly it also takes into consideration other washing options. For example, lets say that your quick wash cycle used to only display 35 min. now if you select an extra rinse option the time will increase from that 35 min. to a higher amount of time. This is due to the longer time it takes to go through a second rinse cycle. The MAH5500 if I'm not mistaken also has a heater in it so there are options such as sanitize which takes 120 degree hot incoming water (suggested temp. for hot water heaters) and heats it to approx. 165 degrees. And as you can imagine this takes a washer some time to do this (increasing wash time). If you would like to lower washing time check the washing options and remove any that are not needed at that time; pay close attention to extra rinse cycles and the soil levels that are selected. Hope this helps. Cheers.
May 16, 2011 | Maytag Neptune MAH5500B Front Load Washer
Making loud knocking/clunking sound in the wash cycle.
i have the same problem. the transmission/brake assembly is worn out. the stopping and starting problem... I have that too, that was a dry solder joint on the circuit board. i found it because if I pressed on the area of the panel to the left of the cycle select knob, it would shut off immediately. I soldered it back up and it's fine. Still working on fixing the transmission problem, the parts store wants 300 bucks for the part but looking at the GE website, the tranny might be under extended warranty.
May 03, 2009 | Washing Machines
Whirlpool Duet washing machine will not start a cycle.
sounds as if its a door latch/lock issue, not recognizing the door closed will simply beep 3 times when the start button is depressed. try unplugging and replugging after 2 min.
Nov 17, 2008 | Whirlpool Duet GHW9150P Front Load Washer
LOC Blinking
Control Lock
To avoid having someone accidentally start or stop the
washer, press Options and Select at the same time and
hold for 10 seconds until “LOC” is displayed alternately
with the estimated cycle time. To unlock the controls,
press Options and Select at the same time and hold 10
seconds until ”LOC” is no longer displayed.
Jun 05, 2008 | Frigidaire Affinity ATF7000E Front Load...
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
136 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
