Question about Motorola Mobility RAZR V3xx Cellular Phone
Motorola V3xx I have a standard built in motorola handset in my Jaguar X-type (with touch screen) and want to unplug the handset and install a direct lead connection from the RJ45 to the V3xx mini usb. Can anyone tell me which pins from the V3xx I need to connect to the RJ45 pins to get maximum functionality?
    Scholar:
  • 45 Answers
Hi AliyaC,
I'm not sure which pins to connect for maximum functionality. If you want to connect your V3xx to a RJ45 connector, I suggest you look at buying a converter set which do this for you. I've put together this diagram to show which components will be required for the conversion:
Cable 1 can be found at
http://www.nanosys1.com/cbl-usb-minib-a.html
Converter 2 at
http://www.nanosys1.com/con-usb-aaff.html
Cable 3 at
http://store.apple.com/1-800-MY-APPLE/WebObjects/AppleStore.woa/wa/RSLID?nplm=MB442Z/A#overview
I hope you find this information helpful in solving the problem.
Please take the time to rate this solution.
Kind regards and thanks for using the FixYa service.
Posted on Mar 22, 2008
    President:
  • 1,944 Answers
What you would like to do is most probably not do-able. May I ask why you want to do this?
  • 19,396 Answers
You cannoct just connect a cable from those two ports, you will need an adapter
  • Ginko
    Ginko Mar 22, 2008
    Usb is Universal serial bus, it manages serial signal, RJ45 is ethernet terminator, it will communicates using ethernet packet. You cannot just run a cable between those two port. The easiest thing to do is to connect an ethernet adapter to usb port, that would work on a pc usb, but not on min usb on your motorola, as you will not find drivers for a usb ethernet adapter on V3xx.
    Here is one model:
    NewLink USB to Ethernet Adapter,
    Here another
    D-Link DUBE100 USB to Ethernet Adapter
    I do not think models above can work on your device.
    The only remaining thing to do is to use a hub/switch or router with usb capabilities.
    Here is the sample with a hub (cheaper than other devices).
    If you use a hub same as the one above it will work for sure.
    regards
How to unlock motorola v3xx at&t 3g
Hi, You can unlock a Motorola V3XX safer and easier using unlock code. You can get the unlock code for a Motorola V3XX from www.simpleunlocking.com/motorola-v3xx/rs16wp9/ at low cost.
UNLOCKING STEPS FOR MOTOROLA V3XX
1 - Switch ON your Motorola V3XX with a NOT ACCEPTED SIM Card,
2 - Phone will display "Enter Special Code",
3 - You can now enter the Unlock Code.
Oct 10, 2012 | Motorola Mobility Razr V3xx Cingular At&t...
I need a subsidy password for my v3xx
yes, surely you can get the subisdy code for your Motorola v3xx model mobile, through this site http://www.mobileunlocksolutions.com/motorola-v3xx/rs1wp9/ , it has the some better instructions and methods for getting your subisdy code for your motorola mobile phones..........
Jun 22, 2011 | Motorola Mobility RAZR V3xx Cellular Phone
Remove camera
open up the back of your v3.take out the battery..
then remove the 4 little rubber screw plugs on the 4 corners of the screen side of the flip/there are 4 little star type screws in there.remove them remembering what hole each screw came out of.some v3s have different size screws in the holes.then you'll see the flat ribbon cable going from the camera to the pc board of the screen.remove it and gently work the camera out of its holder..be careful.use a flat type screw screw driver to work it out.
May 25, 2010 | Motorola Mobility RAZR v3xx Cell Phone
My motorola Razr V3xx mobile is not detected motorola phone tools in vista 64 . so I am unable to use the internet from my mobile's modem
Go to the link below and try the driver installer, you will see that there is one for 64bit OS, hope this helps you.
http://direct.motorola.com/hellomoto/nss/usb_drivers_pc_charging_drivers.asp
Mar 14, 2009 | Motorola Mobility RAZR V3xx Cellular Phone
Motorola V3xx Razr Front LCD Screen Glass Repair
Your best bet would be to take it to your cellphone company and have them fix it for you.
Jul 03, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
Motorola V3xx I-mode
Under the settings for usb connection type change the setting to memory card connection. This is subject to having a memory card (Micro sd) installed. Otherwise you may have to install motorola phone software into your computer and use this to update files on your phone.
Regards,
David M-G
Feb 20, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
Motorola Mobility RAZR V3xx Cellular Phone Logo
71 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
