Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Whirlpool Icemaker flooding freezer
Hello, yesterday I pulled out the Icemaker and defrosted some ice that was stuck in the fill chute. However after I reinstalled it. The Icemaker proceeded to flood my freezer water went everywhere. Any suggestioins?
  • MikeinBowie May 03, 2008
    I have Whirlpool Model ED25PE and water also freezes in the entry shute and causes a frozen water mess in the whole freezer unit. Twice I used a hair dryer to get enough melting to remove the frozed water from the plastic feeder shute. Afterwards I poured very hot water into the water entry chamber of the ice tray using a transparent ketchup/mustard/mayo squeeze bottle that has a long neck and a small discharge opening. However, the problem still happens after a couple of days. This last time I completely removed the ice maker and inspected for problems. All I found was ice in the entry chamber. It is working again after re-installation, but I have no reason to believe that the problem is fixed. I think the problem started after outside water was shut off by the water company for pipe work across the street.
    President:
  • 1,314 Answers
How much water and did you have to shut off the water supply to stop it
Posted on Mar 23, 2008
SOURCE:
My Whirlpool Ice Maker in the Freezer is frozen with ice stuck in the top. Some of the last ice that came out was more than half the circle size. Can I use a dryer to melt the ice stuck in it? How can I...
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
If you still have trouble GO HERE:
hhttp://www.applianceaid.com/procedures.htm
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Sep 28, 2011 | Whirlpool Refrigerators
Whirlpool #ER2CHMXPL00- ice forming in freezer below fan on base and all around plastic chute in center back of freezer. Not from icemaker. How to get plastic chute out to see defrost drain, etc?
use hair dryer but do it gently.
turn the unit off.
the drain is in the back wall of the freezer and its go all the way to the pan next to the compressor , use hot water and pump to clean the path.
good luck
Jan 11, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Freezer drain line and upper drain pan freezes up regularly.
sounds like your fill tube is leaking
you should be able to pull it out from the back of the machine
to inspect it
if the fill tab on the tube is facing in any other direction than down it should be straight down
Oct 09, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool Gold refrigerator water leaking
If it's flooding, it's NOT the drain pan. It's probably the water valve has gotten stuck in the open position. Hope this helps!
Aug 19, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Icemaker stopped making ice
remove the front plastic cover on the icemaker and you will see a bunch of little holes make a jumper wire out #10 or 12 house wire strip about 1/4 inch off the ends an insert in the holes marked t&h this will start a test cycle make sure you hold the plastic insulation so you don't get bit if the ice maker starts cycling remove the wire and watch for it to stop listen for the icemaker valve to open if the ice maker finishes and the valve didn’t fill replace the water valves if the icemaker doesnt cycle and you may have to kind of twist the jumper back and forth to get it to make contact depending on the gauge you used then replace the ice maker motor module if you hear the valve open and the ice maker doesnt fill check for a frozen ice fill tube that should do it
May 24, 2008 | Whirlpool ED2FHEXN Side by Side...
Ice maker flooded the house
how much water we talkin here a cup or gallons?? the icemaker will only call for water after dumping cubes,SHOULD at least, if only a cup of water or so id say the ice maker has an issue and needs replacing(its an entire module), there is a valve behind the machine energized by the ice maker, if htat got stuck open in which case water continued to flow overnight i would repalce both ice maker and valve
Mar 01, 2008 | Whirlpool GD5SHAX Side by Side...
Freezer Problem
The only thing I can think of is your icemaker heater is staying on. When your icemaker goes into a harvest mode, (dumping ice and then re-filling with water) there is a "U" shaped heater (located on the under side of the icemaker) that comes on to release the frozen cubes from the icemaker mold. If this heater is continuously hot, it will cause temperatures in the freezer to rise.
Oct 04, 2007 | Whirlpool GS6SHEXMB / GS6SHEXMQ /...
Ice Maker floods floor and freezer compartment
You may not have got the supply tube all the way into position so I would check this first. If the water is running down the back wall of the freezer compartment at a higher level than the icemaker the problem is not with the icemaker but with some break in the supply chain. If the water is overflowing from the icemaker then it could be the timer cycle on the icemaker or the water inlet solenoid valve at the back of the cabinet (compressor side). Water leaks need to be traced back to the highest point ( I know how obvious that sounds but sometimes we all miss the obvious). Hope this is of some help.
Aug 16, 2007 | Jenn-Air JCD2389G Side by Side...
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
381 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Bruce Denton
Steve Allison
Steve Allison
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
