Question about Kenmore 73503 Stainless Steel Bottom Freezer Refrigerator
Fridge not working
My refridgerator all of the sudden won't cool. It is at 72 degree. The bottom freezer is working fine, it is just the fridge. Please help
  • 1 more comment
  • Anonymous Apr 26, 2008
    my refrige is 77 degrees and the freezer is -2 degrees
  • aewall Jul 12, 2008
    We moved into a new house with this refrigerator. The fridge seems to have beeen working during the inspection...but todays it says its 90+ degrees and it's not cooling. Help?
  • smt1969 Sep 30, 2008
    got an "er" message on my 735033 refrig, along with no cooling and a bunch of bad food. took freezer apart and cleaned all ice around the fan, and is working like new now. it cooled down to 37 dgr's in about an hour. hope this helps
I've had this happen to my Kenmore 73503 several times. The 1st time took me a few hours to figure out what the problem was.
Basically the fridge is cooled from the freezer, so when you say your freezer is -2 degrees, it's a big tip off to the problem.
If you look very close in the freezer compartment at the back, you'll notice an opening with a little door at the top of the freezer compartment. This opening extends up the inside of the back of the fridge to the top of the fridge area via a square plastic tube.
Basically what happens in my fridge is the family loads the freezer to high especially at the top/back. This restricts or closes off the opening for the cold air to the fridge portion of the appliance ....resulting in a warm fridge, but cold freezer. Just remove the articles at the back of the freezer to correct problem. (It will take a few hours for the cold air to cool the fridge down)
Note: the temperature control unit in the fridge area controls the little door at the top of the freezer compartment, so if you haven't blocked off the opening, the next place to look would be either at the mechanical parts of the little door or the temperature control unit itself in the fridge
Posted on Aug 06, 2008
Not making ice
Posted on Apr 03, 2008
Fridge won't cool past 57 degrees
Guessing ether a fan, damper our defrost issue. Sorry cant be much help.
Aug 19, 2012 | Samsung RF266ABRS Bottom Freezer...
Freezer works fine. Refridgerator wont get below 60 degrees.
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jun 08, 2010 | LG 26.0 Cu. Ft. Side-by-Side Refrigerator...
Refridgerator does not get cool enough
Buttom freezer Sub Zero. Replacing evaporator for fresh food section.
Mar 31, 2010 | Sub-Zero Bottom Freezer Refrigerator
Kenmore model 596.72253201. Bottom freezer works, fridge does not
The most likely reason is part number 12566102 Adaptive Defrost control board. The next likely are the defrost heater and the defrost thermostat,Sea Breeze I will send you photos. below
Sep 10, 2009 | Kenmore Refrigerators
Kenmore Elite bottom freezer refridgerator
I just went through this with my refridgerator and actually posted one of the questions. Here is what I found ........
In the freezer compartment behind the panel there is an evaporator fan which pulls cold air from the freezer and pushes it up into the refrridgerator compartment. If the fan is not working it is one of three things.. 1) there is so much frost in the fan area the fan blade is stopped and cannot push the cold air into the refridgerator compartment or the air channel is blocked. 2) there is no electricity going to the fan (usually tied to the door switch of the refirdgerator compartment, and 3) the motor is dead and will have to be replaced.
Solution to #1 - defrost but there is another problem in the "frost-free" part of the system which must be addressed or the frost will return and it will happen again in the future.
Solution #2 - check to see there is power to the fan. (most are 110VAC but some are 100VDC. Use a meter and check)
Solution #3 - If there is power, the motor is dead. Replace the motor. Be aware that AC and DC motors are different and replace per manufacture's specifications.
Feb 21, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer works fine refridgerator does not
problem may be that the return vent from freezer to fridge is blocked with ice. best solution is to switch off for 24 hours with doors open. 2 hours may not be long enough to clear this blockage
Jun 13, 2007 | LG LRBN20510WW Bottom Freezer Refrigerator
Kenmore 73503 Stainless Steel Bottom Freezer Refrigerator Logo
543 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
