Question about Lands Phones
I want to get the front cover off of mw phone, how do i do it without breaking it?
My dog knocked a wood burner into the front cover of a fashion mate 69 stitch computerized machine is there a way to replace the front cover?
Probably. However, the first issue is finding a replacement cover--may have to find a used donor part for that. Second issue is actually getting the old cover off and the new cover on without cracking or breaking anything, ie the plastic clips that hold the cover in place.
Apr 30, 2017 | Sewing Machines
How do i replace kitchenaid superba microwave torsion spring
This is tricky if not done in correct order real easy to break the plastic door frame I will try an explain best I can there is a vent cover between MW door and oven door remove on the MW bottom frame there is a tab on each side with a small screw remove screws you can now pull MW forward won't move very far now the plastic piece that connects to door look up at bottom remove these 2 screws it will be at an angle I use a small speed wrench with a phillips bit okay all this is loose now open the MW door towards top there are 2 holes inside each is a phillips screw use a skinny screw driver hold the door tight it is spring load the frame part with glass will try to slam forward door should now be free usually only one spring is broken change both they are not the same different part numbers take a picture first before trying to remove you will eventually figure out that you have to put in hole at one end and thread thru to the other end then twist in place to lock now be careful if you slip real easy to break inner glass once you figure all this out put the door back in the exact opposite order starting with the door screws first you will now find out the door has a high spring load i usually mate the door to the frame and secure with tape after door is on then do the 2 screws on bottom of plastic frame do the sequence backwards you will break this piece, best i can do yes a lot work but remember I do this about 3 times a week I suggest you think about paying an appliance repair company to do this reason being that plastic piece i keep harping on is roughly 100.00 to replace which negates most savings by doing it your self hopes this helps good luck
Feb 16, 2015 | Ovens
We had a phone where the message light wasnt coming on. I found the fix but now the light is on when a message is left but where I did the fix when you pick up that phone (with prob) receiver then hit the...
Here's the free, don't look in the manual, free answer. You didn't fix anything, you set a message waiting from another phone. Either answer the other phone when you press the MESSAGE button, or dial 700 plus your extension to clear all MW lights. When you first press message, without picking up the handset, look at the display. It will tell you who, or what, left the message.
I don't know why you're using 167 as it's the 3rd set of VM ports, but the VM system needs to send out the MW indications. You can tell the system in 990 to let the VM or the phone system to cancel the MW light.
Carl
Aug 29, 2011 | Panasonic KX-T7433B Corded Phone
How do I remove my ge jvm 1653 microwave?
Clean out the cabinet above the micro wave and you will find 2 or 3 bolts that secure the unit (MW) to the bottom of the cabinet. They will normally be towards the front of the cabinet.
I always put a towel or cardboard over the surface of the range for protection and a place to set the MW once it is ready to come down.
Have someone either hold the MW up by putting pressure upwards on the front of the MW or take the screws out. (don't forget to unplug the MW)
Gently let the front of the MW fall forward about 6" to 8" and lift the back of the MW upwards and it will release from a mount that is attached to the wall.
You may feel a little resistance as it might be duct taped to the exhaust going up or out the back.
Be aware that these older micro waves can be a little heavy and it is recommended that 2 people are used to do this.
Apr 09, 2010 | GE JVM1653 Microwave Oven
Microwave was run for 4 minutes with nothing in it, and the right side, next to the light, burned, from the covering next to the light upward and down into the panel halfway.
yes it is NOT advisable to run a MW without something in it to absorb the MW energy, this has happened due to the signal being reflected back to the magnetron, which has no doubt failed. You will need to repair or replace. get a "Quote" before proceeding. That way you can tell to repair or replace.
Mar 20, 2010 | Microwave Ovens
Was microwaving a hotdog on a paper plate covered by another paper plate and the microwave just kind of went poof and now nothing lites up (display) and it wont work. I checked the breaker it is on and...
Yes there is.
Unplug the MW.
Uninstall from wall mount (if installed that way.).
Remove outer cover by removing the screws at back and (possibly) bottom sides.
Locate fuse. Replace only with an equivalent type and amperage.
You can test the MW without reinstalling or putting the outer covering back on.
Dec 21, 2009 | Kenmore 63672 Convection/Microwave Oven
I want to insert headphone jack and need to
There should be a swing plastic cover on the front underside of the phone for plugging in the headphones line cord plugged in and handset cord plugged in the middle jack is for heanset.
Oct 05, 2009 | Nortel Meridian M3820 Corded Phone
Spring on ice dispenser door came off but I can't get in to fix.
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
Nov 12, 2008 | Roper RS25AEXLQ Side by Side Refrigerator
Removing front cover of Nokia N81
it is best to take the phone and have a professional take it apart for you.
Aug 19, 2008 | Nokia N95 Cellular Phone
Nokia n73 case change
it would be best to let the professional change the case for you......so you will be sure not to have anything broken or damaged.
Mar 21, 2008 | Nokia N73 Cellular Phone
Lands Phones Logo
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
