Question about Zenith R50V26 50" Rear Projection Television
Blue adjustment wont adjust
The other day I noticed that my screen looked like it was misaligned and so i went to the ez-focus and adjusted the red but when I went to the blue it wont move and the blue seems to be bowed in the middle can i fix this and is there a perceedure to check this out any help would be appreciated
  • 1 more comment
  • Anonymous Mar 28, 2008
    Have the same problem the top 2 adjustment on the upper left corner. The blue wont adjust. Where can I get the IC for a Zenith R50v26 unit.
  • twluv13 Aug 01, 2008
    My tv went out last week like the color alignment or something, i had it fixed at a tv shop but now i notice a slight red in the top left corner, i dont have the original remote so i cant do the ez focus? Unless there is another way to do that? Where can i get a remote that will work, or is there a way i can fix this without it?
  • mota44 May 12, 2009
    i changed the 2 IC 's and got the center cross to aline pretty good but the outer edge crosses wont aline is there another way to adjust these?
Ez-focus will not adjust the blue in upper middle and bottum middle
Posted on Oct 23, 2008
  • Zenith Master
  • 8,617 Answers
You will need to change the convergence IC. they are cheap so its better to change both at the same time as the red is sure to follow soon. Also check the resistors that power the ICs as usually one or two go open when the IC goes out.
Posted on Mar 22, 2008
Blue will not focus causing "shadows". Magic focus will not solve the problem.
This tv have a problems call convergence,it dead.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts must be replaced to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jun 17, 2010 | Hitachi 53FDX20B 53" Rear Projection...
Blue outlines on screen. not a screen burn or convergence problem
I am not familiar with that particular model but most are similar.
It may need the blue focus adjusted. Most tv's have some type of automatic focus. If the blue is out of focus it can "bloom" beyond the red and green. There should be a focus block with 6 adjustments (2 rows of 3) behind the speaker cover. I wouldn't mess with the one labeled screen or block. Adjust very carefully. They are usually in the order Red-Green-Blue with the focus on the bottom row.
Mar 02, 2010 | Panasonic PT-47WX53 47" Rear Projection...
I cant get the color right. its to red??? any help? i did notice with the back cover off, there are 6 adjustment screws
yes! those are the screen and focus adjustments. 3 for screen, 3 for focus. try this. go in menu....turn down color, brightness, contrast all they way down. you should then have no picture, but in your case a little red. then go to back of tv and turn those 3 screen adjustments all the way down. slowly turn the screens back up until you get barely a picture. because remember, your brightness and contrast is all the way down. the picture should be dim but seeable and with red, green, blue adjustments, make it a black and white picture. when balanced..... turn up color , brightness, contrast in menu. enjoy!
Nov 14, 2009 | Philips Magnavox 9P6034C 60" Rear...
Hitachi 53UWX10BA dynamic convergence works but blue is blurry
I know this set very well---you are saying convergence adjusts ok everywhere? If you understand that the blue is usually de-focused a little----there are only two ways to adjust the focus of each tube-----
1.) Behind the front speaker grill there is an inspection plate---with it removed you will see a small black plastic block with 6 controls on it; it is the MASTER SCREEN/ FOCUS BLOCK
2.) THREE of the controls left to right are Screen controls(red, green and blue) and the other 3 are FOCUS--IT IS ALL black and you need to look close to identify which is focus and which is screen---you are looking for the BLUE focus control(one of the 6)
3.) With the convergence grid on screen cover the RED and GREEN lens in the set and try to adjust the focus of the blue(I presume you know how to put the set into the Convergence mode?
4.) The only other way to adjust the Blue focus is from the back of the set---with the Red and Green lens covered up place a blanket over the top of the set that covers the whole screen--from the back of the set you will note that all three of the black focal lens have a wing nut---with the convergence grid up and only blue lines present(Green and Red lens covered with a cloth) look from behind the set at the grid---loosen the wing nut on the blue lens and slowly slide the lens left or right until the blue has the best focus possible----if it will not adjust with the focal lens or the front focus control you have a circuit problem.
I do this here for free and if this information helps you take a minute and give me a vote here. If you have any questions or need advice reply to this posting here and I will assist you.
SD TECH
Sep 14, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Mitsubishi Convergence issue
If the screen is out of focus you probably need to adjust the focus on the focus block it is usually located behind the front grill, there are 6 adjustment screws on this block, leave the screen controls along just adjust the red, green, and blue focus screws. When converging a set everything is converged to the green, the blue and red are suppose to come to the green.
Sep 02, 2009 | Mitsubishi WS-65311 65" Rear Projection...
Red horizontal curvy lines
You need to turn the voltage on the red tube down slightly, also you would need to adjust focus to compensate for the lower voltage to the red tube. On the left and right bottom side of speaker cover are two round covers, take them out and there are 2 1/4" hex screws take them out carefully take cover off, there is another service cover same hex screws remove. You will see the focus block on the right side, tubes are labled on block. 2 knobs for each tube. Make voltage adjustments while tv is on a black screen, then for focus, turn color all the way off in the menu, and adjust focus until it looks right in black and white. These adjustments should only be very small; if alot of adjustment is needed, you may have other issues.
May 29, 2009 | Sony KP-51WS500 51" Rear Projection...
No blue just red and green tint
adjust the blue bias on the high voltage block .
it has focus and bias for all three colors
Dec 26, 2008 | Samsung PCL5415RB 54" Rear Projection...
Samsung Rear Projection Problem (not convergence)
The tv has 2 focus adjustments for each tube, mechanical and electrical.
1. Mechanical focus is set by looking at screen from back (through inspection plate on back of most samsungs) and rotating the lens assembly on CRT. loosen wing nut and turn lens assembly to go through focus and back to best position.
Put convergence pattern on screen and manually misadjust bottom red and green lines convergence so they can be seen through inspection hole.
With back cover of TV off you can usually reach your hand up beside the lens assembly to loosen the wing nut then rotate to adjust. Green is in the middle. The focus will be obvious when you rotate and look
When you are finished make sure the foam dust protector is not over any of the lens assemblies and the wing nut is tight.
2. Electrical focus - located at front of unit. the front grille/speaker cover is removed and maybe a cover over the front crt inspection hole.
In the inspection hole there is a black plastic "Focus/screen adjust Assembly" with 2 rows of 3 controls.
One row is focus and the other is screen. The middle controls are for green with R/B on either side. Usually the controls are labelled as "focus" and "screen". You want to adjust the focus controls, one for each color. Look for the focus or screen label imprinted in the plastic. Don't play with the screen settings.
With the same misadjusted convergence pattern you can see a red, blue and green line. Adjust green focus and watch green line for best focus. Do same for other 2.
Screen adjustments are very exact and delicate. The easiest way to deal with them is to turn color off in Customer adjust menu. Put any color tone adjustments in the middle (low, med, high, put at med).
You should have a b/w picture if there are no crt or other color related faults. If it is close to B/W leave screens alone.
If the pix is too green, then the green screen setting must be reduced a small amount. Do not play with these adjustments as most TV repairrers have a difficult time adjusting them.
If focus adjustments don't help then focus control or CRT may be defective. Needs expert to determine.
easyab
http://calgaryconvergencerepair.weebly.com/convergence-ics.html
Jun 24, 2008 | Samsung HCM4216W 42" Rear Projection...
Jvc av56wp74 blue shadow
my suggestion would be...to replace the focus block..john
Aug 10, 2007 | JVC AV-56WP74 56" Rear Projection...
Jvc av56pw74 blue shadow
You are going to need a full convergance alignment to rectify this issue.
Aug 09, 2007 | JVC AV-27720 27" TV
Zenith R50V26 50" Rear Projection Television Logo
198 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
