Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GEW9200LQ0 Dryer
All lights are on but will not start. When start button is hit, you hear 3 beeps as if dryer door is open - but it is closed.
    President:
  • Whirlpool Master
  • 2,651 Answers
Can oyu oppen the door nad physically push in on the door switch( little grey switch atop the door opening). do you hear it clicking on/off??? if not you have a bad door switch.
Posted on Mar 24, 2008
I have a whirlpool duet gas dryer model ggw9200lw1. when i press the start button it clicks once but wont run.
First, check the door switch. Push and release it by hand and you should hear a click. If no sound, replace the door switch with this part.
If the switch is ok, press the cancel button on the machine. Then do this. press and hold the start button for 2 seconds then release wait 2 seconds and press and hold again for 2 seconds continue this pattern until the dryer goes into test mode. You will see all the lights on the control light up. press each button on the control one at a time 3 times each. (Do not press the cancel button) until the dryer begins to run. When the dryer starts to run then press the cancel button. Then your machine should function properly.
Oct 19, 2012 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Cycle light flashing. won't let it start. when i hit start button it beeps 2 times quickly
Very common issue, check the door switch when you press it in you should hear a click, If you have a volt meter we can walk you through this repair.
http://www.appliancerepairlesson.com/
Mar 01, 2011 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
My whirlpool duet dryer will not start. Power
You have to slam the dryer door shut. Sounds silly... but it worked. Guy said it has to do with it being stacked??
Jan 11, 2010 | Whirlpool GEW9250 Electric Dryer
Beeps but doesn't start
Duet dry lights up, hit the start button and it just beeps and lights flash. but will not start.
Mar 01, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool Duet GGW9200LL1 will not start
The electric flash does not sound cool, It sounds like you have a door switch problem. Check to see if the door switch button is in tact. If it is , you may have to go after the door switch itself. Try this, press more time, less time, more time, less time buttons in that order, the whole panel should light up, open the dryer door, you should hear 1 beep and OE displayed, If you have this the door switch is ok, Catriver
Jan 14, 2009 | Dryers
Whirlpool Duet Steam Dryer Beeps 3 Times But Does Not Start
Brand new unit - same problem. After an hour of investigating, I found the issue.
You don't actually have to SLAM the door. If you look closely, there are 3 separate pins that must latch. One is a simple push-button style which latches no problem.
The others are little prongs at the top and bottom of door. The bottom prong latches cleanly, but the top one will not latch because the door is a bit too flexible.
Close the door normally, then firmly press on the top edge of the door. You will hear the final latch grab, then you press and hold the start button. The dryer starts normally.
Yay!
Nov 02, 2008 | Dryers
Whirlpool duet dryer won't start
whirlpool duet dryer has power but will not start--when I press start, it beeps once and the sensing light comes but the dryer doesn't start
Nov 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Dryer just says beep beep beep everytime I push start
sounds like you may have a bad door switch(mach thinks door is open when it is not).open door and look on front panel that door pushes into.you should find a small button covered in a grey rubber boot.push on it and listen for a click,if u dont hear a click the switch is bad.if u do hear a click it could still be bad or you can have a open thermal fuse
Sep 29, 2008 | Whirlpool GEW9250 Electric Dryer
Whirlpool dryer,duet
check the door switch for operation, if the machinr thinks the door not closed == no operation
Jan 11, 2008 | Whirlpool GEW9250 Electric Dryer
Whirlpool Duet GHW9150P Front Load Washer Logo
298 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
