When I start Giga Pocket I get an error: gp666 cannot launch-Giga Pocket data base might be damaged. I have re-booted, reinstalled and loaded Giga Pocket update utility 5.5. Verified that Vaio media video server was started. I used msconfig to disable services snd startups and rebooted in safe mode. Result: error-failed to open sony tv tuner device. I tryed Knowledge article #C286679, no success. Roger
  • 2 more comments
  • viper69 May 04, 2008
    I downloaded Giga Pocket update utility 5.5.from sony Verified that Vaio media video server was started. Result: error-failed to open sony tv tuner device. I tryed Knowledge article #C286679, no success win xp
  • Anonymous Jun 22, 2008
    y have the same crazy problem of error message gp 666 (and RMAN 3526 ) and just after a new complete installation of a diSk VAIO for SONY ;
    So y have not reinstalled other programm ( non VAIO ) which could be responsable of an immediate conflict .
    wihat can y do????????
    thank you of a response in my BAL : jean-michel.navette@wanadoo.fr
    nota bene: the problem disappear when an externel DD isconnected with de PC!!!!!!!!!!! but it's not a solution
  • Anonymous Oct 08, 2008
    "failed to open sony tv tuner device" still appears even after i moved the giga folder into a temp folder as suggested in an earlier post. any thoughts? thanks.
  • islandsailin Oct 23, 2008
    "failed to open sony tv tuner device" error msg when i try to open vaio tv.
    have renamed file...nada. thanks. js
This one took me a while to figure out as I had the same problem.
The answer is rename/delete the D:\GigaPocket directory and restart GigaPocket. It will regenerate the directory and will work fine....or at least mine did.
Have fun
Wingblur
Posted on Aug 20, 2008
  • 4 Answers
After a long time of suffering problems with Giga Pocket randomly failing to load and having to re-install the whole thing time and again, I have at last discovered a solution. The main culprit is USBSIRCS.EXE failing to run at startup.
If Giga Pocket 'hangs' then check to see if USBSIRCS.EXE is running, by pressing CTRL-ALT-DEL and looking at Processes. If it is not then that is almost certainly the cause of the problem.
The solution is simple. Locate the USBSIRCS folder in c:\program files\sony.
Now copy each of the .dll files in that folder to c:\windows\system32.
Make sure USBSIRCS.EXE autoruns at start-up by checking MSCONFIG. If no entry is there, paste a shortcut to the program in the Startup folder.
If your Giga Pocket stops displaying video, do the above and either re-boot, or once the steps above have been completed, and you have closed the non-functioning Giga Pocket program, just double click on USBSIRCS.EXE and GIGA POCKET should then work immediately.
Posted on May 23, 2009
Wingblur's Solution #3 posted on Aug 20, 2008 works! Rather than delete or rename the existing folder (D:\GigaPocket) I moved it into a "Temp Folder for Giga Pocket" folder. Then restarted GigaPocket and no more GP666 database error!! This was definitely a 4-star "FixYa" !!!!
Posted on Sep 30, 2008
Here is the perfect fix. Sony's GigaPocket software wants to load the main program on your C drive but must have a D drive to install the (example) D:\Giga Pocket V5 folder (which is where the video capsules are stored). The reasoning behind this is to help your C drive run more efficient and faster by storing large recorded video capsules on a different drive other than the C drive. If you want to reload this program back on your system because, say maybe you got a larger/newer hard drive, you'll have to partition the new drive to accept this necessary folder (which is the database for Giga Pocket) or you will continue to receive the GP666 error message. It will work just like it did on the old hard drive. Good Luck.
Posted on Jan 20, 2010
How did you either create or locate the Giga Pocket Temp Folder? When I create a folder then I get an error which tells me "can't locte Giga Pocket program" reinstall from the CD
Posted on Oct 09, 2008
Can giga pocket run on a compaq?
Posted on Aug 11, 2008
    Problem Solver:
  • 12 Answers
It might have driver confilcts. what is you os platform?
Posted on Mar 22, 2008
2 Suggested Answers
SOURCE: Sony Giga Pocket, error: GP666-computer pcv-rs 430G
I had this problem and I renamed the GigaPocket V5 directory and restarted Giga Pocket. No more problems with GP666, now I just need to learn how to re-import the old videos into the cabinet.
Wingblur
Posted on Aug 21, 2008
I have an hp dv9925nr laptop running vista home premium 64. I tried to reset to factory settings and now when I try to start up I get a boot manager error. It says \boot\bcd status 0xc000000f error...
Most of the boot up of problem because of hardware problem, registry missing or crashed, file deleted or changed.
You can boot up your Windows with Tenorshare Data Recovery WinPE.It allows users to burn ISO file to CD/DVD/USB flash drive directly.
Step 1: Download Tenorshare Data Recovery WinPE in any available computer (not from PC that can't boot up). Then launch it.
Step 2: Insert CD/DVD/USB flash drive to the computer, choose ISO image file. Here we take USB flash drive for example. Then burn ISO file into flash drive.
Step 3: Insert the burned flash drive to the unbootable PC. Run computer and press "F2", "F10" or "Delete" to enter BIOS setup.
Step 4: Use the arrow keys to select Boot tab, select Boot Device Priority and press Enter. Please choose 1st Boot Device to USB, and then press F10 to save setting. Now,you can boot up your PC.
If you have a backup for your Windows then perform a system restore to fix it.If not,reinstall it.If you have no backups for all your data,you can use Tenorshare to retrieve data under any boot up problem.You can get it from http://www.any-data-recovery.com/product/datarecoverywinpe.htm
Here is tutorial to guide you how to do --How to Recover Data from Computer Won't Boot Up?-Windows Data Recovery.
Sep 19, 2011 | HP Pavilion dv9925nr Notebook
NTLDR is missing is displayed when i turn on the computer
The "NTLDR is missing", error displays very shortly after the computer is first started; after the Power On Self Test (POST) is complete. Windows XP might only initially load when the NTLDR error message appears. Causes of this error message include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors, an outdated BIOS, and damaged or loose IDE cables.
Get more help and information for Windows XP hope this helps you.
Mar 01, 2011 | Microsoft Windows XP Professional
Having a problem with dimension 3000 destop. I turn on the computer and it will proceed to the XP loading screen then the picture will go black and won't return. Using AOC 23inch monitor.
A critical file needed for the launch of XP is missing. To see it can be recovered try to boot in Safe Mode. If you can the reinstall all the drivers and check every program for errors - launch them and see how they behave. If you can't boot in Safe Mode the the only thing left is to reinstall.
Dec 17, 2010 | Dell Dimension 3000 PC Desktop
Sony Vaio RS-530G. Have recovery disk. Did recovery a few years ago but "think" did not install "giga pocket," but now want it installed. Probelm is, after loading recover startup it asks for disk 1. ...
Running your install disk will place a new OS on the drive and if what you want is on the disk, that as well. Make a backup of your data first then restore it all.
Jul 24, 2017 | Sony VAIO PCV-RS530G PC Desktop
Giga Pocket GP666 error!!!
It means renaming the folder GigaPocket V5, in C:\Program Files\GigaPocket V5. I am basing my answer on the details you have given me, If you have any problems do not hasitate to contact us again.
Jul 08, 2009 | Computers & Internet
GIGA POCKET TV TUNER NOT WORKING
PROBLEM SOLVED. APPARENTLY THE GIGA POCKET PROGRAM IS AFFECTED BY THE SONIC STAGE MUSIC PROGRAM OF SONY. I RE-FORMATTED AND DID NOT INSTALL THE VAIO MEDIA AND SONIC STAGE SOFTWARE ...
THE TV TUNER NOW WORKS FINE ....
I JUST USE WINDOWS MEDIA PLAYER AND WINAMP FOR THE MUSIC ....
NO REMOTE CONTROLS ... BUT THE TV TUNER WORKED .... ONCE MORE ....
May 19, 2009 | Sony Computers & Internet
Re-Loading Software
Since they installed a generic copy of xp, there are none of the sony installed add-ons present on the computer. go here to view the available downloads for your system provided by sony, you will have to select the "EVERYTHING" tab to see the giga downloads if it does not load there.
Otherwise you will have to contact sony for a recovery disk specific to your system.
Oct 08, 2008 | Sony VAIO Digital Studio PCV-RZ22G PC...
When I boot my Sony Vaio, I get an error message something like 'unexpected interuption program usbsircs.exe'. I located this file at c:\program files\sony\usbsircs\usbsircs.exe. I have been deleting...
Unistall the Giga Pocket Recorder by going to Control Panel=> Add/remove programs & then reinstall again if you have the setup program with you.
Hope this helps you..
Jun 21, 2008 | Sony Computers & Internet
Wingblur
Mar 25, 2008 | Computers & Internet
Sony VAIO PCV-V100G PC
yes reinstall the tv tuner software.
there might be some other applications conflicting the same.
Feb 04, 2008 | Sony VAIO PCV-V200G PC Desktop
Computers & Internet Logo
2,484 people viewed this question
David Payne
David Payne
