Printing WHEN I TRY TO PRINT FROM INTERNET I AM ONLY GETTING WHAT LOOKS LIKE SOME KIND OF COMPUTER SCRIPT BUT NO PROBLEMS PRINTING FROM MY DOCUMENTS.
  • atthaullah mohammed May 11, 2010
    can you tell me your printer model and your installed os
  • 148 Answers
Same youe documents to window application such word or excel
Posted on Mar 23, 2008
Keep printing old docoments / will not print current docoment / printing seem to be strunt
Follow these steps to fix your problem :
Method A :
Press the cancel button or use the cancel menu command on the printer
The most obvious way to cancel a print job is to find a cancel button or a cancel menu command on the printer and to press it. So, if you have not already done this, try this method first.
If this method worked for you, you are finished with this article. However, you may want to read the "Prevention tips" section to avoid this problem in the future.
If your printer does not have these items or if this method did not work for you, try Method B.
Method B:
Turn the printer off and on
Next, try turning the printer off and then on. With certain printer models, this cancels the print job.
If this method did not work for you, turn your printer off, and then try Method C.
Method C:
Use Control Panel to cancel printing
This method is a bit fancier. We will use Control Panel to try to cancel printing.
But what exactly are you trying to do? Are you trying to cancel printing only a single document, or are there other print jobs that you want to cancel? And are all the print job yours, or are there print jobs that other people have sent to the printer? If you have to cancel documents that other people have sent to the printer, you must have Computer Administrator status or you must have permission to cancel the print jobs. If you are using your own printer, you most likely have Computer Administrator status. If you are printing to a shared printer, you might have to ask the system administrator to cancel the print job for you.
To cancel one or more print jobs, follow these steps.
1. Click Start, and then click Run.
2. In the Open box, type control printers, and then click OK.
3. Right-click the icon for your printer, and then click Open.
* To cancel individual print jobs, right-click the print job that you want to cancel, and then click Cancel.
* To cancel all print jobs, click Cancel All Documents on the Printer menu.
Note If you cancel a print job that you did want to print, make sure that you send the print job to the printer again.
If this method did not work for you, make sure that your printer is turned off, and then try Method D.
Back to the top
Method D: Stop the print spooler and delete all spooled files
If you tried Methods A through C and you were not successful, Method D should work for you. If you came to Method D immediately only to delete a print job, some of what we say here might not apply to you, so please bear with us.
Method D is somewhat more complex and will require a bit more work than the other methods, but don't worry. Method D looks much more difficult than it really is.
First, in case that you don't know how printing works, here is a short explanation. Print jobs are sent to the printer as spooled files. This means that the files are put in a temporary location so that the printer can access a print queue and print jobs at its own speed. If you stop the spooler and its files, most of the time, you both cancel printing and delete the print job.
Note To use this method, you must have Computer Administrator status. If you are using your own printer, you most likely have Computer Administrator status. If you are printing to a shared printer, you might have to ask the system administrator to cancel the print job for you.
Step 1: Start Notepad
To stop the print spooler and its files, we will have you create and run a script file that will automatically stop the service. This sounds difficult, but it really isn't. Just follow these steps carefully.
2. In the Open box, type notepad, and then click OK. Notice that a blank Notepad document opens.
Step 2: Copy a command script to Notepad
Now we will have you copy and paste some commands to the Notepad document.
1. Carefully select (highlight) all the following text:
net stop spooler
del %systemroot%\system32\spool\printers\*.shd
del %systemroot%\system32\spool\printers\*.spl
net start spooler
2. Right-click the text that you selected, and then click Copy.
3. In Notepad, right-click in the blank document, and then click Paste.
4. Carefully select (highlight) all the following text:
C:\DeletePrintJobs.cmd
5. Right-click the text that you selected, and then click Copy.
6. In Notepad, click Save As on the File menu.
7. In the File Name box, right-click, and then click Paste.
8. Click Save.
Step 3: Run the command script file
Now that you have created the command script file, you will run it. To run it, you will copy and paste the name of the command script file in the Run box.
3. Click Start, and then click Run.
4. In the Open box, right-click, and then click Paste.
5. Click OK.
6. Notice that the Command Prompt window opens to run the command script file that you created. Notice also that this window closes automatically when the command script file has finished running. If you do not see the Command Prompt window open, check that you saved the command script file by using the correct name and that you entered the correct command script file name in the Run box.
If this method does not work the first time, or if you cannot print anything after you use this method, restart your computer, and then try again.
Nov 20, 2010 | Lexmark X2500 All-In-One Printer
How do i cancel a print job?
Method A: Press the cancel button or use the cancel menu
loadTOCNode(2, 'resolution');
Method B: Turn the printer off and on
Method C: Use Control Panel to cancel printing
printing.
steps.
    • To cancel individual print jobs, right-click the print job that you want to
    • To cancel all print jobs, click Cancel All
If
future.
files
us.
it really is.
print job.
loadTOCNode(3, 'resolution');
    net stop spooler
    del
    del
    net start spooler
    File menu.
    then click Paste.
    Note Notice that
    this file name differs from most other file names that you might have seen. That
    is because this file is a command script file.
  8. Click Save.
    click Paste.
  5. Click OK.
    Run box.
Note If this method does
Oct 08, 2010 | Pitney Bowes AddressRight DA300 Printer
Printing VERY slow for PDF documents on DP-8045
well if you really needed a pdf printing concern, you may add an option which is Multi Page Description Language Controller Module. the post script printing language will be activated and you won't have to wait for the computer to process the pdf document on a gdi format (microsoft). what's more is that your mac computer can also directly print to the dp-8045.
that's it
Apr 30, 2010 | Panasonic DP-8045 Grayscale Copier
Can't print from the internet but will print emails and other documents saved on my computer
I understand your concern that you are unable to print from Internet explorer. To resolve the issue you need download and install the HP smart web printing software. Click Here for the HP smart web printing software and select your Operating system and download the software.
May 22, 2009 | HP PSC 2355 All-In-One InkJet Printer
Prints java script instead of highlighted page
First, you probably should not stop the printer after it starts printing, it always creates problems. Second, you should clear your browser history and then you should select the range of pages to print on your print properties menu. If this does not work try reinstalling the print drivers.
Dec 13, 2008 | Brother MFC-210 All-In-1 Print/...
Won't print
We need to first check whether we are experiencing this issue while printing from all the applications in the computer or only from Internet explorer. If you are experiencing this issue only while printing from Internet explorer, then download the smart web printing from the HP website and then run it and try to print.
Please open the below webpage to download the smart web printing
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3551212&lc=en&cc=us&dlc=en&lang=en&cc=us
If you are experiencing this issue when printing from all other applications, then refresh or restart the print spooler and then try to print.
Mar 01, 2008 | HP Officejet 7130 All-In-One InkJet...
Printing PDF files
I had this problem after I had fixed a problem printing from Quicken. I was able to print from Quicken by changing the print option in Windows -- mine was set to "Spool documents" and I changed it to "Print directly from printer" -- the advice I was given was to change it from whatever it was set at to the other option. For printing a PDF file, I changed it back to "Spool documents" and it allowed me to print the PDF file. Try this and see if it works for you -- click the Windows Start button and select Settings, then Printers and Faxes. Right click on the selected printer and select Properties. In the properties window look for a setting to print directly to printer or spool documents -- mine was under the Advanced option. Try the option not currently selected -- in my case, I changed it back to Spool documents with Begin printing immediately -- and then try to print a PDF file. It looks like I will have to toggle back and forth when I am printing from Quicken and when I am printing a PDF file. Hope this works for you.
Mar 01, 2008 | HP Photosmart C6180 All-In-One InkJet...
Printing
your probably printing from internet explorer/website?
on internet explorer go to tools -> internet options-> advance tab
and check "disable script debuging"
thanks for rating
Jan 11, 2008 | E-Machines eMachines Desktop PC
Printing from the internet or e-mail
TO isolate the problem you can do a print preview and see if if looks good before printing.
If it does look correct before printing try
1) Sounds like there was a communication problem between the printer and computer.(IF the printout is garbles characters)
Typically you need to
a) Delete any existing print jobs.
b) Turn off printer.
c) Verify all cable connections to printer.
d) Power on printer
Try printing again...
or
If print previw showed "Code"
If the print out is "HTML Code" make sure you are not selecting "view source" and printing it...
Nov 20, 2007 | Canon PIXMA iP1600 Printer
56 people viewed this question
k24674
