posted by jimbob362008 on Mar 22, 2008
My amp has developed a problem primerily with its right channel output it will work fine then just loe its sound i will then adjust the volume with the volume control and the left side crackles then both sides will start playing again i really like this amp and would appreciate any advise many thanks jamie
Solution #1
posted on Mar 22, 2008
Hi Jimbob. Sounds like you have dirty/dry controls/switches. The contact lubricant dries out on them producing intermittent and scratchiness when you operate them. Clean any offending controls or signal switches with CRC2-26 by squirting(to flood then internals) each control/switch. you will have to do this from the inside of the amp. You may also have a dirty speaker protection relay, sound may return to a dead channel when you turn the vol up points to that. Good Luck. If you need more info feel free to get back to me here. Happy to talk you through more if you cant sort it out.
regards
Graeme
regards
Graeme
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Sony TA-FE370 2-Channel Amplifier
Email this problem
Email this problem
Can you Help with these Amplifiers and Preamps problems?
remote codes for sansui audio...
I have an older sansui stereo... Answer This...
Repair Service
Find Amplifier and Pre. Repairman Near You:
