Question about Acer AL1912B 19" LCD Monitor
Sporadic Discoloration & Distortion
I have had this LCD monitor for a while. After using it for about a year, it started to have short periods where the colors on screen would sporadically discolor in odd patterns. These initially short periods became longer and more severe, eventually reaching the point where the screen would become severely distorted and scrambled. Nothing I did seemed to help, and eventually the monitor became unusable and I shelved it.
About 6 months later I reconnected it on a lark, and it worked fine again! After another few months now though, it is beginning to act up again, getting gradually worse just like it did the first time. Disconnecting it from the computer and power sources for a day or two at a time does not seem to help, and I do not leave the monitor on as a habit.
    Sergeant:
    Champion:
  • 333 Answers
Most of these monitors have a 3 year warrantly. Give them a ring and see if they will exchange it. No harm in trying!
Posted on Apr 04, 2008
Hi, I started to have an issue with a display of my Tecra M5. The laptop is 2 years old and there has been no problems with it before.. Last week I attached a 32" LG LCD TV to my Tecra as an...
the 32 inch LCD may have a lower display resolution that the LCD on your system. Ensure that the display settings for the LC are at the MAX resolution and 60 htz
Jul 31, 2011 | Toshiba Tecra M5-S433 Notebook
My monitor is making a electronic sort of distortion noise (sizziling). Anyway to rectify it?
Check the security of the power cord and look for damage to the plug and moulded plug, see the pins are in tight, vheck the plug socket on the monitor to see the reccieving pins are not bent or damaged.
After that, the issue lies in a short or developing short on the board, if you notice any smell (burning plastic ), you should stop using it and get it tested and repaired
Jan 06, 2011 | ViewSonic VX2235wm LCD Monitor
My monitor is making a electronic noise
u have a problem with electornic circules
Nov 04, 2009 | ViewSonic VX2235wm LCD Monitor
My monitor goes to sleep all the time it is very frustrating
Go into Control Panel, then to Power Options.
In XP, you see a selection for Turn Off Monitor. Adjust that setting as desired.
In Vista, you'll see Choose when to turn off display on the left side. Choose that option and select the desired time setting to turn the display off.
Oct 03, 2009 | HP w1907 LCD Monitor
Sporadic signal -- loses visual-goes blank then resumes
Check your cable between your monitor and computer first. Otherwise you either have a faulty video card or monitor. If you are using an LCD monitor it will most likely be the card. If you are using a tube style monitor I would start there first. Borrow a monitor from a friend and see if it continuse to happen.
Jul 11, 2009 | Computers & Internet
Sudden color/picture distortion
you have a shorted green CRT that is affecting the other crts the short is internat to the crt that leaves what is called retrace lines. if the set is more than three years old then replace all three guns.
Feb 25, 2008 | Samsung TX-R3080WH 30" TV
793S 17" CRT Monitor Problem
Have X2gen LCD Monitor with the same type of problem.
Take apart the LCD screen and reseat all ribbon cables. Make sure they are connecting right. I found a black wire on one ribbon cable that was not seated in the connector correctly.
RESEAT ALL CONNECTORS carefully to avoid breakage.
Look for discoloration on all connectors to see if they was an overvoltage to a short causing the screen problems. If you see discoloration you know you have the connector they cause your screen problem.
USE A GOOD LED FLASH LIGHT. UNPLUG MONITOR PUT IT IN YOUR LAP AND FIGURE OUT HOW TO FIX IT, YOURSELF.
Jan 27, 2008 | Samsung 793S 17" CRT Monitor
Samtron 95P CRT Monitor
this caused by one or more capacitors on the horizontal circuit
Nov 09, 2007 | SAMTRON 95P 19" CRT Monitor
Acer AL1912B 19" LCD Monitor Logo
169 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
