Question about Microwave Ovens
Roper Double Wall Oven
1986 Roper built-in electricwall oven. The door will not stay closed. The door sprung on the top oven.
  • 53 Answers
sounds like you may need new hindges, unfortunatly they may not be available any more, it may be time for a new oven.
Posted on Mar 23, 2008
Why doesn't it work until I push up on the door just a bit?
There is a safety interlock that the door actuates that lets the oven run. If the door is bent, the interlock switch is not in the right position and the oven does not think that the door is closed.
There is not usually an adjustment on the interlock stud. You might try to re-align the door.
Aug 30, 2015 | Frigidaire Microwave Ovens
I have a whirlpool oven. I ran the self cleaning cycle,let it cool down for a day and ride to open the door. It wouldn't open. I then cycled the circuit breaker and tied again. No good. There appears to be...
sad to say but way too many of us have gotten lazy , even I do at times but self cleanings ovens have always been a problem. the excessive heat required is costly and burns up many elements among other things
Oct 29, 2017 | Whirlpool RMC275PVQ Built-in Microwave...
Microwave door warning light
If this is a built-in wall oven with microwave on top, it is probably the 20-amp fuse located above the microwave. It is wired in series with 1 of the door switches, hence the "door" message. The only problem is that you have to pull out the microwave oven (at least part-way) to be able to get to that fuse.
Dec 08, 2013 | Kenmore Microwave Ovens
I ordered and received a replacement door for my 2002 spacemaker ge microwave. The lady I spoke with said I would be able to install it myself. I figured there would be directions in the box explaining...
HELLO.
Below is the solution to replace your microwave door.
Unplug the oven from the outlet and/or shut off the gas valve. Open the old door completely and unlock the hinges by pushing the hinge out toward you and down toward the door. Slightly close the door and lift the door up and toward you.
Install the new door. Make sure the wall oven door hinges are aligned to go into the rectangular wall oven slots. Place the hinges into the slots. The hinges should "catch" on the slots comfortably.
Ensure the door is fully opened and push the hinge locks into an upright position. The two hinge locks should rest on top of the two hinges that are inserted in the wall oven slots.
Close the door and open it several times to make sure the door is properly opening and closing. Replug the oven back into the outlet and/or turn the gas valve back on.
Thanks.
Sep 25, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
SAMSUNG MICROWAVE, MODEL SMH9187ST, WHEN NOT IN USE, WE HEARD A SMALL NOISE (CLICK) AND THE DOOR OPENED. THE DOOR WIL NOT LATCH AND STAY CLOSED. I CHECKED THE TWO FUSES, THEY ARE GOOD. WITH THE...
Hi dschema,
You have a door switch issue. There are three behind the panel. If you can lift and hold the door and it starts one of them is bad for sure. You would be better off replacing all three or have a repair man replace them because a microwave can hold 3000v even unplugged.
Hope it helps.
Thank you for using FixYa.
Aug 20, 2011 | Samsung SMH9187ST Microwave Oven
I have aa brand new panasonic microwave oven. The door seemed sprung, you had to lift it slightly to get it to close. After using it last night, and slosing the door the interior light stayed on.... how...
Either the door or the door switch mounts need to be adjusted.
Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
You can find an authorized Panasonic servicer here.
Jan 08, 2009 | Panasonic NN-P794SF Microwave Oven
My lower oven does not work; top oven works fine
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Thereshould also be a "mini-manual" (tech sheet) hidden inside the unit behind thecontrol panel or hidden inside behind the back cover, etc., and it's very helpful when troubleshooting, testing, and locating components.
Nov 24, 2008 | Microwave Ovens
I have a double roper oven Model #39758B0 Serial # 8Roo896 Problem when turning the top oven on I get an F-5 signal and the oven does not turn on. I need to know how ro fix this problem. Thank you, Rita...
My problem is with a roper double wall oven not a micowave. When turning the top oven on I receive a F-5 signal and the oven does not turn on. I misplaced my manual hoping you can solve this problem or send me the manual.
Thank you,
Rita
Sep 16, 2008 | Roper MHE14XKB Microwave Oven
Microwave Ovens Logo
217 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
