Question about Crosley 4-in-1 Entertainer CD Shelf System
Crosley turntable problem
Tone arm will not swing back into off position and rest in the turntable arm holder. Will only go as far as the edge of the spinning platter. So, the only way the unit will shut off is turning it off at the phono switch on the front of the unit. I have applied some pressure to try force the arm into the rest, but it will not go and I do not want to push it so hard as to break the arm. Any ideas?
  • dklobo117 Mar 30, 2008
    Thanks for all the help. When I took the unit apart and looked under it I found the linkage that connects the speed selection switch with the tone arm was not aligned properly. Once it was aligned properly, the unit worked just like new. Thanks again.
    Genius:
  • 1,027 Answers
  1. Check to see if at the base of the tone arm where it goes into the base of the unit the "cue" plastic riser is not out of position.
  2. Check to see if the "record size" is properly set, as this will prevent tone arm from returning properly set.
Posted on Mar 22, 2008
    Brigadier General:
  • 3,614 Answers
~ .j
  • 3,037 Answers
Some internal component is obviously stuck or malfunctioning, You can open it up and check the movable components, if under warranty, I would call the company first. Otherwise if you are like me, you would open it up and start trying to figure out what isn't working, maybe a gear is having problems, I'm sorry but without looking at it myself I don't know for sure since the arm does move, which means the motor can't be bad, maybe the alignment is off for the gears. My advice is call Crosley first and see if this is a known problem to occur and check about the warranty.
Support number for Crosley
(336) 761-1212
  • 1 more comment
  • Benjamin Patri
    Benjamin Patri Mar 25, 2008
    have you gotten it to work, or have you contacted the manufacturer yet? Let us know, we are here to help!
  • Benjamin Patri
    Benjamin Patri Mar 30, 2008
    Please don't forget to rate this solution
  • Benjamin Patri
    glad you fixed it, have a good day and have fun using it
    Genius:
  • 1,665 Answers
This site may be usefull
    Master:
  • 377 Answers
HAVE YOU CHECK FOR ANY SPRING ATTACHED, THAT COULD BE LOOSE.??
6ya staff
SOURCE:
The turn table on my record player wont spin I can hear that it's on put wont spin.please somebody help
Your turntable belt is off. Remove the c-clip holding the platter to the center spindle. Remove the platter and turn it bottom side up, place the rubber belt around the platter and fix it to the little post sticking up on the outer-edge surface. The little post holds the belt to the platter while you turn the platter over and put it on so that the post points right over the motor pulley. Turn the platter by hand either clockwise or counter-CW and the belt will pop off of the post and land on the motor pulley. One drop of oil on the center spindle for lube and fasten the e-clip back on. Of courseicon1.png, the tone arm might not be actuating the power switch, you can address that with the platter off as well. Good Luck.
Oct 29, 2013 | Crosley CR249TA Turntable
Why does my turntable not spin when I move my Tone arm over?
Hi Daniel, its a bit of a long shot however try this. With the turntable powered of manually rotate the platter approx 12 times to reset the auto operation back to default. John styluscity.com
Nov 30, 2011 | Sony PS-LX250H Turntable
Zennox usb turntable arm rises before end of record
Hi, we don't have that model turntable in NZ so I can't say exactly where the adjustment for the tone arm lift position is. However on the majority of turntables it will either be beside the base of the tonearm possibly under a rubber grommet or if you remove the rubber platter mat and there is a hole in the platter near the outer edge rotate the platter whilst looking through the hole for a screw near the tonearm. Adjust anti clockwise a little and test. Fine tune until you are happy with where it stops. John. styluscity.com
Nov 24, 2011 | Audio Players & Recorders
Tone arm keeps returning to rest on Crosley CR249
Hi, Try this. with it turned off. Lift tone arm across a record to the run out groove and set it down. Now power up and hopefully it will reset itself. In all honesty I would sell it and get a decent old school player. John. Styluscity.com
Nov 09, 2011 | Crosley 0187SST Turntable
The turntable won't spin
Your turntable belt is off. Remove the c-clip holding the platter to the center spindle. Remove the platter and turn it bottom side up, place the rubber belt around the platter and fix it to the little post sticking up on the outer-edge surface. The little post holds the belt to the platter while you turn the platter over and put it on so that the post points right over the motor pulley. Turn the platter by hand either clockwise or counter-CW and the belt will pop off of the post and land on the motor pulley. One drop of oil on the center spindle for lube and fasten the e-clip back on. Of course, the tone arm might not be actuating the power switch, you can address that with the platter off as well. Good Luck.
Apr 10, 2010 | Crosley CR248 Turntable
I HAVE A 1951 AMI D-80 JUKEBOX,THE TURNTABLE IS JAMMED.
There are two motors with beige/tan plastic covers over them, one on turn table platter and the other on the record changer mechanism table. Take the cover off the one on the turntable and spin the motor by hand. Depending on how you spin it the arm will either go back up or down
Jan 03, 2010 | Audio Players & Recorders
Tone arm comes out and touches record, then goes back to cradle
See what kind of arm position sensing elements are used in your turntable (micro switches, optics or possibly other) and check if they work correctly - sometimes a microswitch can be damaged or have oxydized internal contacts or a badly soldered / broken wire and it will not function properly, causing the unit to stop automatically, the same might happen if the sensor is of optical type and there is some dust or broken wires or if the emmiter or sensor is damaged. Also, it could be a problem with the part that activates the switch / optics, it might be displaced or damaged.
If all sensors / switches seem to work well, then check the section which has wires going to those sensors / switches, it's the next probable location of the fault (it might be an electronic controller so there could be damage to some components, broken wires, dirty connectors or bad solder contacts).
It could as well be something else in the mechanisms, wiring or electronics, i just suggested a few things that might cause the malfunction you described.
Hope you can get it fixed.
regards
3rq8 (Triarcuate)
Sep 15, 2009 | Audio Technica AT-PL50 Turntable
Belt is off my audio-technica turntable at-pl50
WASH YOUR HANDS FIRST! Any oils on the drive belt may cause slippage.
This is from the manual:
A) Remove the record mat from the turntable platter
(Fig. 10a). Through an opening in the
turntable platter, visually inspect to see if the drive belt
is around the motor pulley (Fig. 10b).
B) If the drive belt is not around the motor pulley: Lift
and remove the turntable. Place a thumb into each of
the left and right openings on the turntable platter; and,
using the fingers to press down on the turntable housing’s
surface, pull the platter straight up (Fig. 10c).
Avoid pressing on the tone arm.
C) With the turntable platter bottom side up, place the
belt along the outside wall of the turntable platter's
drive rim, making certain that the belt is smooth and
flat all the way around (Fig. 10d).
D) Put the turntable back on the center spindle, make
certain it is fully seated, and align one of its openings
over the motor pulley position.
E) Through the opening, carefully hook the turntable
belt with a finger or with the original red ribbon (never
use a sharp object) and pull the belt over the motor
pulley (Fig. 10e). Make certain the belt is not twisted
between the pulley and the platter’s drive rim.
F) Put the record mat back on the platter.
G) While holding the tone arm in its rest position,
slowly turn the platter by hand clockwise at least 10
rotations to clear the mechanism’s automatic cycle.
Apr 24, 2009 | Audio Technica AT-PL50 Turntable
The tone arm will not drop on our Technics sl-dd33 turntable.
Have you left the tone arm lift in the up position?
If not: At the end of a record the mechanism lifts the tone arm, returns it to the rest, lowers it and switches off the motor.
It the motor has stopped too early, the tone arm will remain raised.
You can try gently rotating the platter clockwise by hand. This may allow the return cycle to finish.
Jan 16, 2009 | Technics SL-BD22 Turntable
Tone Arm skips past first song
Hello, A. Do not try to close the case when there is a record inside!! The fact that the turntable cannot do this is not a design flaw--you'll be hard pressed to find a portable turntable that can close with a record inside because if you were to pick up the player with one inside, it could easily slip off of the spindle and scratch against the sides of the player.
B. Are you using the cueing lever to lift the tone arm before you place it on the record? Read the instructions to see where the cuing lever is (it's a little switch on the right side of the tone arm). When you lift it, the tone arm will lift up and allow you to position it wherever you want on a record, then you depress the lever to make the tone arm touch the record and being playing.
I hope that helps!
Jan 04, 2009 | Crosley CR249TA Turntable
Crosley 4-in-1 Entertainer CD Shelf System Logo
526 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Robert Marmorstein
Level 1 Expert
Gene Pitts
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
