Question about Philips 50PF9631D 50 in. HD-Ready Plasma Television
Philips 50PF9631D Plasma
Philips 50PF9631 Plasma television will not turn on. When power is turned on, green LED light initially turns on but then within a few seconds turns red and flashes 7 times. No picture/no sound. Unplugged television and tried to reset but same problem occurs. Television about 1 1/2 years old.
  • 2 more comments
  • Ageispanther May 01, 2008
    I have the same problem with my television and mine is two years old. The power supply is good. Is there any other solution you can give us.
  • joealmighty Jun 09, 2008
    power is on, blue power light showing. initially clicks when you plug it in as it gets power. sound for a dvd will still go throught the tv to the stero but the tv itself will not show anything nor will the sound work.
  • gwalker33 Oct 09, 2008
    I have the same tv but when it first is turned on it is green for 2 seconds then it chaged to red and flashes 6 times and continues the loop of 6 flashed and then a pause. If you unplug the tv for awhile then it seems to work till next time
  • Anonymous Nov 22, 2008
    SAME EXACT PROBLEM. wHAT CAN I REPLACE
The TV needs to be serviced. I had the same problem. 2 boards had to be replaced at a cost of $1200.
Posted on Nov 06, 2008
    Genius:
  • 1,694 Answers
First step....check power supply components.....research
similar Model & problem.................T.
Posted on Mar 23, 2008
Well i have the same problem i call bestbuy they said the bulb is bad. i hope that help
Posted on May 11, 2008
SOURCE:
Toshiba 50hp66 Plasma repeats power sequence without turning on
A case of which came first the chicken or the egg, Power supply board may be the issue or the sustain board--have you looked for the usual bad caps on the power board?
Dec 03, 2012 | Toshiba 50HP66 50 in. Plasma Television
I have had my TV-- a 42" Philips plasma-- for
it can be a poor contact or puffed capacitor in the power supply board
Dec 06, 2010 | Philips 42PFP5332D 42 in. Plasma...
I have a philips dlp 55pl9773 has one red flashing led on the front when i do a hard reset tv boots up lamps lites led goes from flashing yellow to green for about ten seconds and then back to red flashing...
MY philips tv model number 55PL9773/17 WAS TURNING OFF THE SCREEN AND LEAVING THE AUDIO ON FOR ONE MINUTE. THEN THE YELLOW LIGHT STAYED ON. THEN THE LIGHT TURNED OFF. thEN I TURNED ON WITH THE REMOTE AND THE YELLOW LIGHT TURNED ON AND A FEW SECONDS LATER CHANGED TO THE GREEN LIGHT AND THE TV TURNED ON. AFTER A FEW MINUTES, BETWEEN 10 AND 30 IT DID THE SAME THING. NOW IT IS OFF WITH A BLINKING RED LIGHT PERMANENTLY ON. TO TURN IT OFF I HAVE TO UNPLUG IT FROM THE WALL. I REPLACE THE LAMP A FEW WEEKS AGO AND IT IS FINE.
Dec 01, 2009 | Philips 55PL9773 55" Rear Projection...
42 plasma phillips trouble code D3V3
Check the power board for caps with the tops bulged up. 3300uf 10v I think.
Jan 14, 2009 | Philips 50PF9731D/37 50 in. Plasma...
Philips 42fd9954-175
Hi, and unfortunately I am facing the same issue. My TV blinks GREEN LED for a few seconds then starts flashing RED led. The result I hear from this is that it is the SSB Panel and the estimated cost for service is $600.00 it sounds like you are STARTING with the problem. I began that way too. If you are under warranty, call Philips NOW!
May 13, 2008 | Philips 42FD9954 42 in. Plasma HDTV
My plasma TV turns itself off and there's nothing I can do to get it come back on...
Firmware is avialable for download on the philips web site. The latest one that is the bundle of mutiple patches may not patch all the problems. Looks like it has to be applied indivdually.. -anil
Jul 11, 2007 | Philips 50PF9630A 50 in. Plasma Television
Philips 50PF9631D 50 in. HD-Ready Plasma Television Logo
731 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
