Question about Dynasty DGRSC 30 Gas Kitchen Range
Dynasty range, oven does not heat up enough
Only the left side of the two oven burners works.
  • 93 Answers
30 inch oven has only one oven tube, 36 inch oven has 2 burners in it, most comment is the oven ignitor is out. If you have 2 burners, I'll change both oven ignitor at the same time, because they worked together. also check the oven tube, if it is corroded at the ignitor area, change the burners. Have fun.
Posted on Mar 02, 2010
LOOKS LIKE NO GAS TO OVEN. GLOW STICK LIGHTS IS YELLOW-BROILER LIGHTS...GLOW STICK SAME COLOR AS OVEN'S
You need a new thermostat for the oven. It isn't picking up the heat from the ignitor. They're relatively cheap and easy to replace.
Sep 06, 2009 | Dynasty DGRSC 30 Gas Kitchen Range
Dynasty oven fails to get enough gas to light.
I think you are talking about the oven safety valve or thermal valve. before you change you oven safety valve, I would check the Amperage on the oven ignitor first, install AMP meter on one of the ignitor wire, it should draw above 3AMPs, if not then you have problem with the oven ignitor and not the safety valve. we hardly change the safety valve, I'll try to change the ignitor first. Have fun.
Mar 28, 2009 | Dynasty DGRSC 30 Gas Kitchen Range
Oven is not heating properly
Could you find the completer mode number because the number listed above your post is for a gas oven.
Look at following areas for the model number
  • Under Right Front Burner
  • Under Left Top Burner Front Or Rear
  • Under Main Top Left, Rear Or Center Front
  • Under Left Rear Or Right Front Element
  • On Nameplate Inside Burner Box
  • On Front On Burner Box Bottom
  • On Nameplate On Oven Door Liner
  • On Main Front Behind Oven Or Compartment Door
  • On Front, Center Bottom Of Burner Box
  • On Thermostat Cover Under Main Top
  • Thank You, Sea Breeze
Mar 25, 2009 | DCS RGS-484GG Gas Kitchen Range
Explosion in heating chamber when oven is lit.
the air adjustment is open just a little to much the flame will have a hard time to go to the other side, try closing the vent to the burner just a Little bit and try the oven,another problem that i see is that the ignitor is getting to weak to ignite the flame on time.
Dec 09, 2008 | Dynasty DGRSC 60-6G Gas Kitchen Range
Top burners and oven don't heat up enough-GE Spectra
the stove it's only getting 110 volts, that's what happen when it does not get enught power.
Dec 03, 2008 | GE Spectra JBP78 Electric Kitchen Range
Dynasty DGRSC 30 Gas Kitchen Range Logo
243 people viewed this question
Top Dynasty Kitchen Ranges Experts
Ismael Rodriguez...
Sal De
Are you a Dynasty Kitchen Range Expert? Answer questions, earn points and help others
