Question about KitchenAid KGSA906PSS Gas Kitchen Range
Oven door locked
Did you get you oven door unlocked? Mine is locked and I don't know how, when or why. Tried to use it this morning and when I tried to open it when preheating was done it was locked. Kitchen Aid Customer Service is closed and I can't find anything in the manual to help. How did you resolve your problem with the locked door.
Thanks!
  • 4 Answers
Please check my earlier post on this problem.
I forgot to add that the only way the Tech is able to get the oven door unlocked after it shuts down in the Self-Clean (Self-Destruct?) mode is to take a pair of pliers and short across the bad Thermal Protection swtich before replacing it.
Posted on Apr 28, 2008
I recently purchased a 99 pontiac bonneville...was playing with light switches trying to figure out what goes where...after exiting and locking with door lock i noticed the interior lights still...
If you don,t have the remote for the (Alarm) Try end get one for it, Or Have the alarm taken out if it isn,t a factory installed (Alarm)
Nov 07, 2012 | Cars & Trucks
I don't know the model # but its a kenmore oven and my daughter left her finger on the stop button too long and so the oven door automatically locked us out. I can't find the book for it
According to the eHow website,
"press and hold the stop/clear button for 3 seconds to unlock the door."
(it's the same to lock the door in the first place.)
According to the Just Answer website, either press and hold the stop/clear button for 3 seconds or 5 seconds, (A beep will sound. The "DOOR LOCKED" will continue to flash until the oven door has completely unlocked and the lock icon light has cleared.) or you have to press the button 3 times quickly.
Sep 25, 2012 | Kenmore Ovens
We have a Five Star gas oven and attempted to use the self cleaning process to clean the oven. We started yesterday and it appeared to complete the cleaning cycle. This morning, however, the locking...
There are two reasons for the lock to remain locked. One: the thermostat/wiring failed. This results in the oven's control still believing that the oven is too hot (over 450 degrees) and thus will not unlock. The other possible problem is that the unlock mechanism failed.
You can try to unlock the oven manually. (For some ranges, you can do this from the back of the range.) Please add a comment with the model of the oven/range for more assistance.
I hope this gets you started on solving the problem.
Jul 06, 2017 | Five Star 48 in. TTN045 Gas Cooktop
I turned on the self cleaning process let it clean and cool down Tried to bake next day msg states to unlock door even when the door is open can't use oven help I have tried several times to lock and...
since i dont know your model try this
unplug the range for 30 mins
let the memory clear
and then plug it back in
this works for several differant manufacturers
Oct 13, 2009 | Ovens
The lock on self cleaning oven door will not release
Once the cleaning button on the oven is pressed it take 15 minutes for the uven door to unlock.
Jul 30, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Kenmore locked
The www.managemyhome.com website has some troubleshooting options when the door wont unlock. Good luck. Also you can download the whole manual online it you have your model number. Mine was inside the drawer under the oven.
Apr 12, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Oven door won't unlock
I had the same problem on my Kenmore Electric Range. Door would not unlock. Tried pressing "Off" for multiple seconds, but still would not unlock. No error codes. Clock was displaying normally. Finally decided to try running it thru the self cleaning operation to get it to cycle thru locking and unlocking the door. When I started self clean, the door automatically went thru the auto lock and "locked" appeared in the display. I then hit "Off" to clear it and stop the cleaning cycle. The door then unlocked as normal!
Feb 16, 2008 | Kitchen Ranges
Frigidaire oven door locked
SOME RANGES ARE DESIGNED TO LOCK IF THE CONTROL SENSES A TEMPERATURE EXTREME. IF THERE IS A FAILURE OF THE SENSOR THAT MAKES THE CONTROL THINK THE TEMP IS UP, IT WILL LOCK THE DOOR TO PREVENT INJURY. REMOVE THE BACK PANEL AND FIND THE OVEN SENSOR LEADS COMING OUT THE BACK OF THE OVEN. DISCONNECT THE SENSOR AND CHECK THE RESISTANCE. AT ROOM TEMP IT SHOULD BE SOMEWHERE AROUND 1084 OHMS. IF IT IS NOT CLOSE,
THE SENSOR IS BAD. PLUG IN A NEW SENSOR AT THAT CONNECTOR AND THE DOOR SHOULD UNLOCK. THEN GET INSIDE THE OVEN, REMOVE THE OLD SENSOR, AND REPLACE IT WITH THE ONE PLUGGED IN.
Feb 12, 2008 | Frigidaire FEF336BC Electric Kitchen Range
try hitting self clean again give it a few seconds for the eoc to think the door is locking then hit stop/clear or cancel let me know if this helps if not i can call ge tech after holidays
Dec 28, 2007 | GE JKP15 Electric Single Oven
"door lock" light stays on and oven won't work
On mine, I was able to take of the face plate and unscrew the metal locking arm from the motor. Once i wiggled the locking arm away from the locked position I was able to open the door. Once i opened the door, the little motor which controls the locking arm automatically rotated to the unlocked position and cleared teh "locked door" message on the control panel.
Apr 27, 2007 | GE JTP15 Electric Single Oven
KitchenAid KGSA906PSS Gas Kitchen Range Logo
271 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
