Question about Acer n310 Pocket PC
Connection to internet problems
I cannot set up my Acer n310 PDA to access the internet using a blutooth mobile phone as a modem
Have you updated the firmware?
Posted on Oct 03, 2008
How to connect my to the internet
you haven't told us your pda model, but nevertheless, let us assume your pda is bluetooth capable, can be use as usb modem. and the necessary drivers are already installed.
on your computer, go to network, then select set up a dial up connection, then on the modem's list, select your phone, then indicate a phone number by inputting *#99# (this means that your pc will dial the default internet configuration on your phone) so it can connect to the internet. you must configure your phone browser settings for this to work.
you may also pair your device using bluetooth, then setup a bluetooth connection. same process as usb modem setup..
Dec 29, 2012 | Computers & Internet
Can i get the speed internet browsing using mobile as a modem
yes of course.. connect your mobile to the computer via connectivity cable, blue tooth or infrared. setup a new connection and enjoy.
note: you need to get access point settings from your network carrier. for further problem you will have to cantact your customer care of your network carrier and get help from them since all the carriers have different settings..
Mar 10, 2011 | IBM Computers & Internet
I can't conect s312 to my pc via Blutooth for Internet using
hi,first pair ur mobile with ur pc.then check whether the modem for bluetooth is being installed.after that go to network sharing centre.
1.click 'set up new network'
2.select 'dial up connection' then press 'next'
3.ur modem ll be shown,click 'standard modem over bluetooth' then 'next'
4.give the dial up number as *99#
then leave other options
you ve to configure ur modem first before doin this.
1.pair ur mobile with pc.
2.goto 'device manager' in 'system properties'
3.click on 'modem' u'l see ur mobile modem der
4.right click on it and select 'properties'
5.goto 'diagnostic' option and click 'query modem'
6.it ll check ur modem functionality and it ll show some msg like AT SUCCESS
7.then goto 'ADVANCED' menu
8.type AT+CGDCONT=1,"IP","access point" in extra settings.
9.the access point change dependin upon the network
10. clilk ok
NOW UR PC IS READY TO CONNECT INTERNET WITH MOBILE
Enjoyyyyyy.........................
Nov 03, 2010 | Sony Ericsson S312 Mobile Phone - Silver
Sir when i am connect my nokia2626 mobile phone to pc via nokia pc suit when it's not work correctly and the main proble is that when i want to connect my pc to internet using my phone then message shows...
Hi!
You have to select the mode of connection.. through blutooth or by usb data cable.
If by blutooth, you have to stable the pairing of the phone and the pc.. You also need to make sure that your phone has already the settings that your phone provider has sent you to access by phone.. If you can access the net from your phone then its ok to surf internet on your pc via phone as your model.
You also will need to set your phone as your modem.. how? go to control panel and select Phone and Modem, there set up the phone as modem.
If this things are done, then go with your pc suit again and try connecting.
If you are trying to connect via usb data cable.. you will need first to install the driver of your cable before you can start pairing your phone to your pc via pc suit.
I hope i gave you a better idea with that.
Much appreciated if you could rate this help. Thanks
May 19, 2010 | Computers & Internet
How to ACESS INERNET TO LAPTOP THROUGHT MOBILE
First of all you will need to have settings save to your phone sent to you by your phone provider. If your phone can access the web, then that means your phone already have the settings for surfing the net.
Secondly, you will need pc suit software or any other mobile suit software compatible for your phone. Install the software to your pc..
Third, you must specify the mode of connection that you want for your phone and pc.. If you will be connecting your phone to your pc via blutooth... then you will need blutooth device installed and connected to your cpu.... If you will be connecting via usb data cable.. then you will need driver installed for your data cable.
Fourth, on control menu.. double click Phone and Modem.. Install your phone as your modem.
Lastly, If all is done.. run your pc suit... pair your phone to your computer.. Access dial up via phone modem... and there you go.. just make sure your phone is loaded so the connection wont stop..
Good luck.
Much appreciated if you rate this help. thanks.
May 21, 2010 | Computers & Internet
Is there a way to switch from wireless to wired internet on asamsung np-n310 netbook.
Yes I looked up the specs of your netbook and it shows you have an ethernet port but there is no phone modem. Just disable your wireless connection and plug in your wired connection.
To disable your connection open Network Connections in Control Panel and right click your wireless network (you enable it the same way).
Here is the link for your netbook specs http://www.samsung.com/ca/consumer/office/mobile-computing/netbook/NP-N310-JA01CA/index.idx?pagetype=prd_detail&tab=spec&fullspec=F
Jan 13, 2010 | Samsung N310-13GBK (NPN310KA05US) Netbook
Modem Drivers for chinese mobile phone MT 6227 and Mt6228
You can download your modem driver from here
http://www.filebuzz.com/findsoftware/Download_Mt6228_Modem_Driver/1.html
May 18, 2008 | Cell Phones
Acer n310 pda power problem
I have a Acer pda model C530 and it has a switch that detects if the cover is correctly inserted, check that switch, buy electronic contact cleaner spray and clean it (and clean the battery contacts,on/off button) if possible try with a new or known good battery. If it has dropped to the floor it might have some bad contacts.
Apr 15, 2008 | Acer n310 Pocket PC
GPRS setting in my Qtek 1020 PDA Phone
in connections, create a new connection
my isp>add a new modem conn>connection name (whatever)>modem : cellular line(gprs)>access point : bplgprs.com (case sensitive)>user name: bplmobile>password: blank>advanced>servers> use specific server : DNS: 202.169.145.34> alter DNS : 202.169.129.40 >OK
good luck
Aug 07, 2007 | O2 Xda II Smartphone
Using Nokia 3650 as modem
On your PDA go to Start – Settings – Connections. There you can find an option called Connections. Chose it and go to option “Add a new modem connection” On this place please enter the name (example MOBILE) and select a modem (Generic IrDA). Next step is to enter the right number that should be called with your mobile phone. At the last step should be inscribed username and password if necessary. Go to finish. After that, make please direct positioning of your mobile phone near PDA. On the mobile phone start in the menu the option called “Infrared”. You can see at the top of the PDA display a symbol for the Connectivity. Touch it with the stylus-pen. As you can see there is a small window with the right name of connection and phone number that should be called. Click on the number and wait for a second. After short time the mobile phone will dial the number.
Sep 11, 2005 | Toshiba e400 Pocket PC
Acer n310 Pocket PC Logo
97 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
