Question about Cuisinart Grind and Brew 10 Cup Coffee Maker
Coffee maker When turned on, it does not grind
Please how it turn on
Posted on Jan 10, 2009
Too coarse a grind
have you tried adjusting anti-clockwise whilst grinder is in operation ?
Nov 11, 2011 | Jura Capresso Jura Ena 5 2Cup Coffee Maker
Trying to figure out which direction to turn the knob inside the coffee bean grinder to make my coffee weaker. Others have told me that the finer the grinds, the stronger the coffee. And the courser the...
HI
You can run more water through the same grind you are using now or you can trun the big knob in the bean hopper to a larger #. That will make the grind coarser. You can turn the knob to a larger # anytime but to turn it to a smaller # it has to be grinding or you will damage the grinder. If you have 2 knobs in the bean hopper, you can turn the small knob down towards the -(minus) and reduce the amount of coffee in the brew unit.
Apr 17, 2011 | Saeco Vienna SuperAutomatica Coffee...
This coffee maker (10 c maker with grinder) beeps it's done every few minutes with water left. we have to brew about 5 times for a full pot, what gives?
Presume this is the Grind & Brew Thermal™ 10-Cup Automatic Coffeemaker, Model # DGB-600BCC
An instruction booklet is available here: http://www.cuisinart.ca/pdf/ibs/en/DGB-600BCC_en.pdf
Review the sections beginning on page 11 of the pdf on Turning Off the Grind Function (if not using the grind feature) and Making Coffee.
Make sure you are turning off the grind function if using preground coffee and that the reservoir lid is securely closed.
Check the Cups Setting button; is sounds like the 1-4 feature may be turned on.
Jan 30, 2011 | Cuisinart Grind and Brew 10 Cup Coffee...
When the espresso is grinding, it appears to be grinding continuously and will then stop and the light will come on as if the hopper is empty, even when it is filled with coffee beans.
Turn the big knob in the bean hopper to the largest #. If it works, on the second try turn the knob back down to a #, higher that you had before, but only turn the knob when it is grinding.
Sep 11, 2010 | Saeco Vienna SuperAutomatica Coffee...
I set up our new coffee maker and it didn't grind...ordered it online from Macy's but had no manual and didn't know what to do...put coffee grinds in the top and then set up the timer for this...
You need to swivel the brew basket cover until it locks for the coffee to grind. Then turn the machine on and the coffe will grind. , then turn the machine off, add water and press the auto on to use the auto timer.
Dec 13, 2009 | Krups KM7000
Problem with a Cuisinart Coffee Maker
Hi I have a dgb600bc coffee maker the beans do not grind all the way and it makes a funny noise when grinding. thanks
Nov 28, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart grind and brew 10 cup grinder stopped working
My grind and brew is a little different, but when I have this problem, I havve to remove the beans and vaccuum out the bean reseviour. It gets clogged and then it won't grind.
Mar 23, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Where is the grind switch on the cuisiart grin & brew
Once you turn the machine on, it should automatically start to grind, unless you press the Grind Off button to make it stop.
Mar 15, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
The timer to keep the coffee hot does not work. It turns off
Turn the setting to "auto-OFF" - make sure it displays "2:00" or higher. You can use the HR button to increase the time to 4 hrs ("4:00"). It wil lcontinue ehating for up to 4 hours.
Nov 01, 2008 | Cuisinart Grind & Brew DGB-500R, 12-Cup...
This happens when the machine needs cleaned. Fill coffee maker with white vineger instead of water. Turn grind off, make sure empty pot is in place. Brew a pot of hot vineger. Repeat. Brew a pot of hot water. Repeat. This process removes mineral buildups inside machine. If you have access to filtered water, start using that to brew your coffee. I do and probably do this process 1 per 6 weeks.
Oct 07, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart Grind and Brew 10 Cup Coffee Maker Logo
52 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
