Question about Jabra BT150 Wireless Headset
Pairing can't remember how to pair the headset with my phone, any ideads???
    Novelist:
  • 141 Answers
Http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT150/Documents/User%20manual/BT150_UM_NA_EN_496.pdf
Manual for Jabra BT 150
Go to page 4 Pair it with your phone
Did you know that if you have a bluetooth card in your computer you can also use this headset to listen to music. Do it everyday. It's great!
Posted on Mar 29, 2008
SOURCE:
Trying to connect bluetooth to my new phone went threw pairing process but when i inter the pin 0000 my phone says pairing failed
The pass code should be 0000 (four zeros), it's always been that for Plantronics headsets. Here are a couple of things to try. First, remember that newer phones are like small computers, so they may become corrupt over time and you may need to reset them every so often. Simply turn your phone off and remove again the battery for a few seconds, then replace the battery and turn it back on again. Second, you want to reset the headset. The attached user guide for the Plantronics Explorer 230 on page 7 will show you how to turn off / on the headset and page 4 will walk you through the pairing process. Remember to remove any previous bluetooth connections from your phone.
Plantronics Explorer 230 User's Guide
Good luck from Headsets Direct!
Mar 16, 2011 | Plantronics Explorer 230 Bluetooth Headset
Plantronics 330 connects to phone but no volume on the headset/microphone
Remember that newer phones are like small computers, so they may become corrupt over time and you may need to reset them every so often. Simply turn your phone off and remove the battery for a few seconds, then replace the battery and turn it back on again. If this does not resolve the issue, delete the pairing information for your Explorer 330 headset and pair it with your phone again. The link below for the Plantronics Explorer 330 has the pairing information.
Plantronics Explorer 330 Pairing Information
Dec 31, 2010 | Plantronics Explorer 330 Headset
Need to pair my headset and cannot remember how
Press and hold the headset's call button until the blue and red lights flash alternately. It is in pairing mode now. Then, make your phone's bluetooth application search for new devices. When your headset appears on the phone' screen, make it proceed. If a pairing code (or passkey, or PIN) is requested, enter '0000' (four zeros).
Hope it works for you.
Regards, Carlos
Jul 01, 2010 | Plantronics AUDIO 920HEADSETUS Wireless
Can not pair with my new phone
sure can
with the boom mic closed Push and hold the call button until the light around turns purple or stays a blue, then open the boom mic the color should stay on now go in to the phone settings and find the bluetooth settings and search for device once it finds it connecct to it, Remember the Passcode is 0000, and then you should be all set up.
Jun 28, 2009 | Motorola Mobility Bluetooth...
Bh 101 bluetooth headset lost manual and forgot pairing code
Try this: 1. Ensure that your phone is switched on. 2. If the headset has not been previously paired with a device, switch on the headset. The headset enters the pairing mode, and the indicator light starts to flash blue quickly. If the headset has been previously paired with another device, switch off the headset, and press and hold the multifunction key until the indicator light starts to flash blue quickly. 3. Activate the Bluetooth feature on the phone, and set it to search for Bluetooth devices. See the user guide of your phone for instructions. 4. Select the headset from the list of found devices. 5. Enter the passcode 0000 to pair and connect the headset to your phone. In some phones, you may need to make the connection separately after pairing. You only need to pair the headset with your phone once. If pairing is successful, the headset appears in the menu of the mobile phone where you can view the currently paired Bluetooth devices. When the headset is connected with your mobile phone and ready for use, the indicator light of the headset slowly flashes blue.
Apr 14, 2009 | Cell Phones
Can not remember how to pair my nokia bh208 headst
Try this:
Pair the headset
1. Ensure that your phone is switched on and the headset is
switched off.
2. Press and hold the power key until the green indicator light
starts to flash quickly.
3. Activate the Bluetooth feature on the phone, and set the phone
5. Enter the passcode 0000 to pair and connect the headset to your phone. In some phones you may need to make the connection separately after pairing.
If the pairing is successful, the headset beeps and appears in the
phone menu where you can view the currently paired Bluetooth
devices. The headset is now ready to use.
http://nds1.nokia.com/files/support/apac/phones/guides/Nokia_BH-208_APAC_UG_EN.pdf
Mar 03, 2009 | Nokia Bluetooth Headset Headset
Cannot pair headset with phone
Morning
After i reset the headset, the passcode "0000" allowed the headset to pair with my phone.
Thanks for the info that was posted as it helped me solve my problem.
Aug 26, 2008 | Nokia HS-36W Wireless Headset
Blue tooth pass code
Typical pairing code for PLT Voyager 510 is 0000
Dec 19, 2007 | Plantronics 510 Voyager Headset - PLN-510...
Pairing headset with phone
You can download manuals from this link: http://plantronics.custhelp.com/cgi-bin/plantronics.cfg/php/enduser/std_adp.php?p_faqid=8079&p_created=1125099403&p_sid=BnXTqpIi&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MzMmcF9wcm9kcz02MiwxNjYmcF9jYXRzPSZwX3B2PTIuMTY2JnBfY3Y9JnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5zZWFyY2hfbmwmcF9wYWdlPTE*&p_li=&p_topview=1 There is an online pairing guide below: http://www.plantronics.com/media/media_resources/easytopair/index.html?WT.mc_t=EasyToPair&WT.mc_n=EasyToPair&WT.srch=1
Aug 05, 2007 | Plantronics 510 Voyager Headset - PLN-510...
Headset will not pair up eith razr phone.
Have you pressed and held the button on headset until light is always on, as this is in pairing mode, then search devices with your phone.
Jan 15, 2007 | Motorola Mobility HS820 Consumer Headset
Jabra BT150 Wireless Headset Logo
222 people viewed this question
Top Jabra Radio Communications Experts
Anthony Ward
Anthony Ward
Bobby G
Bobby G
Damen Wong
Damen Wong
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
