Question about Cherokee (REF) AM/FM Stereo with CD Player and Hands-Free Capability
Jeep radio problem
The radio cassette in my 98 cherokee sport displays - wait 2 hrs - when I turn it on.
How do I get it to work?
  • 1 more comment
  • fatgreig Jan 10, 2009
    me too exactly the same, but on 97 model
  • neb5 Jan 31, 2009
    Same problem on a 97, Wait 2hrs
  • Anonymous Mar 16, 2009
    I have same problem... My jeep was more than 2 months in garage and after that radio stop working and there is WAIT 2hr SIGH on the radio display... Actually Wait 2hr is on only few seconds, after that only WAIT sign is on... Can enybody help?
I have a 2002 Grand Cherokee Jeep and the issue is that the radio/clock display is blank 99% of the time even though everything else on the stereo works fine (radio, cassette deck, 10 CD changer etc)
If all fuses are good ,then that is a bad display
bad radio,.
bad is bad...
get the radio fixed, ($$$$)
or upgrade for same price.
cassettes are like, cave man tech, now.
and CD near.
we use, usb mp3 here. up grade
Nov 06, 2016 | 2002 Jeep Grand Cherokee
I have a 2004 Jeep Grand Cherokee the radio display is blank can I fix this
Sure. Pull the radio, take off the metal cover around it. At the face and the bottom of it, there around 20 leads soldered to the board. Use a soldering iron and resolder them(cracked solder joints). No extra solder is needed. This fixes about 98% of no display problems. Every once in a while it is a chip. In this case, replace the radio.
Jan 30, 2016 | Jeep Cars & Trucks
only fixed by replacing radio, used to work at jeep and when they were under warranty we replaced them for this concern and it fixed the problem
Mar 22, 2014 | 2004 Jeep Grand Cherokee
Gauges and radio went out
if you beat on the bottom of the dash where youre knees are it will probably come on common problem, on my 98 i pulled the cluster (not hard) and took a pair of needle nose pliers and just slightly twisted all the pins that go into the back of the cluster to make better contact than put dilectric grease on them
if you google cherokee forums you will find all the answers you need
Feb 02, 2013 | 1999 Jeep Cherokee
Clarion pu 1570 radio cassette not responding
If You know the code:
1. Turn radio On
2. Display say "Code in"
3. Enter the Code by memory station buttons (4 digits)
If You enter wrong code for the first time:
1. Turn radio off.
2. Turn radio on
3. Press and hold the band "~" button
4. Display shows ====
5. Wait till display say "code in"
6. Enter the code by mem. station buttons.(4 digits)
You mast wait by Radio ON in = = = = condition,
and not in - - - -!
The max. waiting time is 90 min.
Tested by PU-1570A Eeprom 93C46
1. Radio Off
2. Press and hold the Band "~" Button.
3. Turn the radio ON
4. Enjoy!
Apr 22, 2010 | Car Audio & Video
98 jeep grand cherokee all time 4wd, v8, 5.9L, how to fix a blown head gasket
u also need 2 buy intake gaskets. bcuz the intake has 2 come off 2. u need 2 take everything off thats in the way. u also hav2 drain the coolant. its a big job like 12 hrs
Feb 13, 2010 | 1998 Jeep Grand Cherokee
Jeep cherokee sport 97 entered wrong code 3 times,
did you have the ignition on for two hours with the radio turned on?????????
Dec 24, 2009 | Car Audio & Video
My 1998 Jeep Cherokee cd player does not work, displays "error when cd inserted, the radio works fine, can it be repair?
it will read burnt cds, the only thing is that it will not play .mp3  format songs, if you can somehow change the format to something else it should work just fine. i had a friend who's car had the same problem and switching the file extension from .mp3 to something else like .mpeg or something else should work. the cd player in a 98 grand cherokee is older and does not have .mp3 play back on it so it cannot read .mp3 format files. that's the only reason it doesnot register. try different audi files out and it should work. give it a try. i hope that helps out some.
Dec 30, 2008 | Jeep AM/FM Cassette with CD Changer...
'98 Grand Cherokee Factory Radio - Zune Interface?
There are adapters that you can get to connect the speaker wires to in order to get the aux jack levels the Zune needs. Amazon com Speaker RCA Line Level Converter Adaptor High Low Hi Lo with...
Sep 04, 2017 | Jeep AM/FM Cassette with CD Changer...
Decoding my radio
replace it,its useless to repair?
Jul 01, 2008 | 1996 Jeep Grand Cherokee
Car Audio & Video Logo
503 people viewed this question
Top Cherokee Car Audio & Video Experts
xxxxxx xxx
Are you a Cherokee Car Audio and Video Expert? Answer questions, earn points and help others
