Question about Frigidaire 24 in. PLD2850 Built-in Dishwasher
Water in dishwasher
Dirty water remains in dishwasher.i use it.i cant use it.its not leaking but its dirty and smelly.please help me
  • rhornbu Mar 25, 2008
    water will not drain from bottom of diswasher
  • gzaonas Jul 13, 2008
    My dishwasher also doesnt drain, it makes a noise but the water doesnt go anywhere. Sometimes it even starts leaking all over the kitchen floor.
    President:
  • Frigidaire Master
  • 2,651 Answers
If you push the start/cancel button it should start to drain water out. can you hear it drainin into the sink???can you at least hear thje drain pump activated trying to pump???perhaps its humming... if so id check your drain connection under the sink for blockage, and then next remove the drain pump itself and look for debris clogged within it stoppin drain
Posted on Mar 30, 2008
SOURCE:
Dirty water standing in the bottom of the tub
There is probably some debris that is blocking the water from getting to the pump.For More information please visit Kenmore Parts.
Oct 04, 2012 | GE Nautilus 24" Built-in Dishwasher
Dishes come out dirty especially those on top shelf and a scum remains along the bottom of the dishwaher at the edge of the door i do use very hot water and a rinse agent
It sounds like you have a hard water issue. Please try dishwasher magic additive this will clean out the dishwasher and help you get better results.
Thanks
Dec 11, 2010 | Dishwashers
Dirty smelly water is in the bottom of the dishwasher. Is there a problem with the disposal/dishwasher connection?
Maybe.... Check the hose to the disposal...
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 29, 2010 | Whirlpool Dishwashers
I have standing water in my dishwasher. How do I unclog the drain?
It will be smelly water and if you have access to a shop vac that will help you remove the standing water if not use a bowl or turkey blaster listed below.
Use a small bowl to remove standing water from washer to access screen to remove and check for blockage. Once you have removed all the water that you can with a bowl or cup. You can use a turkey blaster to sucton remaining water from dishwasher.
Then you remove screen and clean out drain and also check drain line for blockage from dishwasher to under sink.
Clean out drain to unclog in bottom of dishwasher and you may have to remove drain line to clean it.
Aug 10, 2010 | Frigidaire Dishwashers
1. leaks from bottom. 2 smells like mold. Help, Cheryl
YOU WILL HAVE TO REMOVE 4 SCREWS LOCATED INSIDE THE DOOR WAY. 2 HOLD THE DOOR HINGES AND THE OTHER TWO HOLD THE FRONT PANEL. THE DOOR CAN REMAIN ON AND IT SHOULD STAY PUT ONCE SCREWS ARE OUT. THEN REMOVE THE FRONT PANEL, RUN A CYCLE AND SEE IFF YOU CANT LOCATE THE LEAK.
IT IS MOST LIKELY LEAKING FROM THE BIG GREY DOOR GASKET
LEVI
LEBARCHRIGEN APPLIANCE REPAIR
WWW.LARTODAY.COM
Dec 11, 2009 | Maytag Neptune MAH5500B Front Load Washer
GE Externa Tritan XL (7 yrs old): Standing dirty water
Hello, there isnt much that you can do, there could be a number of problems. It could be a slight blockage somewhere from your drainage hoses to your pump. It could also not be spinning properly. If you want to drain the rest of the water out you will need to get your drainage hose and lay it flat on the floor to a drain, this will stop things getting smelly. You just may have to get a repair man in, I hope this helps.
Nov 07, 2009 | GE 24 in. Profile PDW7800 Built-in...
My Bosch shu 5315uc does not advance to rinse or dry. Machine just keeps running. Dishes are dirty and smelly. Manuel says to check if water line is closed or inlet filter blocked. Have no idea how to do...
The waste pipe may be blocked or partly blocke. Is this connected with another appliance under the sink?( T junction?. It may be blocked or partly blocked.
Oct 11, 2009 | Bosch SHU5315UC Dishwasher
Water is leaking into the dishwasher when it was not on. The water is really dirty and fills over time. How do I make it stop? It is not on automatic or on at all.
Hi, The water is dirty, do you think it is water draing back into the d/w from the sink? You need to raise the dishwasher drain hose that hooks up to the sink. Make sure the highest point of the drain hose is over the connection where the drain hose hooks to.
If it was fresh water filling the dishwasher, the water would be clean.
Please let me know if this helps you at all or if I can assist you further.
Thanks
Vic
Jul 18, 2009 | Maytag MDB9100A Dishwasher
Dishes not clean
water valve under dishwasher that let the water come in is not opening all the way causing either low water level or no water to come into the dishwasher. with out the proper amout of water the soap cant be disolved. replace water val to solve problem
Nov 20, 2007 | Maytag 24 in. MDB6100A Built-in Dishwasher
Frigidaire 24 in. PLD2850 Built-in Dishwasher Logo
213 people viewed this question
Top Frigidaire Dishwashers Experts
Archie Ferrarini
Archie Ferrarini
Mike
Vitally Alcher
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
