Question about Nokia 7373 Cellular Phone
Replacement cover please help!!! i have my nokia housing ready to fit and have'nt a clue where to start thanking you in anticipation! linda
    President:
  • 1,017 Answers
This might help, also do a search on YouTube for Nokia 7373.
LCD change on 7373
  1. Switch off the phone.
  2. Take SIM card out.
  3. Take front faceplate off by inserting Credit card/Tweezers between housing and silver key. As you pull up, take credit card and slide it on the side of the phone prying the clips off. (Gently tease it out working around the phone)
  4. Unscrew these 6 screws at the edges with the T6 screwdriver and release the 4 clips surrounding the LCD screen. Slip the little black frame off of the LCD screen, and lift the screen. (Prize it up gently from the swivel end of the mob.) There's a printed circuit board underneath it is attached to the LCD by a hook type catch. Don't damage it (the board). You should now see a screw. Removing this screw removes the back cover.
  5. That’s it! Put your new faceplate or housing in and figure out how to put things back by following the directions here in reverse order.
  6. You should use anti static gloves for this job, avoid touching the connections and the LCD face.
Posted on Mar 22, 2008
My themorsat stop working,and I replaced the batteries.
see this causes and fix it. God bless you
Furnace Produces No Heat Possible Causes
Possible Repairs
  • Remove cover of thermostat and loosen screws holding unit to wall. Level the thermostat. Re-tighten screws and replace cover.
  • To adjust the heat anticipator, please see Heat Anticipator Adjustment.
  • Furnace Turns On and Off Frequently ("short cycling")Possible Causes
  • Dirty thermostat components
  • Heat anticipator not set correctly.
Possible Repairs
Sep 30, 2012 | Honeywell Programmable Thermostat Heater
Tv nt coming on red light is on next to power light 50 inch lcd projection sony tv
hello. it sound's like you need to replace the lamp in your set. and here is how to do it the right way. rember to all ways unplug your set.. # 1 first. .Remove the outside lamp cover. The lamp cover is located on the right side of the Sony television. To remove the lamp cover, simply pull down. You will now have access to the lamp housing. # 2 Open the lamp housing door by turning the locking handle counterclockwise while pulling the door toward you # 3 Pull the lamp unit straight out of the television unit. Be sure not to touch the bulb, as it may still be hot. # 4 Slide the replacement bulb into the lamp housing. # 5 The lamp will slide securely into place.!!! "Do not" touch the new bulb as it will cause damage to the bulb and result in malfunction. # 6 Push the lamp door back into place. Turn the locking knob clockwise to secure the door in place.# 7 Slide the outside lamp housing cover back into place on the television.!!! plug your set back in to the wall & The television is now ready for use. thank you
Oct 21, 2010 | Sony KDFE50A10 50" HDTV
Need fitting instructions for Nokia E63 replacement full housing.
get through your user manual provided with thw purchase of your mobile phone.you can find the instruction for replacement of housing....better to get a help of trained service engineer
Mar 20, 2010 | Nokia E63 Cell Phone
Unlocking Problem Nokia 6500s
your IMEI: 352027021230088
mastercode:
563773451x
The mastercode can be entered instead of standard security code.
please do not forget to rate this solution if it works.
and Thanks for using FixYa.
Oct 17, 2008 | Nokia 3590
Nokia 5310 fascia replacement
Here is a guide a wrote for replacing the front housing on a nokia 5310. It should be what you are looking for.
Nokia 5310 Front Housing Change
Hope that helps
Sep 21, 2008 | Nokia 5310 Cellular Phone
HOUSING REPLACEMENT INSTRUCTIONS
i have the instructions but will need to charge
Mar 26, 2008 | Nokia 8800 Cellular Phone
Replacing mokia n73 screen
Here's a video... http://www.youtube.com/watch?v=Byo_xRfklE8
Jul 19, 2007 | Nokia N73 Cellular Phone
Nokia 7373 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
