Question about Bosch HGS 255 Gas Kitchen Range
Oven does not heat but broiler does
Oven will not heat. The igniter is not glowing. The broiler works, the burners work as does the timers and clock. Only the oven will not ignite.
This is a Bosch HGS3052uc Gas range
  • 2 more comments
  • Olivenan Mar 22, 2008
    Igniter for oven does not glow. Igniter for the broiler (which is on top of the unit seperate from the oven) works fine.
    The oven igniter was the problem. Once installed, problem was resolved - Thanks
  • Anonymous Mar 25, 2014
    oven does not work
  • Anonymous Mar 27, 2014
    the electrical in the house works so that is not the problem for the oven and burners not to heat up
  • 871 Answers
First thing to suspect would be a weak igniter....see if the amp draw while the igniter is glowing matches the amp rating of the gas valve, the value will be on the side of the valve, if the amp draw of the igniter is lower than the rating of the valve you would need to replace the glow coil/igniter.
Posted on Mar 22, 2008
  • 3,037 Answers
The most common cause of this symptom is a defective ignitor. Oven ignitors can glow and allow enough current through to open the oven gas valve but just not produce enough heat to ignite the gas immediately (see the link below).
In that case, replacing the oven ignitor is the usual solution.
http://www.appliance411.com/links/jump.cgi?ID=823
  • Benjamin Patri
    Benjamin Patri Mar 25, 2008
    no problem, have a good day
Gas burners on top of stove work but broiler & oven do not heat up.
Hello'
Does your model have an electronic ignition? If so open broiler drawer ,turn on oven and look for bright orange glow. May take a few seconds.If it glows but no or poor flame .replace oven igniter.If no glow at all , check for voltage at igniter when switched on to see if it may be oven thermostat . Get a tech to test if not sure.All easy to fix.
Hope this helps
Aug 16, 2011 | Ovens
I have a Hot point electric ignition oven and the burners are working fine but the oven is not heating up with no smell of gas when i turn the knob. Any ideas about the problem would be appreciated....
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Oct 07, 2010 | Hotpoint RGB535 Gas Kitchen Range
The oven won't ignite. The broiler does and the top works fine.
This problem is commonly attributed to a bad igniter on the bake manifold in the bottom of the oven. As the igniters age from repeated use, they can become weak and longer function properly. Just because they glow, does not mean they are good. If you are experiencing ignition problems, the following link explains a little theory about how these igniters work and how to replace one:
http://www.fixya.com/support/r3575727-replacing_an_oven_igniter_on_a_gas_range
The burner manifolds in most ovens each use a glow bar or electrode type igniter with a gas safety valve to ignite. Both oven manifolds are controlled by the Electronic Oven Control (EOC) board, which is your clock/timer on the control panel. If the surface burners work, but the oven does not, the problem is usually not a gas related issue. If a single igniter is still working (i.e., the broiler still works), its more than likely NOT a control board issue, either.
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between these sites, so shop and compare. The first three sites listed also offer helpful exploded view diagrams to help you locate and properly identify the parts you need.
NOTE: It is common for the BAKE igniter to require replacement more often than the broiler, due to the frequency of use.
If you have any questions please post back with your complete MODEL NUMBER and let me know. I hope this helps you.
Oct 06, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
My oven suddenly quit working - broiler works and burners, but the oven will not heat and there is the smell of gas whenever I turn the oven controls on. Can light the bottom burner of the oven with a...
More than likely, you have a bad igniter. As the igniters age from repeated use, they can become weak and longer function properly. Just because they glow, does not mean they are good. If you are experiencing ignition problems, the following link explains a little theory about how these igniters work and how to replace one:
The burner manifolds in the oven each use a glow bar or electrode type igniter with a gas safety valve to ignite. Both oven manifolds are controlled by the Electronic Oven Control (EOC) board, which is your clock/timer on the control panel. If the surface burners work, but the oven does not, the problem is usually not a gas related issue. If a single igniter is still working (i.e., the broiler still works), its more than likely NOT a control board issue, either.
repairclinic.com
Prices vary between these sites, so shop and compare. The first three sites listed also offer helpful exploded view diagrams to help you locate and properly identify the parts you need. If the model number is correct, the part number for a replacement igniter is WB2X9154.
If you have any questions please post back and let me know. I hope this helps you.
Oct 05, 2010 | GE JGBP24 Gas Kitchen Range
The oven won't heat up the broiler works
repairclinic.com
Prices vary between these sites, so shop and compare. The first three sites listed also offer helpful exploded view diagrams to help you locate and properly identify the parts you need. If the model number is correct, the part number for a replacement igniter is 330688.
Sep 15, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven ignitor works and gets hot but no gas comes out no odor and no flame but the burners work perfect. and the erc works too timer works clock nd all
Just because it glows that does not mean it is not bad...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Aug 17, 2010 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
OVEN WONT LIGHT BUT BURNERS AND BROILER DO. TAPPAN 30-3860-23/03
More than likely, you have a bad igniter on the bake manifold in the oven. As the igniters age from repeated use, they can become weak and longer function properly. Just because they glow, does not mean they are good. If you are experiencing ignition problems, the following link explains a little theory about how these igniters work and how to replace one:
The burner manifolds in the oven each use a glow bar or electrode type igniter with a gas safety valve to ignite. Both oven manifolds are controlled by the Electronic Oven Control (EOC) board, which is your clock/timer on the control panel. If the surface burners work, but the oven does not, the problem is usually not a gas related issue. Since the broiler still works, its more than likely not a control board issue, either.
repairclinic.com
Prices vary between these sites, so shop and compare. The first three sites listed also offer helpful exploded view diagrams to help you locate and properly identify the parts you need. The part number for a replacement igniter for the model you have listed is 5303935066. The price is about $23. NOTE: It is common for the BAKE igniter to require replacement more often than the broiler, due to the frequency of use.
Aug 12, 2010 | Tappan TGFS_63 Gas Kitchen Range
Oven does not light. Top ignitor glows red bottom
Since BOTH oven manifolds and surface burners are usually fed from the same source, this is probably the result of failed igniter(s) in the oven. This is assuming that your surface burners are working, or course. If you are trying to light the BAKE manifold, the broiler manifold is used on some model to speed up the pre-heat process. So, you may see the broiler attempt to light as well. If you have tried using only the broiler by itself and it still does not light, you may have a weak igniter on that manifold as well. Double check your symptoms.
If this is a GAS range, as these igniters age from repeated use, they can become weak and longer function. If you are experiencing ignition problems, the following link explains a little theory about how these igniters work and how to replace one:
The burner manifolds in the oven each use a glow bar or electrode type igniter with a gas safety valve to ignite. Both oven manifolds are controlled by the Electronic Oven Control (EOC) board, which is your clock/timer on the control panel. If the surface burners work, but the oven does not, the problem is usually not a gas related issue. It can be a control board issue, but is usually a weak or failed oven igniter.
repairclinic.com
If you have any questions please post back with a complete MODEL NUMBER and let me know. I hope this helps you.
Jul 19, 2010 | Tappan TGF657 Gas Kitchen Range
The lower oven ignighter does not glow
I had the same problem and swapped the oven igniter with the broiler igniter and the oven now works. This proved the oven igniter itself was the fault, now I have to replace the broiler igniter with a new one(which is much easier to get to).
FYI: An igniter may glow red and still not allow the oven to work. The igniter has to draw a certain amount of electrical current for the main gas valve to open.
Jul 20, 2009 | GE JGRP17 Gas Single Oven
Magic Chef oven & broiler do not work
you know i am thinking more towards a bad temp probe.
May 28, 2009 | Magic Chef 31000 Gas Kitchen Range
Bosch HGS 255 Gas Kitchen Range Logo
2,737 people viewed this question
Top Bosch Kitchen Ranges Experts
Oloyede Monsuru
Joseph Hoffmann
Are you a Bosch Kitchen Range Expert? Answer questions, earn points and help others
