Hello there ,
i've a serious problem with my sonydvd rw aw-g170a device.
it stopped functioning for dvd's only
..................do u have any solutions.
please mail me if u have [email protected]
you might want to try and update the firmware on the DVD burner, find out with the vendor if there is a fw version and how to do it, if not I would suggest hiring a professional.
The yellow exclamation point is telling you there is a problem with the device. First thing to do is uninstall the device using your hardware or device manager. Reboot. Your pc should automatically recognize the device on reboot and install the proper drivers. If not then you will have to go to the Sony website and download & install the drivers manually. If this does not fix the problem then your drive has went bad & will need replaced. Good luck & I hope this helps you out.
I believe the read head is not aligned properly. I would send it back for a replacement. I have had this happen several time after the DVD burners/readers had many hours on them.
Hi i have Sony AW-G170A on 2 pc's and almoust at same period both
pc's started not to read DVD cds, cds that were writen by the same
drive so ive check the net and end up updating the Firmwares 1.71 to
1.75 so check this link. And get AW-G170A Firmware 1.75 then u gonna need Binflash to update the Firmware get Win32 GUI version if u use Win Xp. Open the program press Flash find the location of the 1.75 Firmware and update it restart pc and it should work it worked for me.
the drivers are part of windows
what they look as though they did was rerun the m/board setup disk and install the m/board drivers
try removing the upper and lower filters
scroll down to how here http://support.microsoft.com/?scid=k...060&x=12&y=13#
check for a firmware update
the laser may be dirty or has gone
try the drive on another computer
This is a problem with the DVD Writer model.
SONY DVD RW AW-G170a has problems reading DVD+/- R/RW Discs.
But there is no problem with any of the DVD+/- R/RW Dual Layer, DVD Ram or CD+/- R/RW Discs.
It is the reason that this DVD Writer lacks the correct bitsetting for DVD+/- R/RW Discs.
There is nothing else you could do other than replacing the wirter with some other model.
