Question about Tomtom GO 510 GPS Receiver
TomTom 510 Sat Nav
Dear Sir/Madam,
I accidentally connected the wrong mains charger my Tom Tom 510. (but only 6V dc as opposed to the correct 5V dc charger) This resulted in a smell of electrical burning and a bright white screen which I was unable to switch off. After several hours the battery was drained and the screen returned to the normal off state. It it worth mending?
Thank you for your help.
Paul
    President:
  • 2,072 Answers
Most likey its not worth fixing. Look at it like this. While it may have only been 6 volts versus 5. One volt in a 5 volt system is a 20 percent increase.
If you took something that ran on 120 volts and plugged it into a 144 volt source you can figure the damage that would do.
Posted on Mar 22, 2008
SOURCE:
My tomtom go 510 will not charge in car but ok at home
The Car chargers are generally the defective unit.
I have also faced a similar issue as the spring loaded cigarette lighter was pushing the charger causing it to disconnect.
Jul 31, 2016 | Tomtom GPS
Iwant to download truck routes to my tom tom 510
Just go to the tomtom website (see below), and find the desired map (update) for your device.
https://tomtom.com/en_gb/sat-nav/maps-services/shop/travel-map/
Dec 31, 2015 | Tomtom GO 510 Car GPS Receiver
My tom tom 510 mount broke from the housing. Can
Hello sir, i am sure if you head to TomTom.com and looking under accessories for your model you will find what you are looking.
Jan 06, 2010 | Tomtom GO 510 GPS Receiver
Tomtom one sat nav 18 months old is now taking upto 5 minutes to get a gps signal. When desination is entered the calculation is done tap done and continue then it says gps signal was lost and takes...
try downloading tom tom home to your computer and use your dock or cable to connect it to your computer, switch on your tomtom and allow it to connect to your computer and updates should automatically happen, this should fix it, good luck
Aug 26, 2009 | Tomtom One XL GPS Receiver
Where to get in car charger for evesham 7211
Hi.
I just bought an in-car charger for the 7211 on ebay.
It is 5v with a 2amp flow.
It's not for the mini-USB port on the side but for the dc input hole on the other side.
I've just plugged it into my laptop via the mini-USB port to see if it will charge that way but it doesn't seem to be doing.
Hope this helps.
Aug 09, 2009 | Evesham Nav-Cam 7700 GPS Receiver
Sat nav tomtom 910
Complain to Tom Tom ,you may have a lemon,look for law suit soon
Feb 23, 2008 | Tomtom GO 910 GPS Receiver
Tom tom go 510 Sat Nav
leave on charge for two hours, then with the SD card out hold down the reset button at the back of unit for ten seconds and then the 'on' switch for ten seconds.
STEP 1
Connect your TomTom to your
computer True True (``````````` (``````````` 0 95250 95250 clip_image002.gif via USB and open up your Windows Explorer and go to the drive. (It will be listed as TOMTOM (E) or some other drive letter).
Copy the Yellow Folders one by one to your PC. Ideally, save all the folders under a new folder that you name.
You may find that the folder ttntools and gns may not be copied. This is o.k. if they aren't.
STEP 2
Format your Tomtom via MY Computer.
STEP 3
Copy the Yellow Folders from the
backup True True (``````````` (``````````` 0 95250 95250 clip_image002.gif you made in STEP 1 back to the TomTom.
STEP 4
Open TomTom Home
Click on Upate Now.
Install the latest update onto your TomTom.
Once installed, switch your TomTom off, then disconnect if from the PC.
Thats it. From now on, make a full backup using TomTom Home prior to any updates.
Also note, that copying all the files will take some time.
Jan 25, 2008 | Tomtom GO 510 GPS Receiver
Frozen tomtom
Is there a reset button? See this from PocketGPSworld.com: Reset hole The Reset hole is hard to find, you need to first remove it from the mount, turn it upside down, and within the mounting base area of GO you will see two interface slots (currently only one is being used) and towards the front of the unit on the base you will see a little hole marked reset. This is just like soft resetting a Palm or Pocket PC, it requires something small like a paperclip, and nothing was supplied with GO to enable you to easily reset the device.
Feb 25, 2007 | Tomtom GO 510 GPS Receiver
GPS Logo
127 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
