Question about Creative Labs ZEN V Plus MP3 Player
Creative zen v plus
Usb doesnt recognized by the computer
my player will charge from the pc but i cannot transfer any files as the software is saying my player is not connected when it is, ive tried reinstalling the software but this wont resolve the problem should i return it to the shop as theirs only 2 weeks left on the guarantee ?
  • 12 more comments
  • Anonymous Mar 22, 2008
    Got exactly the same problem!
  • kavit Mar 23, 2008
    reinstalling the software but this wont resolve the problem....
  • Anonymous Mar 26, 2008
    I have the same exact problem! So Sux :(
    i have the same problem also. I plug it in to the usb and nothing comes up and on the play/pause button a blue light will fade on and off
  • Anonymous Mar 28, 2008
    same
  • Anonymous Apr 15, 2008
    my zen when i plug it into my computer it saysre building library then it loads 1/4 the way then it stops and all my music and everything else is gone
  • info278 Aug 06, 2008
    my divice in first step look in plag and play but during driver inistall exit
  • kezzafergo Aug 06, 2008
    Im having the exact same problem! first it wouldnt charge at all, so i spent all day onlne trying to figure it out. its been charging for 13 hours and still isnt fully charged. now my oc is saying it isnt connected, when it is, so i cant transfer files. how annoying! i thought these things were meant to be great!
  • Anonymous Sep 08, 2008
    mtp device not connected
  • leila_sh110 Oct 12, 2008
    usb doesnt recognized by the computer,
  • Anonymous Oct 13, 2008
    its been a long *** time since i had my creative zen v plus , and just like 3 weeks ago it started to do this **** to me man , its bull ,i need help
  • george_loyol Mar 11, 2009
    the player cant open & transfer the songs & other media from computer.
    how i can....help me..ple..
  • Anonymous Apr 26, 2009
    Creative Zen V plus used to work, now "There is an error with your device" MTP driver did not work.  But the MP3 player works fine on my friend's computer.
    How can I get windows to forget everything it ever knew about this player and then reinstall the driver (I tried the traditional method of uninstalling from the device manager and reinstalling) it almost gets to the end, but then it fails.
    It worked before, what did windows do? Anybody know?
  • alliesmp3 May 11, 2010
    Can you tell me the name of the software? Is it avisynth? I don't see anything that resembles creative...thanks.
I had the same problem but solved it, it seems that the usb driver does not always install with the software installation so you must install using the DEVICE MANAGER make sure first your mp3 player is connected, so ( copy & paste) your software to desktop, then go to CONTROL PANEL, then SYSTEM, then HARDWARE then DEVICE MANAGER, in device manager you should see ( zen v plus ) with a yellow question mark above it, which means the drivers are missing, click onto that and follow instructions to install the drivers which you will find in the software you have pasted to desktop. good luck, tony spain
Posted on Mar 24, 2008
  • 4 Answers
This is a common problem when the battery is completely depleted. You may also see a windows pop up saying that an MTP device is connected. The first thing to do is to let the zen charge up at least some. The second thing is to go into the device manager in control panel and locate the MTP device under portable storage. Then right click on the MTP device from the list and UNinstall. Then, unplug your player, wait a few seconds and plug it in. Hopefully this time your software will load properly and your computer will recognize the zen.
Posted on Mar 23, 2008
SOURCE:
I installed the PC Suite for my LG BL40, but it won't connect via USB and my computer doesn't have a bluetooth device. |Ive tried everything suggested and when I connect choosing Music Sync, it connects bu...
First, syncing is the transfer of data between computer software's that are designed to acquire and share with another entity. The sync function usually is embedded in the computer program. Once the computer recognizes compatible software that has several capabilities including transferring data, a USB connection capacity should be achievable. Usually devices that are designed for data transferability should be capable of acquiring a USB connection either as physical cables or wireless Bluetooth technology. The power to sync is contained in the software program. Once software that has sync capabilities is installed on the computer, any USB cable that is attached to an empty port would display a user message asking for further procedures. For example, USB connections on the computer that has media software's would display device recognizes link requiring data transfer. The solution lies in the software that is relied on for sync capabilities. Acquire Windows Media player, Real One player, or ITunes player as downloadable onto the computer to achieve compatibility.
Important Notes
USB ports are available on all computers as versatile connection links to devices that would require communications. The computers original systems are expected to recognize USB cable connection as manufacturers default. Usually, the computer is likely capable of upgrading several software programs that would least communicate with the USB. For example, the program suit installed has compatibility requirements to perform on the computer as an entity. Also, the program suit requires compatibility with USB connection for another device that would be connected to the computer. Attempt to install media transfer programs that are designed with sync features.
Jan 26, 2011 | Computers & Internet
My system is not supporting coby MP-7052gb I want coby software for file transfer
Your system should support it, most likely your computer doesnt recognize the device on MTP mode, you can switch this on the device, go to Setup Mode > System > USB Mode > put the USB Mode to MSC, and then reconnect the MP3 player to your computer, the MP3 player should then show up as a Removable Disk drive under 'My Computer'.
May 21, 2010 | Coby MP-705 Digital Media Player
Computer wont play a video i recored with my camera on my sd card
I understand, if you are able to record on the SD card, make your computer to recognize it and lastly if you can transfer it successfully with no errors, we can make it to work by choosing an appropriate media player. I personally would recommend VLC player. Latest version of this software can be found in:
www.filehippo.com
Still if you are not able to open/run the media file. Let me know the type of file. I ll then according do a research and suggest a specific codec or a player that will support the file type.
File type can be found be right-clicking on the file and selecting Properties.
Jan 15, 2010 | Acer Extensa 5620 Notebook PC
I am trying to put more songs onto my mp3 player. The songs show that they're on there on the computer, but when i unplug it the songs aren't shown on there. It says i have plenty of space, so that's not...
Hello.
Welcome To Fixya.
In order to have a succesful Transfer of songs from you computer to your mp3 player follow these Steps:
1/ Install:
  1. Insert the CD supplied with your product into the CD ROM drive of your PC.
  2. Follow the on-screen instructions to complete the installation of Philips Device Manager and Philips Media Converter. The Philips Media Converter converts video clips and JPEG pictures into suitable formats for the player.
2/ Connect and charge:
  1. Connect to PC:
    When you connect the player to the PC, it automatically charges.
  2. Connect the supplied USB cable to the mini USB port at the bottom of the player, the other end to your PC.
3/ Transfer:
Your player appears as a USB mass storage in Windows Explorer. You can organize files, transfer music and picture to your player during USB connection. Use Philips Media Converter to transfer video file. See Media Converter for details.
Transfer music:
  1. Click and highlight one or more songs to transfer between your player and your computer.
  2. Use drag and drop actions to complete your transfer.
Tip : To transfer music CDs to the player use software such as Musicmatch Jukebox or Windows Media Player, rip (convert) the songs on your music CD into MP3/WMA files. Copy the files into the digital audio player via Windows Explorer. Free versions of these programs can be downloaded from the internet.
Also you can Transfer Video:
The Philips Media Converter converts video clips and JPEG pictures into suitable formats for the player. You can install the software from the supplied CD.
Thank You For Using Fixya.
Good Luck.
Nov 06, 2009 | Philips SA3025/37 Flash MP3 Player
Samsung YP-U3 is not recognized by computer
it is not appering in my copmuters but it is charging.
Jul 23, 2009 | Samsung YP-U3 MP3 Player
Issues downloading audio files from Sony minidisc to my computer
You can't. You can only transfer digital files from your pc to your Minidisc player., it's a one way street. there's no hack for it either as it's a basic hardware issue within the player itself.
If you want to download from the player to the pc you'll have to connect the audio output to your pc and record it the old-fashioned way which loses a bit of quality. All Minidisc compliant players were like this until the advent of the Hi MD format which succeeded the Net MD's as an anti-piracy measure.
Mar 23, 2009 | Sony NetMD Walkman MZ-NF810...
Iriver E100 is not recognized on PC
That might be a blessing in disguise. I have never liked the non-MSD option, but I tolerate it. You should be able to transfer and view files with the computer recognizing it as an MSD device. If you insist on changing it, use the iRiver plus 3 software from iRiver's website to update the firmware on the player, and your computer will no longer treat it as a Mass Storage Device - don't say I didn't warn you.
-Tha Mp3 Doctor
Dec 26, 2008 | iRiver E100 Digital Media Player
S3 won't allow file transfer.
SOLUTION FOUND!!! NO DRIVER PROBLEM ...Right click on my computer,go down to properties ..next window click the hardware tab,then click on device manager...right click and goto properties on ALL your "usb ports"...goto power management and uncheck the power saving box for every usb port,and click ok,then restart.!
Aug 09, 2008 | Samsung YP-S3JAB Digital Media Player
Vision M not recognized
I'm having the exact same problem. My zen is 'charging' but isn't detected anywhere on my pc and I'd leave it charging for days but nothing happens. I've tried different usb ports, reinstalling the software several times but nothing. I recently reinstalled Windows and with my new pc my Zen cannot work on it for some reason?! I put previous files from my old pc onto my Zen hoping that I could transfer them onto my new Windows pc but I fear I've lost the data on my Zen completely. Arggh, any suggestions guys? Please..x
Feb 29, 2008 | Creative Labs Zen Touch MP3 Player
Creative ZEN Vision M
Zen Vision:M Not Responding SOLUTION! to No Charge, Device Not Connected or Recognize
If that doesn't fix it try the USB cable
Screen Doesn’t come on anymore
http://www.anythingbutipod.com/forum/showthread.php?t=18859
If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
Feb 13, 2008 | Creative Labs ZEN Vision:M Digital Media...
Creative Labs ZEN V Plus MP3 Player Logo
854 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Ekse
Marvin
Marvin
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
