Question about Liebherr Custom Finish 24" Right Hinge Built-In BioFresh/Refrigerator - RBI-1400
Leibherr side by side fridge/fridge freezer
Our side by side was noisy from the start, it sounded as though there was a high wind blowing in the kitchen? Now the small fridge ( over the freezer) has stopped completely along with the ice maker (in the freezer below)?
The other large fridge is always frosted up on it's back wall.
Any idea's experts?
Tanks
Nicki Evans
  • 1 more comment
  • Nicki-noo Mar 25, 2008
    Thankyou for your response.
    No sadly the warranty is void, it's not the freezer that has stopped but the fridge that sits on top of the freezer. This was what made the 'high wind atop a mountain' noise until it stopped working, the integral ice maker in the freezer below packed up at the same time?
    Could these have been damaged in transit (we shipped from the UK when brand new) or are these common problems?
    Thankyou
    Nicki-noo
    We have a new Leibherr fridge on top of freezer which we have shipped so negated the warranty. From the outset the fridge made a loud ' high winds' noise and eventually stopped working along with the integral ice maker in the freezer below, can you offer any suggestions?
    Thankyou
    Nicki-noo
    Sorry I didn't see the second reply/assistance as i was only reading the copy in the green box.
    I am very grateful for all advice and certainly wouldn't refuse any.
    Many thanks
  • Liebherr Master
  • 19,396 Answers
Here is Lieberr contact worldwide. Contact them and get the address for nearest authorized service. You refused solutions from two good experts, I think they were addressing the problem well.
Probably the best solution in your case will be contacting the nearest service.
Regards
Posted on Mar 25, 2008
  • 3,037 Answers
The fridge being frosted up is good, that means that that cooling unit is working but you may have it set a little cooler than needed.
You may have a faulty cooling system for the freezer because it shouldn't be louder than any other refrigerator. The fan might've been running much higher than normal and eventually burnt out. If you still have this under warranty, I would call them up on this. I would first call the store, when we buy a new appliance, we usually extend the warranty and make sure that it covers a free visit to our home if something major may go wrong.
If anything, you will probably have to replace parts from the freezer unit, have you noticed any liquid from the cooling system, possibly the compressor has gone bad and needs to be replaced
*Be Careful, if there is a capacitor, you will need to discharge it before working
Good luck with this
Posted on Mar 22, 2008
  • Benjamin Patri
    Benjamin Patri Mar 22, 2008
    here is a good website for you to view, if you want to take it apart and know how certain parts work
    http://home.howstuffworks.com/how-to-rep...
  • Benjamin Patri
    Benjamin Patri Mar 25, 2008
    have you figured out the problem or is there anything else that you have questions on? Please let us know, we are here to help!
    Genius:
  • 1,665 Answers
It seems to be a compressor problem or loss of coolant liquid
  • 3 more comments
  • Kleanthis Mavropoulos
    Kleanthis Mavropoulos Mar 22, 2008
    (The ice maker has completely stopped producing ice )
    Check to see whether the ice maker has been turned off.
    Here's how to check.
    Look for a wire along the right side of the ice maker that looks a bit like a coat hanger.
    If this wire is in the raised position, the ice maker is turned off.
    On some units you simply lower the wire to the down position to turn the ice maker on.
    On others, you lower a small red plastic lever to lower the wire.
    If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit.
    If it is warmer than 10-12 degrees, the ice maker may not produce any ice.
    Check your door seals and thermostat, repair/replace as necessary
    Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling.
    The fan is located in the freezer, as follows:
    • If the freezer is on top, the fan is on the back wall, near the top or bottom, in the center of the freezer.
    • If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer.
    • If the freezer is on the left, the fan is on the back wall, halfway up or near the top.
    Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead.
    To find out if the fan is causing the noise, just open the freezer door and push in any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause.
    You can't lubricate or repair this motor. You must replace it.
    Here's an inexpensive, though inconvenient, way to determine if the problem is
    with the self-defrosting system. Remove all of the perishable food from the
    refrigerator and freezer, turn the thermostat in the refrigerator to Off, and
    leave the doors open for 24 to 48 hours.
    (Be sure to have several towels ready
    in case the melting frost and ice causes the drip pan to overflow). This allows
    the refrigerator to defrost "manually." When the frost and ice build-up has
    completely melted away, turn the thermostat back to a normal setting. If the
    refrigerator then cools properly, it indicates a problem with one of three
    components in the self-defrosting system:
    • The defrost timer
    • The defrost thermostat (also called the bi-metal switch)
    • The defrost heater
    If it still does not cool properly,
    there may be a problem with the refrigerant level or the compressor. You may
    need to consult with a qualified appliance repair technician to further diagnose
    the problem
    Kleanthis Mavropoulos Mar 25, 2008
    You may need to consult with a qualified appliance repair technician to further diagnose if the problem can be solved.
How does a side by side domestic fridge work
Freezer one side, refrigerator the other side. Compressor is in the bottom at the rear. Often ice and water dispensers in the door.
Jan 23, 2016 | Refrigerators
Leibherr freezer icing up and not staying at right temp
Probably the heating element in the defroster is not working
Mar 30, 2013 | Refrigerators
Refrigerator making a high pitch vibrating sound
Sounds like the fan from the freezer that blows the cold air into the refrigerator is noisy. It either needs replacement, or lubrication. Good Luck, I hope this helped Please rate me, Thanks
Jan 12, 2010 | Refrigerators
GE Profile GSS25LGMB
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Sep 05, 2009 | GE GSS25LGM Side by Side Refrigerator
Refrigerator not working but freezer is
You have two vents between the freezer and fridge. The one the cold air from the freezer comes through(blown by the fan) and the other vent is a return vent back to the freezer. On a side/side they're at the top and bottom. It sounds like the bottom one may be blocked by food or frosted closed by ice.
Aug 22, 2009 | Refrigerators
Maytag msd2456dew not cooling / not freezing after noisy fan
my Matytag msd2456dew fridge fan is running, no ice bulid up on coils in freezer section, but no cold air to freeze anything in freezer section or cold air in fridge section. what can be the problem?
Sham
Feb 15, 2009 | Maytag Refrigerators
Bottom of freezer/fridge only getting cold.
Thre is a fan inside the freezer which circulates the cold air around both the fridge and the freezer compartments.
You should be able to feel cold air blowing around the inside, particularly at the top of the freezer.
If the defrost thermostat fails open, the internal fan (depending on freezer) will stop and this can be the cause of the freezer being warm at the top and no ice.
You say the bottom of the freezer is blowing cold, but are you sure its blowing, as it can feel like a cold blow. Of course the fan could have failed or may be the defrost heater itself.
Have a look at this site for some useful trouble shooting
And a good site for troubleshooting and general info
Refrigeration Help Section, Fridges, refrigerators, not cold enough, frost free problems and how to test, noisy fan motors, clicking on and off compressors, door gaskets
Nige
Sep 26, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Frosty bottom of Leibher Freezer (supposed to be no frost)
 I am trying to contact Leibherr; I see that production is located in the United Kingdom. I have found an office located in New York. I’m sure this is not helpful and your freezer is very expensive and I will try to get technical information (if they will allow me access). Sounds as if the defrost timer is not working and that would be the first thing I would look at if I could see the wiring diagram. If it is a common defrost it will be a timer that cycles every 8 hours. If it’s a digital defrost with circuit board I won’t be able to locate it until I get a response from Leibherr. The problem could also be in the defrost element. Here is the link that I have found.  Let me know anything or information you have obtain since the beginning of your search that will help me help you get the problem solved, Thank You, Sea Breeze HVAC
http://www.euro-parts.ca/English%20files/specials/index.html
Oct 24, 2007 | Freezers
Liebherr Custom Finish 24" Right Hinge Built-In BioFresh/Refrigerator - RBI-1400 Logo
251 people viewed this question
Top Liebherr Refrigerators Experts
Charles T Nevin
Charles T Nevin
Shehu Pro
Shehu Pro
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
