Question about Mercury P4VM800M7 Motherboard
Monitor my monitor bulb flashes once and then stops. all the wires to my mother board are secure and tight i dont kno wats wrong pls help me as soon as u can
  • Anonymous Mar 25, 2008
    the same one happen to me
    Genius:
  • 1,913 Answers
Hi''
when u pc start check ram beep.
after rthat check your key bord numlock key if your num lock is on and off your cpu is ok and your monitor haas pro.
other wise check your ram clear it and fix exactly in its position.check your processor refix it . clear your bios setup take away your cmos cell for 15 minutes then fix it.also try cmos jumper to reset it
Posted on Mar 23, 2008
Not showing normal display to Dell LCD monitor
If you look at the resolution on the monitor and match it with the windows resolution or download a driver for your monitor from Dell
Mar 17, 2014 | Asrock P4I45GV R5 Motherboard
MY MONITOR LIGHT IS FLASHING AND THE FAN COMES ON BUT MOTHER BOARD DOESN'T SEEM TO COME ON
CHECK WITH A OTHER MONITOR.
CHECK THE CABEL BETWEEN COMPUTER AND MONITOR
SHOULD BE SCREWED TIGHT.BE SURE THE VIDEOCARD IS
SCREWED TIGHT AND FIRMLY TO THE MOTHERBOARD.
THE VIDEOCARD CAN BE BROOKEN.
Feb 11, 2014 | ECS Mcp73pvt-sm With Hdmi Mcp73vt-pm...
Motherboard help
If this is a new mother board installation you my be grounded against the case. Remove the screws securing the mother board inplace, go to a hardware store and pick up some small rubber or paper washers to put between the mother board and case. This little tip has saved me many times.
Hope this helps
Jan 30, 2012 | Intel Motherboard
For many years, my monitor will flash too bright ocassionally. And it will stay too bright until I jiggle the whole monitor. I thought it is the connection in the back of the monitor, and if I jiggle this...
there is the problem with ur mother monitor mother board i.e. solders get moistures u have to re soldering the all the components of ur monitor mother board.
best solution is the, go to the nearest electronics repairing shop near by u.
May 29, 2011 | iiyama Vision Master Pro 450 Monitor
NOT SHOWS RESOLUTION 1360 by 768 IN 16" WIDE LG LCD MONITOR MY MOTHER BOARD IS GIGABYT INTEL CHIPSET 865, PLS GUIDE US
Hi!
Installing the video card driver can make use of its features of higher resolution support for your LCD monitor.
And also install the driver of your LCD monitor. This enable to use higher resolution that could provide with your computer video card as I have mentioned above.
Hope it helps..
Thank you for reaching Fixya.
Please leave comments for further assistance.
Apr 05, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
HCL HCM780M CIRCUIT DIAGRAM
SIR..., regarding monitor...display block characteristics which is operated manually by buttons situated bottom of monitor is anytime coming at the centre of monitor display... The settings block comes on suddenly and we are unable to exit from the same sometimes the block goes off without any action and everything is fine till it is back again and it is come again and again.....by all this i did'nt work on my PC...all result it's useles......please sir giving your suggestion as soon as possible....... This has been happening for the last 1 year and is a real pain Please send some solution
Jan 23, 2009 | Computers & Internet
My Computer
OK. Thanks for the response. That message is telling us that the monitor is getting no signal from the computer. In your case, it sounds like it is working part of the time. So, here are the things that can cause the problem, starting with the monitor and working backwards.
1) The monitor may have an internal problem.
2) The cable connector that goes into the monitor may have a loose connection or be bad. Check for loose or bent pins in the connector plug and socket, and that the plug is seated properly and is tight.
3) The cable itself could be damaged and have a wire that is cut or pinched. Look for cuts or heavy crimps on the cable.
4) The cable connector that goes into the computer may have a loose connection or be bad. Check for loose or bent pins in the connector plug and socket, and that the plug is seated properly and is tight.
5) There could be a problem with the computer that is internal. If there is a video card that plugs into the mother board, you could unplug it, clean the dust and such from the contacts on the card and around where the video card plugs in the mother board and reinsert the video card. Also, the video card itself could be bad,in which case it would need to be replaced. Some systems have the video function as a part of the mother board. If that's the case, the mother board would need to be replaced.
One thing that you can try when it is failing. While watching the monitor, firmly wiggle the cable and each of the connectors to see if the signal comes and goes. You may want to enlist someone to watch while you wiggle, or wiggle while you watch (That sounds kind'a bad doesn't it? <Grin>) But, that could tell us something.
Hope this helps and will be waiting to hear back from you on this.
Ron
Dec 16, 2008 | HP Vs17 17" LCD Flat Panel Monitor
Monitor flashes
If the power button flashes, You probably have a bad power-inverter board thats needs to be refurbished due to burned out capacitors and possibly a transistor or two.
If the screen flashes and the power button stays steady, it could be the same thing or a bad bulb in the screen.
Fran
Sep 30, 2008 | Gateway FPD1975W 19" LCD Monitor
Mercury P4VM800M7 Motherboard Logo
71 people viewed this question
Top Mercury Computers & Internet Experts
Mark Gough
Abhinandan  Patil
Abhinandan Patil
Alun Cox
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
