Question about Brother DCP 115C All-In-One InkJet Printer
Paper jam my printer says paper jam, open back cover, remove paper whenever i try to print on photo paper. but there's no paper jam. but i tried it on an ordinary paper, it works.i used to print on photo paper and it works fine until now.
  • rozone Dec 09, 2008
    my printer says paper jam, open back cover, remove paper but there's no paper jam. WHat can i do?
  • 832 Answers
Try another photopaper of less weight. It could be that the rubber of the paperfeeder is stained with paper dust.
What you also can try is:
take paper tray out.
use a sponge with a rough side (to clean very dirty pans) to scratch
along the grey rubber and to give the rubber more grip.
Posted on Mar 22, 2008
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
Epson Photo PX710W Unable to print on photo glossy paper. Always a paper jam message. Will print fine on ordinary paper. (Will print 6x4 size on upper tray). Help!! Geraint.
Im having the same problem, will print on normal paper but when I try to print onto Glossy paper it comes up with paper jam,or paper not loaded properly is anyone else hjaving this problem? Please help!!
Caroline.
Aug 25, 2010 | Epson Office Equipment & Supplies
Printer says Paper Jam but it is not
  1. Remove the paper from the paper tray.
  2. Press the Power button and then wait for the jam to clear.
    • If the paper jam cleared, try the print job again.
    • If the paper jam is not resolved, continue.
  3. Remove the rear access door. Press the handle to the right, and then pull out the door.
  4. Remove any paper that is inside the printer by pulling the paper out from the back of the printer.
  5. Replace the rear access door.
  6. If the paper jam cannot be removed from the back of the printer, raise the product cover, carefully remove the jam from the front of the product, and then lower the cover.
  7. Re-load the paper in the In tray. Fanning the paper makes sure that the pages are not stuck together.
  8. Press the Power button ( ) to turn on the product.
  9. Open the document in the application in which it was created.
  10. Click File, Print, Properties, Printing Preferences click Paper/Quality tab.
  11. Verify that the type of paper specified in the Type is text box matches the type of paper being used. A paper jam might result if photo paper is specified in the Printer Properties dialog box, but plain paper is loaded in the printer.
  12. Click OK to try job again.
Sep 22, 2009 | HP Deskjet D2360 InkJet Printer
I get a clicking noise when I print on a Dell 3115
The print cartridge carrier could be stuck and clicking agains the wall or gears might be clicking.
If your machine doesn't work at all, open the cartridge cover, take the cartridges out, close the cover, wait for it to call the carriage carrier to the side, then turn it off, unplug wait 2 minutes, plug it back in, turn it on, open the cover, install the cartridges back, close the cover and try printing again.
If that doesn't solve the problem follow these steps
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
If the problem still remains
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
After you have done all the suggestions, whats the status of your printer, are you still unable to print? is the printer still just clicking? are you able to remove the cartridges from the machine or is it just clicking?
If your not able to do the suggestions or the cartridges won't come to the center, your printer has a mechanical hardware problem that will require service.
Sep 05, 2009 | Computers & Internet
Brother MFC-9420CN Paper Jam Error message w/ loud grinding noiz
please try this
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Jun 09, 2009 | Brother MFC-9420CN All-In-One Laser...
Paper jam while printing on BROTHER MFC-290C all-in-one
hey
try this
alternative :
Jun 03, 2009 | Brother MFC-290C Printer
Paper jam notification after printing one page, no paper jam
try this
alternative :
Nov 16, 2008 | HP PSC 2210 All-In-One InkJet Printer
Paper jam
give this a shot
alternative :
Jul 08, 2008 | Brother Multi-Function Center MFC-665CW...
HP 1510 - Photo Paper Jams
Hi, try using HP brand photo paper, HP makes their special photo printers and special photo paper for them.
The surface of the back of the HP's paper is rough, like sandpaper to avoid the paper being jammed in the cheap loading mechanism of their actual printers.
Oct 11, 2007 | HP PSC 1510 All-In-One InkJet Printer
Brother DCP 115C All-In-One InkJet Printer Logo
219 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
