Question about GPS
X3-02 nextar gps
I just bought nextar x3-02 gps.it works first day next day i turn on and
freez on loading screen. i did try after battery die and push resat and
plugged in but nothing happed.somebody has idea to fix it
thanks
Three step solution, easily correctable. wrap in towel, smash with ball peen hammer, gently lay in trash. You should have no more issues after this.
Posted on Mar 22, 2008
I just purchased the nextar Q4-06 GPS. I set it
Try plugging it into your car with the AC Adapter. I just bought one too and had a problem getting it to do anything until I charged the battery and then everything worked great. Hope it works out for you.
Nov 26, 2009 | Nextar GPS
My nextar GPS screen is flashing and won't turn on or off. I have had it for 1 week. X3-08 Please let me know. Tim Nextar X3-08
try tapping the bottom right of the screen with your finger, during the error or freeze up. > (gently)
Sep 03, 2009 | Nextar X3-08 Car GPS Receiver
GPS stuck up
Since the operating system and navigation software are preloaded into the internal flash memory of the GPS, the freezing may either be software or hardware failure. First, press the "Reset" button or push the stylus into the "Reset" hole, to see if the navigation software can load successfully. If the program still does not load, then the software may be corrupted. Also, if the internal memory fails to read or write and the software cannot load properly, it may be caused by hardware failure. In this case you must return the unit for exchange or repair to the retail location from which you purchased it, or contact Nextar for further assistance.
For technical support for your Nextar GPS see http://www.nextar.com/frontend/support.asp or you can phone them on 888-849-0846
Jul 07, 2009 | Nextar X3-02 GPS Receiver
NEXTAR 14-bct KEEPS FREEZING UP.
I just opened up a Nextar 14-BCT GPS unit and found the inner side of the ribbon cable is cracked. This unit has the exact same freeze on load screen as you do, so try looking inside, you may need the LCD ribbon cable or both LCD and LCD ribbon cable for your unit to function normally again.
Feb 23, 2009 | Nextar I4-BC GPS Receiver
My nextar p3 freezes up
Sounds like the sensitivity is whacked...can you hear the type sound. Mine does this sometimes and I solve it by using 2 thumbs and constantly push the settings icon, on each side. It will bring up the x for sensitivity...using the stylus tap gently and then twice to set. Hope this is what you were looking for.
Dec 10, 2008 | Nextar P3 GPS Navigation System
Nextar HGPS35
I found this on Nextar support site. These units **** lots of problems being reported by many users.
Q: It (GPS) freezes on the "loading" screen. Why?
A: Since the operating system and navigation software are preloaded into the internal flash memory of the GPS, the freezing may either be software or hardware failure. First, press the "Reset" button or push the stylus into the "Reset" hole, to see if the navigation software can load successfully. If the program still does not load, then the software may be corrupted. Also, if the internal memory fails to read or write and the software cannot load properly, it may be caused by hardware failure. In either case, please return the unit for exchange or repair to the retail location from which you purchased it, or contact us for further assistance.
Jan 13, 2008 | Nextar X3B GPS Navigation System
Intellinav.exe application error
Did you try the switch on the back of the GPS? Turn off on the front, turn the switch on the back off, then on. This has worked for me numerous times.
Jan 06, 2008 | Nextar Q3 GPS Receiver
Loading screen
i had this problem...i dont know if its the right way to fix it but i let the battery die and left it sit for awhile. then i held the reset button down then plugged it in and it came to the loading screen and a second later it finished loading up
Dec 25, 2007 | Nextar X3B GPS Navigation System
Nextar x3-02
I just bought one P3. The SD card does not load the maps!!! I am going to return right away...
Dec 20, 2007 | Nextar X3B GPS Navigation System
Nextar X3B
let the batter die. then hold the reset button and plug it in at the same time. itll take a second but i loaded up for me after a couple seconds.
Nov 24, 2007 | Nextar X3B GPS Navigation System
GPS Logo
180 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
