Kef Ceiling Speaker
The speaker only works when you touch the speaker foam
  • 4 Answers
Hi, probably there is a false contatc between the cords and the coil. If is visible could be resolded otherwise the speaker has to be replaced.
Posted on Mar 22, 2008
SOURCE:
How do I open up a Kef egg speaker
9aa4f771-e31b-4b6e-a152-d7f1795ba2f6.jpgRemove the rubber ring around the speaker, by pull gently outwards. then remove the speakers or resonator. if necessary remove the other side as well
Jan 26, 2012 | KEF Audio HTB2 Subwoofer
Hi Dear Support Team I just bought KEF Q300 speaker from online market in US and ship that speakers to Malaysia. Once I got it found that the HF of one speaker is not functioning. Please help me with...
Since even the KEF website has no manual for this model http://www.kef.com/us/support/download we're on our own.
In the picture of the rear panel look closely at the speaker posts and those silly link knobs for each one. Unless you're biwiring (BUY wiring) those minus contacts should be electrically connected to each other and the positives to each other. Most other speakers with this dubious capability have simply jumper bars in place to ensure continuity.
http://www.enjoyaudio.com/zbxe/?document_srl=2781068
I'm thinking you either have a mis-set Link Knob or one of them has simply failed. With volume turned down to something medium try manipulating them to see if the HF driver wakes up.
You can prove that the HF driver works or not by attaching the speaker wire directly to it (top pair).
No matter what the result I would advise you to contact them and demand a manual be made public.
http://www.kef.com/us/Contact
Jul 14, 2011 | KEF Q300 Speaker
My KEF (PSW 2150) ruffer speaker buzzes even with no input connection?
Your amplifier is bad. I sent mine to KEF in NY and they fixed it for $100 US.
Dec 08, 2010 | KEF Audio PSW 2150 Speaker
Replacement of the tweeter of KEF Audio Q55 Speaker
call kef. go to kef,com for the phone number. 28.02 plus vat per tweeter
Sep 27, 2010 | KEF Audio Q55 Speaker
KEF Speaker Sticky
My Dad had the same problem. KEF admitted it was a paint problem and replaced the speakers.
Sep 22, 2009 | KEF Audio KHT 2005.2 System
My KEF 20B subwoofer has stopped working since i accidently plugged it into my amp with the sub switched on, it made a quiet thud and now makes no sound at all, is there anything i can do with it? the LED...
Probably blew the speaker or the crossover coil. You can check it with both with an ohm meter to check for continuity. Disconnect the speaker and/or coil for the rest of the box before testing.
Jul 12, 2009 | KEF Audio 20B Speaker
KEF KHT6000ACE TWEETER DIED. HOW CAN I GET A NEW SPEAKER?
if the original KEF tweeter is no longer available there are other brand tweeters that should fit as a replacement option. just contact a repair center (us) and you can get options.
[email protected]
Jun 13, 2009 | KEF Audio KHT6000 Speaker
Blown kef q55.2 tweeter, is replacement possible?
The tweater on my Q55.2 blew as well. I went into a shop in NYC and they tried to charge me $225 for a new tweater, so I took it home and called up Kef. They sent me out a new tweater for $35 and instructions on how to solder it in.
It took all of 10 mins to replace and they are working fine. I've never soldered anything before and it was simple.
Cheers
Martin
Mar 24, 2009 | KEF Audio Q55 Speaker
Kef Q Series iQ1 problem
You may have broken the cross over, which is fixable by an service agent, or you may have damaged the voice coil in the mid driver. you can check this by sofly pushing the main driver in, making sure that you done push the cone, if there is a lot of resistance then you have damaged the voice coil, and you will need to replace the driver.
Dec 10, 2007 | KEF Audio Cresta 2 Speaker
35 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
