Question about Refrigerators
My LG model #LFX25960ST serial #802KRDJO1258 refrigerator temperature control panel display does not light up.I can't adjust the temperature or anything.I just bought it a week ago from Home Depot.It led up when I first plug it in But, after a few minutes it stopped why?I will never buy LG again :(
  • brendalisa Jan 24, 2009
    I have the same problem, but ours is not under warranty anymore. Any suggestions?
    President:
  • Refrigerators Master
  • 2,651 Answers
Let this be a lesson, never lg, but more important buying magor appliance form home depot. your under warr. call lg for service!
Posted on Mar 22, 2008
Where is the reset button on a hottpoint side by side refrigerator.
Self Diagnostics
To enter Self Diagnostic mode, both temperature control panel displays must be illuminated. A display can be illuminated by pressing an adjacent temperature adjustment button. When both displays are illuminated, set the freezer and refrigerator temperature settings to 5. Simultaneously press and hold all 4 temperature adjustment buttons for approximately 3 seconds. A flashing 0 in the refrigerator and freezer displays will indicate that the refrigerator is in Self Diagnostic mode.
To perform a self diagnostic test, locate the test in Table 2, Diagnostic Tests.
For temperature control panels with single-digit displays, the COLDER temperature adjustment button will increment the numbers up and the WARMER temperature adjustment button will increment the numbers down. Use the freezer temperature adjustment buttons to enter the test code number in the freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test. Press the HOLD button for 3 seconds to begin the test.
For temperature control panels with 3-digit displays, the COLDER temperature adjustment button will increment the numbers down and the WARMER temperature adjustment button will increment the numbers up. Use the freezer temperature adjustment buttons to enter the test code number in the freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test code. Press any button other than a temperature adjust button to begin the test.
When testing has been completed, do one of the following things:
• Enter code 1 5 to completely reset the system.
• Enter code 1 6 to exit diagnostic mode. The temperature control panel is reset automatically.
• Unplug the refrigerator for at least 10 seconds. Test mode will terminate when the refrigerator is plugged back in.
Test mode will terminate automatically after 15 minutes of inactivity.
Read more: http://appliancejunk.com/forums/index.php?topic=10408.0#ixzz3VIqUINVz
Feb 27, 2015 | Hotpoint HSS25GFT 25.0 Cu. Ft....
LG LFX25960ST switch temperature display
Do you mean that the display is "stuck", and none of the buttons seem to work? That could be a status code that the refrigerator is displaying to indicate a problem. The decode of those lights should be on the schematic, which will be under a plastic cover at the top of the refrigerator, or behind a cover in the back, or in a pocket underneath.
Sep 28, 2011 | LG LFX25960ST Stainless Steel French Door...
HOW DO I FORCE A HOTPOINT SIDE BY SIDE REFRIGERATOR (HSS25GFTA) WITH AN ADAPTIVE DEFROST TIMER INTO DEFROST MODE?
Start a diagnotsics mode and enter test code 1 - 4 of the diagnostics to start the defrost mode
Self Diagnostics
(or in your case.... after the deforst cycle completes and possibly + 15 minutes)
Thanks for choosing FixYa,
Kelly
Aug 23, 2011 | Refrigerators
It is saying err ff what does this mean
That means the control board is not seeing a feedback signal from the freezer fan. The fan blade may be blocked by frost or ice.
Mar 06, 2011 | LG LFX25960ST Stainless Steel French Door...
Refrigerator light stays on ?
LG has a wonderful way of turning on their refrigerator lights, they have the control board do it. Very nicely done in theory but in reality I would trust a handy door switch to control the light on/off function then a relay that get's stuck. That's right, the relay is stuck on the control board. Pull light bulbs out quickly before plastic melts on the inside top panel of fridge. Call LG, it should be covered under warranty.
Nov 24, 2010 | LG LFX25960ST Stainless Steel French Door...
Control panel stuck. not able to change any
Unplug the refrigerator from the power socket for 30 seconds. When you plug it back in the control panel should reset showing all 8s for several seconds and then return to normal settings. If that does not solve the problem then the controller board probably needs to be replaced. As part of the settlement with Energy Star, LG is supposed to be replacing controller boards for free so your problem could be solved by that if you qualify. See http://www.energy.gov/news/6743.htm. Use phone number to contact LG as the web site did not work three times when I tried to register through it.
Sep 05, 2009 | LG LFX25960ST Stainless Steel French Door...
LG French Door Model LFX 25960--Freezing in right crisper door
Have person who changed out you controlboard come back and recheck connections and controlboard itself.
Jul 26, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
Temperature settings
I don't have any instructions for your particular model but usually you start in the middle and adjust up or down as needed. (example if lettered A B C D E start with C). Most (but not all) refrigerators have an off position on either the refrigerator or the freezer but not both. Whichever control has a definate off position controls the coldness in both. The other control just adjusts the difference between fridge and freezer. Almost all refrigerators have cooling coils only in the freezer, the fridge is cooled by blowing cold air from the freezer.
Jul 01, 2008 | LG LFX25960ST Stainless Steel French Door...
The control panel light blinking and ice trap door will not close
Sounds like you need a new display pwb. The flapper for the ice works on a solenoid which is on a little board that is behind the display board. When the power is cut the flapper should close as it is on a spring. I don't believe that there is any worries of it catching fire. Have a tech come and replace the board for you.
Sgt 48
Jun 03, 2008 | LG LFX25960ST Stainless Steel French Door...
Refrigerators Logo
501 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
