FixYa.com
Tags:
JVC DF420 D-VHS Tape
Tape won't play (by 2 users)
posted by kar2kaj on Mar 22, 2008
I rewound the tape & now it won't play or fast forward.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Grace_329092, posted on Jul 08, 2008
I rewound the tape and it has snapped, is there someway or someone who can repair it or is it totally usless?
Solution #1
posted on Mar 22, 2008
Not Rated (0)
Matt UK
Rank:Guru Guru
Rating: 88%, 87 votes
I am assuming that the problem is with just the one tape...
Two things spring to mind - Either the tape has snapped or the reel lock mechanism is jammed.
1) Check the tape. With the cassette the right way up, press the little button on the right-hand end just behind the tape flap, flip the tape flap up and check that there is actually some tape there. If not, it's snapped.
2) With the cassette upside-down and with the tape flap facing away from you, you should see a small hole in the centre of the cassette about 2cm from the edge nearest you. Press something gently in here to release the reel locks. Then give both reels a couple of small turns back and forth (a finger stuck in the reel holes is ideal for this!) Before you put the cassette back into your machine, make sure there isn't any slack on the tape by gently winding any excess back in by turning the reels, but don't wind it to tightly - the moment you feel resistance, stop.
Hope this helps,
Matt
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Audio and Video Media problems?
pace box 4000
hiya could you help with my... Answer This...
samsung DVD-P650K region code...
My DVD player is not able to... Answer This...
froze up...won't play...nothing
It just stopped working for no... Answer This...
microphone
kayy, my webcam microphone... Answer This...
Hola le? tu post
Hola! No es que no entienda tus... Answer This...
Repair Service
Find Audio and Vid. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
