Question about Samsung 793S 17" CRT Monitor
Blurred picture Hi, When the video cable is out the "No video present" is clear as crystal. When I reconnect the PC the picture is just one mass of blurred colour. Can you help me please. Regards, Dave.
  • Dave Alexander Apr 28, 2008
    Hi Benimur,
    The monitor does the same on other computers.
    The old valve monitors had a focus resistor on the LOPT. This is what I used to get when the resistor burned out. Techniques have changed and I am at a loss,
    Kind Regards,
    Dave
  • Dave Alexander Apr 29, 2008
    Hi Benimur,
    Many thanks for your help. It all makes sense to me. I will check these things out this week and get back to you.
    I really appreciate your help.
    Dave.
  • Samsung Master
  • 13,433 Answers
The monitor might be failing, becouse if the resolution would be too high it would show a box like no video present only with Out of sync text instead.
Posted on Mar 22, 2008
    Brigadier General:
  • 6,966 Answers
Have you tried lowering the Screen Resolution and Screen Refresh Rate of the PC in its Display Properties?
It could be that you PC's current settings are way above what the Samsung can handle.
Good luck and kind regards.
Thank you for using FixYa
  • Louie  Role
    Louie Role Apr 29, 2008
    Hi again Dave,
    Appreciate the post back and additional information. Based on all the info at hand, it could then be of four (4) possiblities:
    1. focus adjustment - normally integrated with the FBT. Most current monitors have their Screen & Focus adjustments at the rear of the FBT and accessible through "holes" of the heatsink of the horizontal out transistor. Being a 17inch, it is likely that there would be two (2) focus controls;
    2. video cable - possibly an open wire of either/or both the vertical/horizontal sync;
    3. video interface - this would be the IC controlling the R-G-B buffers/amps. In all monitors, this would be where the video cable ends (inside the monitor). Likewise often (but not allways), this would be in the small PCB at the very rear of the CRT.
    Of course, it is also very possible that any other component would and could have failed. At this point, a service manual or at the very least a schematic is needed.
    Cheers.
Microsoft lifecam vx 3000 blurred outcome
You have to turn the outside ring on the camera and adjust it till it's clear. hold the camrea base and turn the outter ring it will move adust one direction then the other till you get a clear picture.
Oct 17, 2009 | Microsoft LifeCam VX-3000 Web Camera
If webcam can video record. acer crystal clear.
Web cams are very poor cousins of actual video cameras. You can record but it will not be of much use when viewed on a large screen. Moreover, the resolution and fps would be very low giving you a blurred and jerky movements. Not worh the effort.
Aug 22, 2009 | Acer Extensa 5620-4677 Notebook
Web pictures not clear
Do you have any kind of download accelerators installed? These will compress online multimedia content, degrading the quality and clarity of the picture.
Jun 16, 2008 | HP Pavilion dv6000z Notebook
Toshiba 57H82 Blurry Pic on HD inputs except Xbox 360
Probably your G-Hyper board. You will need expert servicer and should cost about 3-400.00
Craig www.classtorations.com
Jun 08, 2008 | Toshiba 57H82 57" Rear Projection...
Hi i am Sambit_73, As mentioned above i was having the same problem. I Have tried all the Browsers like IE7, Mozila Firefox, Netscape 9 , Safari. But the same problem. However i got one solution from web. Simply I have "turned Off the Web Accelerator" programme. and presently everything is Fine.
Hope U will also find the solution OK.
Apr 23, 2008 | Compaq Presario 1505US Notebook
My lcd tv picture doesn't seem right.
spurious oscillation in video circuit
Feb 08, 2008 | Televison & Video
Toshiba 37 inch TV
do you have the satellite hooked up through the coax cable if so that could be the problem you will have to manually set the settings with the remote. always make sure you have only one thing hooked up at a time. if you have cable and satellite dont hook up both it makes the picture lousy see the owners manual i think its page 58 or somewhere close to there.some times if both are hooked up it will not work at all.
Dec 10, 2007 | Toshiba 37HL67 37 in. LCD HDTV
Visuals on net are blurred
try resetting ur browser settings to default ...
Nov 28, 2007 | Toshiba Satellite A100-S8111TD Notebook
Samsung 793S 17" CRT Monitor Logo
131 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
